What oil type and any tips on oil change?
Am doing an Oil change on my 2005 1.6 Focus tomorrow. Not sure what oil to get though? 5w30? 10w40?
Any special instructions for the oil change or is it just the standard method?
the 10 w40 is to thick for the tappets it will be like treacle and will cause sticky valve cindrome and not open the valves properly or worse cases drop a valve into the pistions or knacker the oil pump up
you should never engine flush a ford engine in fact any engine as it takes the dirty/carbon build up and moves it around and could block a oil gallery or knacker up the oil pump !!!
thats why you dont do it, cost lots of money to fix all because of Ł3.99 bottle of crap was used so big no no no !!
PassionFORD Member
As said above really 10W-40 is too think and causes sticky valves.
And as for engine flush, general consensus always been unnecessary as if you change the oil regularly enough, use decent quality oil and rev your engine properly then everything will be fine.
if i was you change the oil and filter see if it clears up if not sounds like a valve stem oil seal gone down or a piston ring still means a rebuild either way
putting 10w40 in properly has killed that engine !!!!!
silly thing to do really for the sake of Ł24 pound for some 5w30 its going to cost more like Ł500 to rebuild the head ,like i said same as the other change the oil see how it goe's
hmm right change the oil and filter see how it goes if it doesn't clear strip the head down and check oil the valves make sure they are not burnt out replace all the oil stems seals and replace the tappets
is your blk top or silver top zetec ?
if blk top engine will have to re shim it as they are soild tappets
if silver top is hydraulic its a straight followed swop over but use proper assemably paste on the job too on both engines what ever you run also use a std ford head gasket and make sure get the head lightly skimmed
blk top is still 5w30 oil as well in fact all fords are 5w30
aprt from cossie's and the old school diesel escorts/mondy's which run 10w40 which is correct
JK12
33
26-04-2021 12:09 PM
oilman
Trader Parts for Sale.
30-08-2015 08:37 AM
