Focus rs mk1 ppl alarm fob
Yes it was an optional extra to have a cat1 alarm fitted from the factory,
The fob should be 'tear drop' shaped with a large button to the bottom right and a smaller one above left.
Like you say the easiest way to recognise them is with the 'rs' logo.
Hope this helps
Macca
Hope this helps
Macca
Yeah the big right button is all i use. It locks the car and provides full system security. Top left does the usual, turn off sensors e.t.c.
Hope this helps bud
Macca
Hope this helps bud
Macca
This was not an optional fit from the factory but standard.
The GT Alarm system (cat 1) was fitted as standard in order to reduce the insurance group.
The car will lock and lock the dead locks with the standard ford alarm system on the key without the "passive" cat 1 system.
The RS fob will operate the standard system and the Cat 1 system.
hope this helps
hope this helps
When locking your car you should press the ford key lock buttom twice untill indicators flash twice, this activates dead locks and ford alarm. Then press the big button on the fob once, indicators will flash once and a quiet beep will be heard, that activates the cat 1 alarm
Unlock, big button on fob first then open button on ford key.
Macca
Hi can any 1 help, having trouble with the stupid FRS GT alarm. I arm it by the fob (RS logo) and it just goes off after two secs. Checked for boot on the left where the black box is and am getting 5 LED flashes. Indicating bonnet sensor. Tried some WD40 on it still went off (Bonnet catch). Is there any way to reset the thing or am I doomed. (Only had it a week) the standard key fob works fine tho.
Using the standard fob and a disk lock at mo changing the bonnet catch nxt week, so fingers crossed if not looks like am gonna stick the standard fob fook it.
Seazer check how many flash's the LED gives off and look on the RSOC should tell u where to look.
Well just to keep any 1 updated sorted the GT alarm . Changed the bonnet catch £40 and what a ball ache to fit took 2 hours. If you have this problem get some one whos done it b4 to do it or some1 with very small hands (Big thanks to Gary and co @ Profile) lol
