PDA
View Full Version : Ford Focus Range
Pages : 1 [2] 3
  1. Focus St170, New Clutch And Slave Cylinder, Now Leaking Oil
  2. MK1 buying guide
  3. 2008 ford focus tdci alternator / battery problems
  4. Replaced 1.6 with 1.4 now not starting
  5. Car sills
  6. MK1 Focus 2.0l Turbo Build, Gathering Parts!
  7. 2002 zetec automatic gearbox problem
  8. Help with focus turbo conversion
  9. Tuning box
  10. 1.6 zetec se gearbox oil drain
  11. new to passionford not new to fords only diesels :)
  12. Focus top mounts
  13. Bumper
  14. Ford Focus 1.8tdci p0251
  15. Track car potential?
  16. Mk2 Blank button
  17. Focus Headlight adjustment motors
  18. mk1 focus key renewal
  19. Will Mondeo Wheels Fit My MK 2 Focus
  20. Focus 1.6 TDCI tapping noise on acceleration
  21. 1.8 mk1 Focus to ST170 wiring
  22. Opinions on buying Focus 2002, please help?
  23. St170 hub carriers
  24. Constant Fans
  25. Thinking of getting those £200 JOM coilovers...
  26. Focus Tddi
  27. focus 1.8 tdci poor idling after new clutch
  28. Replacing engine on 55 plate Focus CMAX
  29. 2000 focus engine temp gauge broken?
  30. car heater problem
  31. help!!
  32. Whos best to contact concerning the mk1 focus engine
  33. Mk1 rear handbrake cable
  34. Soon to be a St170 owner
  35. Wind deflectors on Focus ST mk2
  36. Heated seats 2004 Ford Focus LX need help ! ! ! !
  37. Focus RS 4273 / Resto / Mod / Build Thread.!
  38. Focus 1.6 tdci problems!
  39. Ford Focus GTR
  40. st170 solid flywheel conversion
  41. ST/RS rear diffuser size
  42. ST170 Decat
  43. Air con only working when outside temp is >25C
  44. Ford Focus Exhaust Help Please
  45. Focus RS MK1 external fuel pump
  46. How hard a job fiting a new cambelt...2002 1.6 Zetec focus
  47. subtle stutter at warm idle on focus
  48. will these fit??
  49. Ford Focus Ghia parts
  50. mk1 focus questions
  51. 2000 Focus Central locking Problems
  52. St170 fault codes
  53. MK1 RS seats
  54. MK2.5 Armrest - Help Please
  55. St 170 steering rack bolt
  56. ST170 brake rebuild...
  57. Recaro Seats
  58. another problem
  59. CMax Ti Vct problem
  60. focus saloon exhaust
  61. Mk1.5 focus with escort cosworth wheels?
  62. Help
  63. FRS - Where does this go?
  64. more power
  65. Lowered suspension kit for focus
  66. TPMS
  67. doing my focus up carpet advice needed
  68. Read this before you replace your maf!
  69. Focus MK1/1.5 3dr Genuine Ford Roof Rack Wanted
  70. Ford Focus Coupe 1.6 16V Engine/Exterior Tuning
  71. Help needed - Misfire
  72. mk1 2.0 de-cat advice
  73. FOCUS Spruce up
  74. Oil for a high mileage 1.8 petrol zetec.
  75. focus st buying advice please!!
  76. Mk1 Not Starting - Fuel Pump?
  77. Mk1.5 Focus Damp passenger footwell
  78. Focus mk1 1.8zetec
  79. Steel Wheel Help
  80. Focus ZETEC SE EML light
  81. 1.6 Firing on 3.
  82. juddering/misfiring under load
  83. fitting lowering springs
  84. Mk 1 Central locking
  85. Ford Focus TDCI Poor Acceleration After Fuel Filter Change
  86. Glow light goes out after just a second.
  87. Stolen focus st3
  88. 5 Stud conversion
  89. mk1 misfire
  90. mk1 focus rs clutch
  91. Focus st170 exhaust advice ?
  92. fusebox question
  93. Focus Lambrda Sensors
  94. Newbie here :)
  95. PIC REQ - MK1 Focus with 17" Zetec S Streetpack wheels
  96. No USB Port
  97. 99 Focus Abs/esp Sensor And Ring
  98. Focus ST mk3 Wheels
  99. ST170 Megasquirt
  100. focus st225 clutch or gearbox problem
  101. Rear disc pads
  102. Replacing oil seals while replacing timing belt -- is it a good idea at all?
  103. mk1 focus digital display and clutch probs
  104. FRS MK2 windscreen
  105. 1.6 tdci engine cutting in and out
  106. Coupe Brembo Calipers On Focus 300mm Discs?
  107. HELP ford focus mk1 disc conversion from drums help
  108. Would you buy this?
  109. Heated Seats on mk1.5
  110. Ford focus diesel gearbox - ford escort diesel engine
  111. Exhaust
  112. My focus - picture gallery step by step
  113. mk1 focus 1.6 2 quick questions
  114. St170 after market exhaust. What to get
  115. Interior light and power mirrors keep blowing fuse
  116. Aircon problem in my ford focus zetec
  117. Focus t190
  118. 1.8 TDCI major misfire like symptoms
  119. Focus st1/2/3 owners
  120. Rear brake caliper not letting wheel run free--HELP
  121. Gearbox pinging and loose in neutral
  122. Ford Focus CMAX 2006 audiobox sony cd Keycode
  123. What to look for if buying a mk1 focus?
  124. Ford focus
  125. focus auto
  126. Imrc making strange noise
  127. focus 2008 tow bar electrics
  128. ford c max electrical problems
  129. Modifying my Focus LX 1.4
  130. mk 1 focus maf problems
  131. mk1 focus rs cutting out
  132. mk2.5 1.6 petrol coilovers
  133. Mk2 Focus estate rear sway bar
  134. steering wheel control
  135. focus gearbox
  136. Focus starting problem
  137. focus 1.8 tdci - poor mpg
  138. Focus MK1.5 headlamp bulb replacement?
  139. Bearings for a ST170
  140. Small(ish) Mods for Ford Focus
  141. Focus Bonnet
  142. Wanted focus mk1 to 1.5 conversion plug adapters ? help
  143. Focus RS MIL Light Fix
  144. MTX75 flywheel & clutch advice
  145. wtf is going on
  146. wiring some heated seats into my focus esp
  147. Hello
  148. Very hard getting into 5th
  149. Focus 1.5 Headlights
  150. EGR Valve Location
  151. system engine fault
  152. 1.8 TCDI EGR or fuel pedal
  153. 1.8 mk1 to turbo or not to turbo thats the question
  154. Ford Focus RS Front Suspension Arms / Wobble Problem
  155. focus mk1 1.6 loss of power and engine light
  156. focus 1.8TDCi DTC code P2339
  157. anyone know what this is?
  158. Coil pack
  159. fan heater blower only works on 4
  160. 1.8 turbo diesel problems
  161. Mk1 TDCi turbo info?
  162. engine managment light 1.6 mk1 focus
  163. 2004 focus charging light problems
  164. Ford Focus electric
  165. Which spark plugs for mk2 fucos 1.6 (115)
  166. Focus 1.4 Engine Rebuilding
  167. heater only working on 4
  168. 2007 mirrors
  169. 1.8 turbo diesel problems
  170. Ford Focus Retro Fit trip Computer
  171. ST225 won't go into 5th
  172. New Focus Owner with a Few Issues
  173. Main Beams not working
  174. Head unit fitment
  175. focus 2006 non start help ford techs
  176. Roof bars
  177. Hand brake
  178. Ford focus diesel starts and won't start
  179. 1.8 TDDI remap
  180. Mk1 Focus problem
  181. Mk 1 AV53 LGK. Build 3133, anyone know this car?
  182. Stolen Wing Mirror Surround - Advice Needed!
  183. New member, brake advice please!?
  184. Any Focus mk1/st170 Suspension Guru's please?
  185. Focus fuel flap
  186. Move Hazard switch to TC switch?
  187. Ford Focus ST170 Hesitation
  188. Carpet removal help
  189. weird boil up
  190. swapped Zetec to D2.3, now electrical problem
  191. Placement of foam piece in line with front cabin filter cover
  192. Leaky iB5 Gearbox
  193. New Member
  194. St170 tapping noise
  195. Some additions to the gfs focus
  196. ST170 standard exhaust code?
  197. Focus zetec 1.6se difficult to start when hot
  198. Rear trailing arm bush
  199. 4x108 to 5x108 conversion help
  200. Focus Alloy Wheels
  201. C-max problem help needed :)
  202. mk 1,5 8 pin front electric window motor
  203. De-Cat! MOT Fail!
  204. golf clubs in boot of mk1 focus 3dr/5dr hatch
  205. PLEASE HELP: Ford Focus Auto - Engine Systems Fault, Transmission Malfunction errors
  206. Lowering a 51 Plate Focus Estate...
  207. trip computer wires
  208. Alloy wheel refurb questions
  209. Yaw Sensor Location on 2006 focus
  210. Just bought a Focus TDCI and have some questions
  211. Bonnet will not open?
  212. ST170 Coolant Leak
  213. Mk1 Focus 1.6 wheel stud dimensions?
  214. mot
  215. MK1 Focus Estate O/S sideight issue!
  216. Fuel Pump replacement on St170
  217. 2wd to 4wd conversion
  218. problem with car when its left out in sun wont start focus help please
  219. focus gearbox
  220. Servicing question
  221. Rattle at specific RPM but only when hot?
  222. Drum to Discs Conversion
  223. mk1 focus blown engine help?
  224. mk1 st170 focus air box and snorkel
  225. Help seized door !!!!
  226. focus tddi help
  227. ahhhhh this car......judder/hesitation under load
  228. Uprated Clutch Master cylinder
  229. lowering focus st170 on springs will it be ok
  230. Coilovers???
  231. HELP PLS Aux belt tensioner
  232. Help fitting fuel computer to Focus MK1
  233. Fitting Traction Control to Zetec?
  234. Focus MK1 Dashboard Ideas? Maybe iPhone Dock?
  235. A/C high side too high
  236. Rear trailing arm front bush
  237. focus mk2.5 footwell light's??
  238. does the focus st 170 have a torque limiter
  239. help please :)
  240. air direction knob fix
  241. 2005 Focus immob starts light flashing while driving
  242. Heater fan broken
  243. Wheel Shimmy
  244. Steering Immediately Stiff then Slightly Less
  245. Torque App With Obdii Bluetooth Scanner
  246. Mongoose Exhaust Offers!
  247. New Airtec Product Offer!
  248. 1999 Focus Bonnet will not open
  249. New to site, very confused please help
  250. Focus boot release problem!
