Ford Focus Range This Section Contains All The Ford Focus Model Specific Forums.
Ford Focus Retro Fit trip Computer
Old Aug 10, 2012 | 08:43 PM
jelly-monster's Avatar
jelly-monster
Exclamation Ford Focus Retro Fit trip Computer
Hi,
I am in the process of wiring in a trip computer into my 2003 Focus. Unfortunately it didn't have the loom so I'm having to run all the wires =(
I have done 11/15 wires =)
I am using this guide:
http://www.luckyb.pwp.blueyonder.co....too%20comp.pdf
The wires I haven't bothered with yet are:
Black, Orange Stripe
Output to low washer fluid switch on washer bottle
Run this cable to the washer bottle and connect to the top pin of the connector (nearest the connector release catch).
Brown, Yellow Stripe
Output to outside air temperature sensor
Run this cable to the temperature sensor location and connect to the bottom pin of the connector (farthest the connector release catch).
11
White, Black Stripe
Input from outside air temperature sensor
Run this cable to the temperature sensor location and connect to the top pin of the connector (nearest the connector release catch).
16
Central Timer Module (CTM) (Ground signal).
Splice into Black, Green stripe wire going to the air bag diagnostic connector (PIN11) located under the centre console behind the handbrake.
Basically, it's not showing MPG or average speed or anything to do with speed =(. Pin 16 is the only one that might have something to do with this? Can someone verify that? I thought it was just to make it beep?
Thanks
JM
Old Aug 21, 2012 | 06:24 PM
jelly-monster
Also, does anyone know how to completely remove the centre console? When I tried the handbrake was stopping it.
BlakeMoyle
Sep 1, 2015 02:24 PM
Jack and the Beanstalk
Aug 15, 2015 04:27 PM
track.focus'd
Aug 12, 2015 05:53 PM
taylora1409
Aug 12, 2015 12:06 PM
