Ford Focus Range This Section Contains All The Ford Focus Model Specific Forums.
A/C high side too high
Old Feb 19, 2012 | 09:36 PM
pakososa's Avatar
pakososa
Angry A/C high side too high
I have A Ford Focus 2004 and the high side are too high . What could be the problem?
Old Feb 19, 2012 | 10:00 PM
DazC's Avatar
DazC
Trinary pressure switch or the cooling fan are common causes (on any vehicle with this problem).
The Trinary switch usually has a low pressure circuit and a high. When the high side is tripped, it should cut the compressor and the cooling fans should activate (or should go to high speed mode if they run at constant low speed) to cool the gas and bring the pressure down.
boeb
Jan 9, 2020 05:11 AM
Kam B
Sep 30, 2015 01:32 PM
