Ford Focus Range This Section Contains All The Ford Focus Model Specific Forums.
Rear disc pads
Old Mar 2, 2013 | 07:07 PM
sococsi's Avatar
sococsi
Default Rear disc pads
I have removed the disc pads from the rear of my Ford Focus 1.8 TDi 2006
The pads I have bought have 2 metal studs on the back one of each pair, the ones I removed do not it seems the removed pads have a spring layout on the back very thin, that clips around the callipers piston, at first I thought they may have been modified so the 2 studs slotted into the face of the piston but then thought because the pistons needed to turn to be retracted back for the new pads to be fitted that the piston would also have to turn as the pads wore down and if the slots where fixed to the piston this would not allow it to turn outwards. am I right and therefore have the wrong pads?
Old Mar 15, 2013 | 08:26 PM
onestan's Avatar
onestan
What brand of pad did you buy?
If its Mintex you should have mdb2686, Ferodo part number is fdb1931.
If its another brand let me know and I'll cross ref it for you.
Steve Escos
Ford Focus ST Parts for Sale
Sep 2, 2019 11:39 PM
155lee
Sep 6, 2016 11:10 AM
yatta
May 21, 2016 10:31 PM
morg65
Escort MK 5 / MK 6
17
Sep 11, 2015 08:40 PM
cossirob
Sep 3, 2015 09:17 PM
