- Ford Focus Alloys
- 2009 focus 1.8 zetec-S
- Jumping out of 2nd gear
- oil pressure question
- Whiring noise when I accelerate
- Zetec idle problem
- Exhaust
- Focus Estate Tailgate Latch Problems?
- focus pterol vs diesel
- RAL Colour
- Fuel gauge problem on Mk1.5
- how to get a bit more out of a 1.8 focus
- Focus S Max 2.5T gerabox?
- Temp going into red when on motorway/higerh speeds
- URGENT advice needed - Focus 1.8 Zetec issue
- 1.8 Headgasket gone, engine swap?
- rs transplant
- w.reg focus tdi cambelt question
- Replacement Sony CD / Radio
- Focus st 225 bonnet switch
- Mk1 Focus headlight adjustment motors?
- 18 or 21mm taper on bottom swivel?
- MK1 Focus Rear Trailing arms (dogbone shape ones)
- Mk1 flickering headlights !?
- Ford Focus mk1 Drivers side wiper sheared off
- Focus mk1 1.6 zetec (high mileage)
- Focus mk1 1.8 zetec
- Car feels like I've touched the brakes.
- Focus 1.6 Zetec Auxiliary Belt Tensioner
- OIL
- Mk1 estate rear window blinds
- Focus estate 1.8 16v zetec
- Body shops
- Just ordered..
- Newbie with focus problem.
- OBD Error code - doesnt make sense
- Idle Problem
- Focus Mk1 Ghia Trip Computer
- zetec and ST170 suspension
- Ford focus speed sensor
- Replacing the inlet manifold with one from a fiesta ST
- Oil burning problem? Expensive repair?
- GEM replacement
- help locating lambda sensor please
- New to ford , and a problem already!
- hot then cold air
- hot then cold air
- Coilovers..
- focus rs mk2 engine?
- Focus 1.6 zetec misfire, loss of power, CEL
- Looking to upgrade my breaking on my focus
- someones nicked my roll bar???
- Focus 1.6 Zetec - Engine Noise on startup
- 02 focus zetec 2.0 loss of power
- Focus aircon/heater problem
- Y reg focus 1.6 zedtec hesitates / nealy stalls when pulling away
- Focus 1.8 16V Zetec estate speedo issue
- Focus Alloy Wheel Trims
- Cmax service intervals?
- exhaust question
- 2002 focus speedo, clocks on and off???
- Boot Lock 06 Focus
- Cannot Remove Battery From Mk 1 Focus 1.6
- Knocking noise from pedal box (break pedal i think)
- Driveshaft Fault on 2004 Focus HB?
- Newbie and wishbones
- 1.6 ghia yr 2000 gearbox ?
- HELP!!!!!!
- mk1 Focus rear caliper removal/swap...
- Ford focus flashing glow plug light problems
- 1.8 sport
- 1.6 zetec conversion
- 1.6 Focus Ghia 06 plate.
- Handbrake cable
- 1999 1.4 focus won't start
- 6speed gearbox
- Side repeater
- Baby Focus 1.4 cam belt change.
- st170 back boxes on mk1
- Focus Engine Management Light Flickering
- mk1 focus electric window problem. HELP!!!
- Have i just killed someones car ?
- JOM coilovers, can you get them for the estate?
- Mudflaps
- Petrol Flap and Housing Help!
- St170 snorkel
- Genuine ford sony stereo im my mk1
- focus 3 botton key
- failed mot on emmissions
- Focus LX 1.8 Idle Problem
- Best aftermarket exhaust system (1.6 Zetec S) (2010)
- 99 focus Zetec s engine question
- MK1 1.8 Petrol ECU
- mk2.5 eibach problem
- Mk 1 wipers starting on thier own
- hand brake problem
- Mk1.5 focus wipers
- st170 random sensor cable tied near battery? hhhhelp please!!
- Focus engine problem??
- Bluefin SuperChip??
- FOCUS ZETEC 1.8 Petrol 51 PLATE - CAM BELT etc change
- Fifth gear issues
- Focus mk1 petrol red lining at 4500rpm
- wheel offset
- Ford Focus - Boot is jammed
- focus st170 engine swap
- Sill Scuff Plates
- Will I need the CD Code
- mk 1 heatin/blowers
- focus mk 1 tick
- New Owner - EML query
- Mk3 rain sensor problem
- ST170 Hubs in Focus 1.6
- Will facelift 08-11 clear rear lights fit on my 2006 Focus??
- Focus 2003 Front Speaker Template
- Ford 1999 focus 1.8 fuel pump removal ...
- Mk1 Focus Water Leak, Whats Underneath The Rear Bumper?
- Locking Wheel Nuts Problem
- New ford focus blower / fan problem
- I need help with my focus project, can't find anything on kits for the saloon
- mk1 Focus brake issue
- engine management light is on and flashes if driven over a certain speed. Limp mode?
- 08 1.6 zetec 3dr improve / upgrade
- Lowering a 2002 focus estate
- car dies uphill.... any ideas welcome
- best way to get more bhp out of my 2.0 esp focus???
- focus 1.8 air filter.
- tripometer display on the dash is on constantly
- Quickclear screen issue
- Focus 55 plate bonnet catch
- why is my focus chiming?
- Thinking of buying a Focus
- Mk1 Remote key
- HELP!!!
- Very Strange Issue?!
- 1999 1.6 zetec gearbox change
- Why Wont An Ashley 1.8 Exhaust System Fit a 2.0?
- Gear Box
- 1.8\ 2.0 mix match?
- Focus MK1 ESP differences compared to normal focus MK1? Rare?
- Focus Newbie
- keyu central locking working intermittently
- Bumper ID?
- Threads asking for Car Stereo codes are not allowed.
- Fitting LED indicators, left side not working
- LED indicators, help needed!
- Window rattle :s
- ST170 gearbox
- idle problems
- Ford Focus Mk1 Saloon Brake Nipple Size ???.
- 200bhp 2.0 zetec s help overfueling
- ford focus automatic
- Coolant
- Ford focus mk1 brake bleeding
- Mk1 Electric windows, Global closing/opening question
- Has anyone put a 2.2 Mondeo TDCi engine into a focus?
- Trailing arm bushes help
- Modified Facelift Focus MK1.5 Headlights (Guide)
- 200HP N/A 2.0L Zetec - Cam selection
- 2001 focus EML, what does fault reading mean?
- 1.8 or 2.0??
- Focus 1.6 Zetec Auto Losing Coolant And Losing Power?
- Lowering 2003 focus zetec?
- focus 1.4 petrol mark 1
- Focus Mk1 Zetec
- 2.0 ecu
- focus mk1 carbon door handles
- remote locking problem
- update on my car
- Focus brake and parking sensor help please
- missing wiring plug please help!!!!!
- Cobra Bucket Seat Help
- Using silly amount of petrol? HELP!!!!!!
- List of issues Mk1 focus
- Tuning options for 250hp Zetec 1.8 Turbo
- Converting a mk3 focus to mk4
- Mk1 to Mk2 Headlight Conversion???
- engine number
- Prob after lowering
- Engine conversion help???
- Focus 1.4 Engine Issues (Yeah, I know it's rubbish)
- Brakes just died suddenly
- 2.0focus HELP
- Fast Help Needed *2007 FOCUS 1.8 Petrol ALTERNATOR
- big rear brakes ???
- Modifying ST170 dash
- front hubs
- Radio help
- Changing dash
- no brake lights help needed
- ford foucs 1.8 zetec
- Need help with my 2.0 Ghia mk1
- Fit heated front screento a Mk 1?
- I need help wiring my towbar please I'm so confused!!!!
- Lowered Mk1 Focus front knocking noise
- Mk7 Fiesta diffuser onto Mk1 Focus
- Need help mk2 focus
- Aux Fuses
- Focus mk1 1999
- 2008 focus radio fudged??
- K & N gen 2
- Steering Wheel Change
- Zetec S 2.0L petrol (145ps)
- Connecting new stereo to steering wheel controls
- Idle issues....again!
- focus 6000 code and multiplayer
- Focus Electrical
- Will it fit?
- Ford 6000 to 7000 Radio
- will it work?
- fitting a ET42 alloys to mk1 focus?
- Focus S 1.6
- CEL
- Mk1 Focus 5 stud conversion
- Any good....2.0 ESP PH1 Focus?
- Fog light conversion - where are the wires?
- Focus 1.8 to 2.0 engine conversion! HELP.
- focus auto slipping out of gear
- lambarda sensor
- Focus 12 year anti corrosion warranty?
- mk2 map sensor
- Mk1 Focus fitting electric mirrors
- Best place to get a stainless system for 1.6 mk2 08 plate
- focus timing belt
- gearbox selector seal leaking
- Ford Focus MkI or MKII
- turbo conversion
- Focus MK1 digital heater/aircon panel
- Focus oils
- Mk1 Hissing...
- Focus III Ecoboost
- Understeer?
- Disassembling mirrors
- Which focus?
- T25 turbo questions
- ford focus 1.6 zetec cambelt change
- Changing Exhaust Mk1 Help Please
- Non RS Or Non ST
- Focus abs
- Ford Focus Turbo problem?
- Focus T190 sensor.... What is it???
- Focus door 3/5 doors interchangable
- 1999 1600 focus dials sweep
- over heating problem on my ford focus ztec
- Lowering Focus 1.6 on 17's?
- Focus 1.6 coilovers?
- Ford Focus Titanium 2011 Model
- ST170 inlet manifold runner control
- Ways of removing ST170 VVT?
- focus speed sensor removal issues..
