- Focus estate/van conversion
- mk1 focus svt lights fitting guide
- Audible Frost Warning
- Will Mondeo mk3 Seats fit Focus mk1.5
- Mk3 Focus'
- Focus mk1 2.0 clunk & simultaneous jerk
- Startup help please!
- 38mm festoon bulbs in a mk1 focus
- Focus c max, error code p0238
- ST170 xenons on a MK1
- Mk1 focus front and rear bumper removal
- So, do i need a different regulator or not?!
- 54 plate mk2 focus 1.6 TI-VCT cam belt change advice
- st170 gearbox swap?
- mk2 Focus 1.6 VCT non-start blows fuse 34.
- mk 2 power
- cougar 16"s
- 1.6 SE Enigine Recondition
- Headlight bulbs blowing
- 3 Rings ?
- Ford S-Max polyurethane bushes
- Central locking
- steering wheel straight vehicle pulling to the left after geometry
- mk1 focus wheel spacers question
- Changing ECU
- speedo not working from time to time
- puddle lights
- mk1 focus low speed on and off rubbing/grinding noise plus a clunk
- Nearside front brake seized.
- Custom Focus Stainless Steel Inlet Manifold. pics
- mk1 focus st recaro + 6 cd changer query?
- Mk1 Focus Motosport
- MK1 focus non start
- Focus MK1.5 1.6 Zetec SE Idle
- 99 focus s-se cylinder heads
- The Focus MK1.5!
- Uprated parts from somewhere other than shawspeed?
- C Max 1.6 TDCI Engine Electrics - non start
- Xenons?
- Focus Zetec S Front splitter were to buy ???
- zetec rs turbo gear box
- 1998 1.6 starting problem
- fuel consumption
- Water in back passenger footweel
- Help needed locked keys I the boot if my mk1 focus!
- Ford Focus Mark 1 1.6 Zetec Engine Warning Light
- Auto windows/Electric Mirrors
- Focus not starting - Now fixed!
- Overheating and not accelerating
- tappit noise on start up
- Bonnet stuck in lock position!!!
- Stinker!!
- mk2.5 1.6 Zetec ESP issue
- Mk1 Focus eBay Intercooler pipework?
- My Mk1 1.6 focus
- Unlocking the car unlocks drivers and rear pass door first?
- When foot on brake all lights dim/flicker?
- Focus 1.6 2008 clicking rear brakes
- Focus remote buttons not working
- £330 for Focus alternator - RAC roadside fix. Fair?
- Any ideas?
- Glove box light cable
- Paintwork damage
- 2001 Focus 1.6 Temp Issues
- Ford Focus instrument cluster/Vss (speed sensor)
- High Idle After Fueling
- heater problem ford focus 2000
- focus reversing lights..
- can anyone check a Ford finis code to a part number??
- Focus mk1 aircon pipes
- Focus burning oil
- I sit true no MAF sensor on a 52 Plate Focus
- need help on engine swap or conversion
- Ignition barrel problem!
- mk1 focus RS or Focus ST 225??
- Replacing the fuel pump
- keeping the focus mk1 1.6
- oil filters
- mk1 1.6
- 2000 ford focus mk1 central locking problem
- 57 plate mk2 Focus to ST/RS body.
- Popping from under the bonnet
- Outer heater blowers not working
- Revs are high with new icv
- Head torque settings 1.6 zetec se
- aftermarket stereo connecting problem
- 1.4 focus erratic idling
- 2002 Focus 1.6 16v fitted with K&N Air Filter strange results (no raspy noise)
- clunking noise from the front
- C max hot starting problem tdci
- Hello & Greetings
- WTB Zetec 98-99 Mountune & WRC 2000-04 water pump housing
- help !! my focus zetec 2litre petrol has just stopped on me !!!
- Sudden loss of coolant + another annoying problem
- Fcus - Persistent valve cover oil leak.
- Removing valve cover on 2001 Focus 1.6 SE
- Transmission Malfunction (Please Help)
- Focus mk1.5 xenon conversion
- Focus Accerator Modification
- Centre Console
- Focus exhaust
- Ford Focus Misfire
- water leaking from dashboard
- Best focus engine to get?
- infomation books
- Central Locking Help...
- Urgent Help. Engine Warning Light
- Ventilation/Heater fan brushes
- Thermostat and temp gauge faulty?
- rear trailing arm bushes
- zetec 1.4
- lowering 1.8 mk1 focus
- focus zetec
- Re brakes.
- Electric Window Fault
- Coil springs
- Mk1 Focus Flight Upgrade Advice Needed
- 3 Problems I Can't Find An Answer For ??
- Mk1 Focus front fog light removal
- Focus wont start
- Turning off airbag
- driveshaft support bearing
- Focus MK1 1.6 16v Idling Rough And Loss Of Power!?
- MK1 focus failed MOT on emissions
- Ford focus st170 air box
- Help needed fast !!!!
- 07 plate sidelights, taillights and Dashlights
- 02 Focus Dash & power loss issue.
- clutch pedal question
- Corner air vents
- Focus 1.8 zetec
- MK2 Focus bumper for a MK1?
- Electronic Stability Control problem on MK1
- Aldon Automotive Flame Thrower Ignition
- Bonnet lock nightmare
- Rear spring replacement
- Problem after tracking
- problem with my focus
- adapt headlights for continent Ghia 2L 2001
- focus dials. Can you find out mileage without them being plugged in?
- Oil Catcher Can 1.6 Petrol, Where To Put It ?
- Focus ZETEC SE Issues/Questions
- focus 2002 tdci removing gearbox help
- Mk1 2.0 esp key
- FOCUS mk2.5 titanium build diary ,just started (UK)
- Rev counter needle flicksup/down but engine fine..
- Where can I get this spoiler?
- Problem starting Ford Focus 56 plate
- Lack of low down power.
- Brake fluid
- focus mk1 key fob helpp
- ST170 Rear brake conversion
- can i fit focus st xenons
- Where to find a Car Carpet
- Idle Problem
- Knocking from rear
- heater control problem
- Fitting ST170 seats into a mk1 ford focus
- Steering noise
- Heater
- Dead Focus?
- Mk1 Focus Steering Wheel change
- Consul switch identification
- SW Autodesign Bodykit For MK1/1.5
- mk1 focus gearbox.
- any one
- 06 focus boot release problem
- Ford Focus 1.4 2003 Idle - or not
- How easy to change outer CV boots on a mk1
- Focus Rear disc conversion
- mk1 focus indicator removal
- Require new alloy wheel for 2000 mk1 - confused?
- Central locking problems, help!
- wiring harness under the seat
- Mk2 Focus Irdium Plugs
- bloody cold starting!! where is the cooloant Temp sensor??
- Front wheel bearings
- escort series 2 rs turbo bonnet vents
- 02 Focus 1.8 thermostat housing??
- Buying My First Second Hand Focus. Advice Please.
- 2007 Ford Focus 2.0 issues
- focus SVT style rear lights
- Focus MK1 pats/new key/programming questions
- rear brake problem
- mk1 focus dmf???
- Brake Lines Help Needed
- Rear nearside indicator
- Ford Focus Automatic Part Numbers Required.
- ABS question
- st170 xenon fitting to a standard mk1.5 Focus
- focus 05 1.6 115ps engine replacement
- 2003 speedo cluster
- i have a problem
- Focus front wing fitting
- eco tuning
- Mk1 Focus help.
- Mk 1 Focus Knocking From Rear Suspension
- MK3 CD player in a MK2 Facelift Focus?
- focus gear ratio
- blower motor resistor
- Is it a clutch cable on it's way out?
- problem with clutch in new ecoboost 1ltr
- modifying 08 focus style
- Engine Revs
- MPG Seems CRAZY
- Focrd Focus Brake Problem
- HID on focus zetec s problems
- Ford Focus 1.8 52 ENGINE MANAGEMENT LIGHT!!!!!
- Mk1.5 focus heaters
- Focus mk1 collection front bumper
- Focus Zetec starting problem
- when i hit the brakes idle goed down
- Focus MP3 spoiler?
- CHT Sensor
- Reg plate lights , need help mot due !
- ford focus 2007 fuse panel layout
- Keys for 1999 1.6 zetec
- Focus immobiliser help plz
- which springs
- Mk1 FRS key and key fob.
- Fans don't cut in on focus 02 reg
- auto gears
- Mk1 1.8 revs hanging.
- doors continue unlocking
- Focus 1.8 zetec 53 plate , mpg
- 05 standard to ST foglight upgrade
- bonnet problems
- Nitros
- Cambelt / chain on a Zetec
- Ford focus 1.6 2000 plate running rough
- Stereo upgrade
- heavy blue smoke on cold startup
- Focus 2006 rear numberplate lights
- rhd convert lhd
- reverse gear
- interior lights
- 2.0l blacktop zetec on gsxr 750 throttle bodies - anyone have a DTA s40 pro basemap??
- 2.0l blacktop zetec on gsxr 750 throttle bodies - Omex 600 or DTA S40 pro??
- estate coilovers??
- 2002 Ford Focus Running Issues
- 1999 1.6 petrol focus
- 2008 Ford Focus key Fob problem
- Focus 2012 running lights
- Focus Sport 2011 Model
- mk1 focus mystery no power under load/forward gears
- Focus Mk1/1.5 corrosion issue....
- st225 cv joint tsb fix??
- Ford Focus heater control speed setting dial problem
- S reg Ford Focus, interior heater switch not working
- EsCos wheels on a MK1 Focus
