Ford Focus (All Models) This forum is for discussion of all things pertaining to the Ford Focus Range that doesnt belong in the seperate ST & RS sections..
driveshaft support bearing
Old May 19, 2013 | 11:00 AM
Daniel-1986's Avatar
Daniel-1986
Default driveshaft support bearing
How easy is it to change the support bearing on the O/S driveshaft on a mk1 focus
Old May 19, 2013 | 05:32 PM
xenton's Avatar
xenton
Enthusiastic Novice
You have to remove the entire O/S drive-shaft, and then pull the bearing (with a puller). In terms of difficulty, not too bad.
Handbrake on put in 1st. Loosen your drive-shaft bolt. Loosen your upper strut mounting bolt 5 turns, loosen wheel nuts. Jack and support on axle stands , I would then drain the gearbox oil. Remove lower arm ball-joint clamp bolt and prise lower arm from hub (use a long bar levered against the underside of the car, do not use a ball-joint separator, as it tends to feck the dust cover. Completely unscrew the drive-shaft nut, then pull the hub outwards to remove the drive-shaft from hub (may need persuading with rubber mallet). Once out tie the end of the shaft in place or support on an axle stand. Undo the support bearing retaining bolts. Pop the drive-shaft out of the gearbox and withdraw from under the vehicle. Remove bearing using a puller.
Reassemble in reverse order and I encourage nice fresh gearbox oil (SAE 75W/90).
Old May 19, 2013 | 08:01 PM
Daniel-1986
cool cheers, I looked on ebay for the bearing which was around £25 then found a complete driveshaft complete with the bearing fitted (asked ebay seller to confirm this first) for £30 which ill get, gonna change the whole shaft as the clutch needs doing soon
Old May 20, 2013 | 04:25 PM
xenton's Avatar
xenton
Enthusiastic Novice
Well that'll save you some bother.
Old May 21, 2013 | 01:51 PM
Daniel-1986
yeah it will, its got a grinding noise coming from my side which ive had since just after I bought the car but nothing showed up in the mot to with the wheel bearing and this can be the other place it cud be so gonna change the driveshaft see if that help as doing the cheapest options first
Old Jul 26, 2013 | 07:00 PM
James B's Avatar
James B
Is it hard to swap complete drive shafts as I think it is the problem with my car. I've had the front bearings replaced so it rules them out now. Yet I still have a very metallic grinding and vibrating and its worse accelerating or braking but constant at a steady speed.
Old Jul 26, 2013 | 07:02 PM
James B's Avatar
James B
Meant to say mine is an 06 mk2 focus. I assume they are very similar?
Old Jul 26, 2013 | 07:05 PM
Daniel-1986
Im not sure tbh, I had my driveshaft changed wen I had the clutch done, killed 2 birds with 1 stone then
Old Jul 26, 2013 | 08:40 PM
James B's Avatar
James B
Did it cure the noise problem?
Old Jul 26, 2013 | 08:58 PM
Daniel-1986
It cured mine, tho now think my lower arms or balljoints are knackered
Old Jul 27, 2013 | 05:06 PM
James B's Avatar
James B
Endless ain't it lol
Old Jul 28, 2013 | 06:58 AM
Daniel-1986
tell me about it
89barto89
Oct 4, 2015 06:59 PM
fordrallycar
Sep 30, 2015 07:57 PM
20/20 vision
Sep 28, 2015 03:03 PM
mondeomark
Sep 28, 2015 06:28 AM
DavidK
Sep 27, 2015 02:55 PM
