Ford Focus (All Models) This forum is for discussion of all things pertaining to the Ford Focus Range that doesnt belong in the seperate ST & RS sections..
focus st170 engine swap
Old Feb 1, 2012 | 08:55 PM
fpst170's Avatar
fpst170
Default focus st170 engine swap
hi all,
i have a 02 st 170 write off and a 2000 focus 1.8 black top zetec,what i would like to know is can i simply swap engine/box/shafts etc, ecu clocks straight over retaining the 1.8 wiring harness ,or will i need the st wiring loom too?
and if i do need to swap wiring does the engine loom seperate or is it a all in 1 job?
any advice from anyone who has carried out this conversion or generally knows their way around a focus would be much appreciated
thanx
Old Feb 1, 2012 | 09:40 PM
Freeked's Avatar
Freeked
You'll need to swap everything from the written shell to the good shell....loom and fuel system. That's because like many people will tell you...the ST170 doesn't have a normal fuel return pipe, because it's controlled by the ECU.
I'm afraid your job is a lot worst than you would thought before
Old Feb 2, 2012 | 01:29 AM
danme1987's Avatar
danme1987
As above. you will need all the engine loom and dash loom. but you have all parts so wouldnt be to bad just time consuming
JoeyBoyden
Jan 4, 2024 02:36 PM
Palethorpe01
15
Aug 18, 2015 06:09 AM
Rickyrustyfox
Aug 13, 2015 01:11 PM
gordyshreds
20
Aug 10, 2015 02:59 PM
