Have i just killed someones car ?
Hello, sorry first post is a question, i did have an account a few years ago when i had my foci.
Anyway, i thought changing a speed sensor on an old focus bould be a doddle. Well, firstly the pin wouldn't come out. After alot of agony it finally came out, but when trying to pull the sensor it snapped in half and it is about 3mm inside the housing. So i tried to drill a hole and put a screw a hook into the sensor to yank it out, still didn't work and when i unscrewed it gearbox fluid has started to spew out of the hole i had drilled,
....help
....help
st170 breaking
thread the hole and bolt it with a copper washer in there too, not too long a bolt!!
thats if its into ali
i dont really know otherwisw as theres no pics or real description of whats fucked
Ben
Run.
Abroad.
Anywhere they won't find you.
Abroad.
Unless you can extract it then it's gearbox out time. You could try applying heat to the surrounding area to try and shift it. Or just punch it through and hope it sits at the bottom of the gearbox for the rest of it's life, like I did with an astra once
Would you go to the effort of stripping the gearbox out of an old astra that's worth about Ł100? Bearing in mind I drove it fine after for about 8 months until the MOT ran out then I just gave the thing to a mate, which is still sat at the bottom of his dad's field nearly 10 years on
I don't understand where the oil is coming from unless you've drilled through the casing somehow?
They're fuckers when they get stuck in the box, I have used a big screw in a dent-puller type slide hammer to get them out.
if the hole is straight through whats left of the sensor, then perhaps the box is overfilled with oil.... and so maybe nothing to worry about. just needs to be drained and filled to the correct level!
So know the sensor is somewhere in the box, i started her up with the wheels off the ground and stuck it in gear, heard abit of a noise (like putting something plastic in a blender) but then it stopped.
I mean its a T reg focus, so isnt the end of the world, sorry if ive offended anyone, so i hope whats left of the sensor just stays out of the way.
Anyway, where is the drain plug and top up bolt on these, it got dark by the time i'd finished mangleing everything up.
Stu @ M Developments
41
21-08-2015 06:47 AM
Archiejay
12-08-2015 12:07 PM
sridgett
15
03-08-2015 07:26 PM
