- Cosworth Rear Hub & Carriers
- Stupid question about disassemling MT75
- Poor Thing
- 4x4 Rear Brake Calipers help needed
- How is fitted the whale tail in a 3dr Cosworth?
- Black 3-Door D940 TWC
- Sapphire cosworth 4x4 spring seats/mounts??
- 2wd fuel pump help
- Revolution Milleniums?
- Sierra cosworth carbon airbox lid or rs500 box??
- Gearbox, diff and transfer box oils
- lambda sensor engine loom socket
- T34 thread size on bleed off
- GT28 Series
- T5 Gearbox Rebuild
- Those carpeted trim thingys that cover the seat subframe...
- No coolant circulating?
- rose joints for rear arb
- long stud kit help!!!!
- Saph rough running
- Cossie owners with a straight through exhaust
- Cossie won't start :(
- Amal valve question
- Wanted L8 / P8 ECU
- Spec- R Dump Valve
- Steering rack yoke plug
- 3dr engine bay decals.
- Rear quarter window rubbers
- quick question
- mk motorsport adjustable beam........
- Saff rear brake pads...
- reyland ap brake kit for standard wheels
- ARB Clamps
- Cossie problems
- Sapphire Cosworth and blue smoke
- 4x4 wing badge placement
- Was this made for a Sierra and if so what part / model?
- Thinking of changing my interior 🤔
- strut tops
- Mot time for the Cossie
- Difference between 2wd and 4x4 throttle body
- Saff cossie 4x4 wont start
- Sierra 1amp diode .... help :(
- Abs sensors
- magnecor r100 and misfire
- Gt3071r cosworth ''during assembly''
- Inter cooler to rad fittings
- optimal running temperature
- Saff cossie metal fuel lines/pipes
- Decent quality poly bushes in black ?
- How much power??
- Clutch for Sierra sapphire
- det/knock sensor
- All my electrics are going nuts
- 3DR throttle cable ball end question
- 4x4 MT75 for mid engine installation
- Water temperature reading high
- pictures
- Must sort the rust out this year!
- Solid beam mounts Saph
- Additional water temp sensor. Where? Saph
- Post pics of your white Saphs
- Prosport gauges any good?
- What spark plugs? 380bhp Saph
- what bhp
- Is a Sierra 2.0 injection fuel tank same as cosworth fuel tank?
- Window rubber question
- Decent Headlight bulbs... Who uses what?
- reaction time,good game :-)
- Gasket sets
- Ford Sierra Cosworth 3 Door - Fuel Tank Refurb - HELP! Correct Fuel Sender Location?!
- plug gaps
- cosworth injectors
- ABS light
- rear mount rad
- sapphire cos 4x4 springs help
- Total Quartz Racing 10W50 Fully Synth
- 097 flat terminal battery
- 3dr colour vin?
- how much are new genuine 3 bar map sensors going for these days ?
- YB slow oil drain
- Hydraulic clutch question
- Seirra rs zender bumper
- Group-A dump valve
- cossie head ache
- Quick Release Steering Wheel
- Cooling system flush
- Sierra sapphire cosworth fuel sender weird problem
- Oil Pressure question on a YB Cosworth
- Ignition Amps breaking down?
- Fuel pump question
- Happy Days
- Max boost-bhp T36 Siemens 55's
- T34 Compressor Housing Union
- air filter size / types
- Cosworth subframe bolt sizes
- compression ratio
- RS 500 block
- Cosworth wheel offset
- Cosworth Spec... What's the Next Step
- Fuel pump rewire
- frequency limiter
- coilover helper springs
- D66NKN
- MSD wasted spark fitting instructions
- Best suspension for 4x4 sapphire
- Motorsport developments engine loom for 4x4 Sierra cosworth
- Best place for reconditioning a Cossy rack ?
- 2wd Cosworth Misfire
- 3 Dr loom clips
- Cosworth bad sound
- 3dr parcel shelf
- engine decals
- Saph 4x4 engine throws out a large amount of oil
- Cosworth Not Starting...
- Best Spark Plugs for 4x4 sapphire
- Xr4x4 and saph shell
- fuel rail
- camshafts
- 3dr engine/gearbox mounts?
- D739 CBD - Does Anyone Know It?
- 3dr abs sensor removal
- genuine fog light grilles
- Which Chip fin my L8
- Issue no.3 Pectel board
- Bumper trim strip and Fog light surround colours
- Head bolt torque settings?
- ABS Pump
- Crystal blue saph waiting for an alternator
- ahmed bayjoo rear springs
- AP 6 pots on a sapph, wheels?
- Sapphire trailing arms
- 4x4 cosworth engine
- Rear view mirror size
- 3 door engine bay ?
- Dump Valve Advise
- 2wd propshafts info reqd
- Best springs to use on konis with 18's
- Cosworth 3 door with a 4x4 rear anti roll bar
- Lambda problem
- Steering rack replacement
- 3 door cosworth solid rear beam bushes
- Cosowrth 2WD compression test
- Cosworth ecu
- Headlight Help
- 2wd cosworth drive shafts issue
- Front diff gone or shafts? 4x4 saph
- Rear light cluster repair plug
- Front wheel bearing caps
- Splitter options sapphire??
- 3dr cosworth heated windcreen?
- Revolution millenium alloys
- Free extra BHP
- 3 door wheel colour
- Cambelt tension tool.
- Ford Sierra / Sapphire factory sunroof resto?
- 3 door rear seats
- Selling up again
- Engine Bay Powder Coating
- battery tray
- XR4I dashboard electrical issues
- Rear doors not centrally locking
- 88 Sierra XR4x4 dash speaker replacement help
- Problem with door locks bouncing...
- Should I go to a stage 2?
- 18inch wheels on saff with konis
- 2.0 pinto rotar arm question
- Borgwarner T5 to electronic speed sensor?
- **sierra rear lights PROBLEM ??
- Sapphire Morettes
- Sapphire Cosworth 3 door 4wd original????
- 4x4 Mt75 gearbox with v6 Type 9 setup
- Wanted 3 door sierra rear belts
- 3 door rear seat belts
- whats this plug off?
- Chip ID help
- spoiler rs 500
- A couple pics from New Years Day
- 3 Door Outer Door Rubbers
- Cosworth flywheel 4x4-2wd
- Crunching gears
- Sapphire out for last day of the year
- Rear beam anti-squat
- parts
- Autospecialists power steering hose
- Broken suspension spring
- real or fake
- 2.9 V6 4x4 Low idle while rolling to a stop. Standstill fine. Also over cooling.
- cosworth stage 3 intercooler
- F606 CGO anyone know it?
- 2wd water temp gauge not working
- Fuel cut out.
- looking to get 60mill springs for my sierra ?
- ET15 17" on a 3dr help plz???
- degree camshaft in cosworth engine
- has anyone got 225/40/18 on their saffs
- oil pressure switch
- Sierra sapphire cosworth 2wd rear diff partial strip down,how to remove stubs??
- Tyre size 18x8 Et35 on sapphire 4wd
- Abs or not
- Any remember this sierra sapphire?
- crack in 4x4 head .what reason ???
- how do ya make a 2.0 pinto a 2.0 pinto efi
- Carcoon & 3DR
- dashboard installation
- For sale original cosworth rs alloys
- Paint or stonechip?
- new turbo from precision ?
- Cosworth 4x4 rear brakes onto XR4x4
- Cheap way to fit 4x4 plenum to 2wd inlet manifold
- Front fogs
- 2wd rear drive shafts
- Help a Yank out! adjustable tcas/compression strut
- Sapphire underside resto,what products to use??
- Removing rear bumper brackets
- Original front spoiler / bumper brackets photo
- How to remove rubber spoiler extension
- Differences 4x4 and RWD Boot lid
- Ford Sierra heater box
- 4x4 cosworth Hydraulic clutch
- Cosworth s/steel turbo damper with all fittings for sale
- Cosworth alloy swirl pot mint,for sale
- Rev counter not working
- L8 ecu wanted ASAP!!!
- **1.6 PINTO to a 2.0 twincam efi ??**
- efr7064
- Saff cossie lambda wiring
- Heater stopped working
- recast cyllinder head anyone tryied ?
- my sierra so far
- camshaft worn?
- wiring plug
- Are all heater/blower covers the same
- F444 ERJ F444ERJ 2WD Sierra Cosworth
- conection behind clocks ???
- How much pay for used gaz gold
- cosworth gasket set
- ReShelled Cosworth Opinions?
- any1 have any ideas how to put a sierra bumper on that has broken brackets
- Castor angle
- will a scorpio diff fit a 92 sierra ??
- is there a relay for the front lights in a sierra ?
- Headlight problem
- abs pump refurb
- 3 door front towing eye.
- bailey breather system
- Sierra 4x4 kit lowering springs..
- Plates for blanking off ABS sensors on a cossie hub?
- stage 3 sapphire cosworth midrange flat spots.
- having electrical problems with my sierra
