Is a Sierra 2.0 injection fuel tank same as cosworth fuel tank?
cossie fan (unluckerly)
The original cosworth tank has a large plastic swirl pot set up inside it. I'd be carful fitting other tanks as I did and ended up with massive surge issues but mine was modded a fair bit
Thanks.
I've currently got a pattern part fitted with internal fuel pot (metal) but still had surge when running under 1/3 of a tank on track so was wondering if the 2.0 inj tank was the same as the cosworth original with the better plastic swirl pot.
I never had a single surge issue with the original tank at 500bhp. I got a pattern one with a metal swirl pot had it converted to aero fittings put it in the car when I changed my fuel lines and it surged like fuck. Had to fit a swirl pot and second pump
cossie09
11
26-03-2016 06:32 PM
Will Pedley Racing
13-03-2016 10:09 PM
