Sapphire trailing arms
According to the Powerflex website, the Cosworth inner and outer bush part numbers are the same as the non-Cosworth which kind of got me thinking..!!!
TT
Thanks guy's. So, other than a possible ARB issue the trailing arms themselves should be identical to those of, say a 2ltr etc??
TT
The arms are not the same as on a standard Sierra.
- The pickup points for the arb are most of the time not present on a standard Sierra.
- Arms for cars with drum brakes are different than disc brakes. Arms for drum brakes have a too small hole for the driveshaft and won't have a location for the ABS sensor either
- The angle for the plate for the hub is at different angles to give different camber settings depending on model/ride height.
- As said, the bushes for the Cosworth are spherical bearings but the fitment of the bushes is the same for all arms
I believe 2wd sapph Cosworth arms are the same as 4x4 Cosworth arms, but 3dr arms are different.
zetaboostboy522bhp
12-02-2017 10:00 AM
155lee
25-02-2016 09:02 PM
