View Full Version : Escort Range
- 1976 MK2 Kent - Cosworth Conversion
- Mk4 Xr3i fuel gauge sender
- Idle issue with my 87 XR3i
- XR3i fuel pump cutting out 1988 MFI
- Mk3 Escort 1.6 CVH VV Carb
- St170 into mk4 xr3i
- Escort cabriolet mk5 interior roof light
- ABS MK4?
- MK4 XR3I EFI Throttle Cable Part no?
- Ford escort Mk6 clutch pedal return spring
- looking for oil spray nozzle for zetec 1.8 16v 105ps
- Mark 5 XR3i brake master rebuild issue
- Mk3 escort front panel
- Mk5 XR31 master Cylinder Connections
- Mk4 xr3i rad fan housing required
- cosworth oilpump
- TPS sensor problem
- New build
- Escort mk6 st170 rear brakes
- MK3 1.6 MFi <=> MK4 1.6 carb
- Decal kits and radiator wanted
- Mk3 Escort 1.6i cabriolet fuel entering oil
- Ib5 gearbox into mk4 escort
- XR3I EFI Aftermarket ECU
- Mk4 estate inner sills
- Differences between early and late Escort mk3 (pre&post 1983)
- 1990 MK4 1.6 EFI CVH Dipstick tube
- Xr3i efi return of rough running
- help please , willing to pay
- turn over no fire
- Adjustable Wiper Stalk
- MK4 Xr3i Convertible rear badge Location
- Escort mk6 zetec fuel pipe removal
- XR2 Manifold compatibility with 1.6 carb CVH Orion
- Mk3 Escort door/window seals door
- Mk6 Cab Motor
- MK4 Escort EFI ECC IV system.
- XR3I EFI N/A to Turbocharing.
- intermittent wipers Mk4
- EFI XR3I Air Filter
- Convertible leaking
- Engine was overheating
- Aftermarket Header Tank
- Efi xr3i rough running
- Need part number for 4sp xr3 gearbox
- Picture of Fusebox XR3I EFI
- Any ideas?
- Indicator Relay
- Ford Escort XR3i Air Filter
- MK4 1,3CL - Conversion to 1,8 zetec
- Ford escort mk7 rs2000
- Ford escort rs 2000 mk7 conversion
- Mk2 Escort, Cossie Build, Advice Needed
- Anybody any idea what this is?
- MK4 EFI no power
- What gearbox do I have?
- Mk4 XR3i Throttle Body Sensor
- Mk2 Escort 1600 Sport
- Desperate help needed immobiliser problems
- Throttle Position Sensor 6854781 - 91XF9B989BA
- Importers for mk2 escorts?
- Picked up an escort zetec, couple of questions . tps
- xr3i / rs turbo rear decal sizing?
- Rsturbo
- Escort rs turbo fuel trip computer
- Fuel trip computer
- Mk2 Escort with 12 digit vin number
- XR3I Engine upgrade
- Aftermarket ECU/Tuning options for CVH 1.6 & 1.9L?
- CVH High Compression Build
- Escort mk3 1.6 XR3I brake callipers
- HELP! MK3 Mondeo Steering Lock Won't Come off
- Escort RS 1600i engine for sale
- Help regarding vin
- MK4 Escort Estate suspension?!
- 1997 ford escort 1.8 16v zetec fuelpump problem
- MK1 Escort suspension, brakes, LSD upgrade help
- H289 TWE New owner XR3I Mk4 90 Spec.
- Escort Mk3 Xr3
- Mk3 Escort LX (Brazilian built)
- Alternator XR3i - Genuine or non genuine part?
- Mk4 RS turbo rear bumper splitter
- Mk4 EFI speedometer.
- mk4 xr3i bushes
- 90spec xr3i seats
- Escort Cab AllBlue SE500
- 1.6 CVH Camshaft Help Please.....
- Stuck Camshaft and Lifters PLEASE HELP!!
- Solid Lifter/Tappet Adjustment
- 1.6-1.9 CVH Performance Suggestions and Advice
- Mk6 RS2000 jacking cover
- Xr3i cutting out
- 1997 Mk6 1800 Escort Cabriolet - intermittent revving
- quick question
- 90s spec xr3i
- Mk4 xr3i mfi bad running
- Mk4 xr3i center console
- Mk4 xr3i interior
- Barn Find MK3 XR3i-But Vin doesnt exist???
- Mk4 escort xr3i efi fuel pump
- Call for help from a Frenchman
- English axle specs for build.
- xr3i cranckase breather adaptor
- Wanted escort mk2 parts
- Escort mk4 xr3i
- underpowered 1.8d van
- Escort 75 Van
- rs 1600i front roll-bar clamps
- Master cylinder help
- mk3 escort need help
- Sunroof tray
- Escort Ghia Decals
- Help with XR3I convertable
- Clicking Clutch quadrant
- Wiper motor query
- MK4 escort steering lock
- FORD ORION MK2 amplifier
- Mk2 RS2000 or Mexico log book
- Ford Orion aerial
- Mk3 escort rs1600i cassette holder
- Wheel arch liners?? 1987 xr31
- Mk4 moredoor LHD. Drivers side door power lock not actually locking door?
- St170 head on the 1.8?
- K20 Mk4
- Xr3i MFI and RS turbo MFI fuel metering unit
- Looking for MK2 RS 2000
- MK3 XR3i INJECTION PROBLEMS
- rear windows
- mk 1 escort
- Mk4 XR3I fiesta st conversion
- escort gti 98'
- Escort Mk4
- Fitting ellectric windows
- Watts link vs mumford link
- 1982 Escort 1.3 "L" our families first car.
- cvh twin 40's dcoe throttle linkage
- Mk2 orion power expectation
- Mk4 escort head unit wiring advice
- Light loom connector location
- Mk3 tailgate
- 1988. Xr3i mfi bad cold start and misfire
- Escort Maxi Kit car
- MK2 RS2000 ready for the road.
- 5th gear gone
- ZVH na, BHP potential?
- 1.8 Zetec injector flow
- MK3 dash clocks
- sound proofing pads mk2
- MFI running issues again and again and again!!
- Mk4 escort indicator not working
- Can a 1.6 SportKa engine fit a mk5 Escort?
- Mk2 rs2000 starter motor wiring
- MY 1983 MK3 Escort XR3I
- Rev counter bouncing (Escort MK3)
- Strange electrical fault help
- Deleting breather hose. Ok?
- Escort Mk3/4 rear suspension
- Cabriolet roof tension?
- Escort Van MK6 Steering Wheel Swap
- Rear lights problem. Possible ground issue??
- XR3i MFi to Mondeo 2.0 Blacktop
- Side lights won't turn off
- Starter motor engaging issue
- Fuel metering unit colour change
- abs confusion
- 2002 mk6 escort 1.8D ex royal mail van Need help Asap Please!
- RS1600i parts...
- MK4 escort more door !
- Mk4 xr3i speedo
- Please help..Need correct clutch diameter XR3i 1.8
- Camshaft change (standard or not?)
- Mk1 escort Mexico November 1970 built help!
- Rs2000 engine into mk4
- whats this part for and whats should its resistor
- Fuel metering unit cap missing?
- No dash lights?
- 1.8d to 1.6 cvh conversion help
- Suitable replacement relay??
- Escort van steering lock
- Help! Mk4 Escort soaking wet headlining
- mk6 escort 1.8 130 spec idling rough
- Buying MK2 RS 2000
- Removed scorpion exhaust and back to standard.Car now running like a pig.
- Xr3i cutting out
- No gear shift on a mk5 XR3i this morning.
- K&N fitted flip side up...Problems..
- PCV Valve.? Can anyone tell me where it is.?
- carello 640 spotlight
- Would a RS turbo exhaust fit on a XR3i cabriolet
- Aaarrgghh.... This starting/running XR3i MFi k-Jetronic doing my nut in
- ignition coil supressor whats it job how to test
- mk4 escort xr3i what does the ignition module do's
- Fuel pump relay problems Help xr3i cabby
- Need help identifying sensors EFI 1.8 XR3i
- Mk4 Escort (battery/alternator?) help needed!
- steel wheels on mk3 4door upgrade
- Mk3 1.3 cvh- wanting to convert to zvh on carbs
- Trying to Fit a 38dgas on a 1.6cvh, is it possible?
- Anyone know where RS1600i UAN777Y is?
- Xr3i starting problem (ish)
- Mk3 1600 cvh
- Escort cab roof not closing properly
- Help to authenticate my pintos heritage!
- mk2 escort 4 link boxes
- '94 RS2K front foglight removal
- Help needed urgently (greater Manchester)
- What would you do? New cylinder head? Escort Mk4 XR3i MFI
- New Xr3i cab
- MK4 XR3i gearbox problem
- XR3i EFi Starting problem
- Help with k jetronic fuel distributor/or injectors
- Exhaust Manifild 2" Heat Wrap
- Mk4 escort van rear inner arch repair
- Running like crap! timing issue??
- 1996 Escort 1.6 16v overheating
- Mk4 xr3i starter motor change
- '94 RS2000 ST170 brake upgrade
- Problems starting and running ruff!
- Need an engine change - anyone want a weekends wages?
- ecu wanted
- Head lining
- Escort Estate
- 1986 cabriolet
- 1.8 diesel fuel lines diagram
- MK3 XR3i Rear spoiler
- Mk4 Cabriolet bent roof bars
- Mk5 escort
- Mk5 ignition fault.
- Brakes are locking on
- urgant help needed :(
- Green Stuf Pads V Ferodo/Mintex ?
- escort van heater pipes?
- Help! mk4 xr3i Megajolt or nodiz pro?
- Escort mk3 1.6, will ford Puma fit and if so, what are the benefits?
- weird electrical problem need help
- ford escort van 2001 mk 6 battery light on power steering failure
- Ford Escort 1985 mk3 cvh fusebox
- st170 conversion
- 1988 1.4 carb 3d Escort rear wheel bearings
- Hi new to forum ....wanted wanted urgent
- found a mk3 escort. whats it worth
- ESC wiring
- new guy in need of help
- clutch
- mk4 eccy gearbox
- which exhaust manifold for a zetec
- xr3i cab short clutch
- "EEC4 Supercip Flash Module"
- escort mk4 anti roll bar
