Escort Range Ford Escort RS1600i / Mk. 5 & 6 / XR3 Discussion.
mk6 escort 1.8 130 spec idling rough
Old Jan 8, 2016 | 05:23 PM
Antony Mann's Avatar
Antony Mann
Default mk6 escort 1.8 130 spec idling rough
ok so I have a mk6 escort was a 1.6 but that broke so I replaced it with a 1.8 130 spec cabbie engine , was working fine no issues for ages then one day the starter motor just stopped working, got a new one and to swap it over I removed the alloy efi inlet manifold that is right above the starter motor , any way sorted it and all was fine but it now seems to be idling weird at first it was dropping and cutting out , then it would bounce on 1000 revs and then it would sit just under and be fine but then when I slowed down and changed gears it would go up and stick on 2000 revs until I came to a stop then it would go back down to 1000, I resealed the gasket on the inlet manifold I did the same to the throttle body I cleaned the throttle up and I cleaned the idle valve as it was dirty inside I checked the pipe from the throttle to the air box, not sure what to check next like I said it was fine until I took the inlet off
eddyj
Dec 31, 2015 05:52 PM
M K
Dec 4, 2015 02:32 PM
massivewangers
Nov 26, 2015 09:57 AM
392B.H.P.SAFF
Nov 25, 2015 07:19 PM
PaTeRa
Nov 22, 2015 10:02 AM
