Escort Range Ford Escort RS1600i / Mk. 5 & 6 / XR3 Discussion.
1996 Escort 1.6 16v overheating
Old Jun 19, 2015 | 08:27 PM
endskyro's Avatar
endskyro
Are we there yet?
Default 1996 Escort 1.6 16v overheating
Hi!
Lengthy post coming up
I'm the owner of a 1996 Escort 1.6 16v,LHD (I'm Romanian) and the car is acting up.Bottom rad hose blew and it seems the cause is the radiator fan not kicking in.The fan seems to be on a dual speed setup (the car has AC which doesn't seem to work,I don't really care about that it's just that from what I've read the AC should turn the rad fan on regardless of temp.It doesn't.).First checked the resistor found on the fan housing,it says 0.23 ohm on it however my DMM reads 18.5 K ohm so the resistor is probably gone.Replaced the resistor with a thick piece of wire,still no low speed,or any speed for that matter.Then I moved on to the 4 contact thermo-switch I found in the upper rad hose.One wire is live(12V) and when I connect that to another wire in the opposite(diagonal) part of the connector,the fan comes on with what seems to be High speed(it still works if I take off that wire I used in place of the fan Low-speed resistor).I think this triggers the green relay just behind the battery as I connect those 2 wires from the thermo switch loom.The other 2 wires I guess should be the Low speed part,there's no live on any of those 2 and when I used the live from the high speed on the remaining wire the fan still didn't work.For now I'm left with manually controlling the fan via a switch wired to the thermo-contact thing in the upper rad hose,high speed.
BTW:30A fuse in port 22 of in-car fuse box checks out fine.The thermo switch seems to be the cause of my fan problems so far,apart from the low-speed circuit.Is there a separate relay/circuit for that?I'd like to sort out the wiring/relay and whatnot before replacing the thermo-switch and resistor.
Sorry for the lengthy post,hope I got it all covered
Old Jun 21, 2015 | 07:15 AM
endskyro's Avatar
endskyro
Are we there yet?
In other(fewer) words,is there anyone that has the MK7 workshop manual or a clue about the Low-speed radiator fan electrical circuit?
Old Jun 22, 2015 | 10:28 PM
KW-rscos's Avatar
KW-rscos
I have a Haynes manual, when I get chance I will take a photo of the wiring diagram and add it on here for you.
Old Aug 5, 2015 | 03:38 PM
endskyro's Avatar
endskyro
Are we there yet?
Still on manual control here
Old Aug 8, 2015 | 12:11 AM
werdas's Avatar
werdas
use torent
just search for ford escort pdf
or use autodata or something for that
I thint that thermo switch is broken and that is main problem
ther is no low and high speed there are two fans...one is for car and other is when air con work
Old Aug 8, 2015 | 08:27 AM
endskyro's Avatar
endskyro
Are we there yet?
My car only has one fan and a resistor in series that was used for low-speed.The thermo switch is gone,I already know that.I need the wiring diagram so I can figure out how low-speed works.
Old Aug 8, 2015 | 11:26 AM
werdas's Avatar
werdas
there is no low speed just one speed and it work only if temperature is high or if its air con on
if you know that thermo switch is broken why dont you change it and everthing will be ok
its around 10euro cost...
http://ford.sklep.pl/product-pol-149...d-1034763.html
this is for outside temp. so you cant turn on air con when is low temperature outside
http://ford.sklep.pl/product-pol-180...-8B607-AB.html
80+9zolts
i think that is 20 Euros my bad
tonicosworth
Ford Escort RS Cosworth
Oct 31, 2015 08:40 AM
Dr. Ickxs
Sep 15, 2015 10:15 PM
imnoteasy
Sep 7, 2015 09:26 PM
Ade
Alloy wheels and ICE for sale
Sep 7, 2015 05:06 PM
Bighandsuk
Sep 2, 2015 05:23 PM
