Escort Range Ford Escort RS1600i / Mk. 5 & 6 / XR3 Discussion.
Escort Estate
Old May 17, 2015 | 12:57 PM
Kyle Langford's Avatar
Kyle Langford
Default Escort Estate
ls there or any compatible lowering springs on the rear that will drop it nicely and not to a stupid -mm?
thank you very much.
Old May 17, 2015 | 02:38 PM
3i Jim's Avatar
3i Jim
10 Year Member
I believe the suspension is the same as a hatch. A 35 or 40mm lowering kit for an xr3i or rs turbo should do the job. I presume it's a mk4.
Old May 17, 2015 | 03:50 PM
Vacuman's Avatar
Vacuman
If you mean Mk5/6 then the springs are different. I've recently bought a full set of -30m lowered springs but not sure I will fit them as my GTi estate sits low already and the speed bumps around here are lethal.
Old May 17, 2015 | 04:06 PM
STeve's Avatar
Super Moderator
what mk is your escort as stan above is spot on as regards mk5/6
Old May 18, 2015 | 08:38 AM
turbo m's Avatar
turbo m
I had H&R progressive rate springs on my 94 mk5 estate a loverley ride.
Was quite low but looked good..
Took 6 weeks to arrive from germany but worth the wait...
Old May 21, 2015 | 04:31 PM
Kyle Langford
Hi yeah sorry i didn't make it clear, yes its a mk6.
I got told and seen on a forum that corsa b springs fit? cheers
Old May 21, 2015 | 08:42 PM
STeve's Avatar
Super Moderator
even if they did fit the load on them would be wrong due to the escorts weight, my advice is get correct springs or leave it alone
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
Dr. Ickxs
Sep 15, 2015 10:15 PM
bassboy
Sep 10, 2015 08:54 PM
sunburstred
Sep 9, 2015 11:24 PM
imnoteasy
Sep 7, 2015 09:26 PM
