ignition coil supressor whats it job how to test
What is the supressors job and how do you test?
I have uploaded photo of the part
There is 12 volts going into the suppressor from the green/red wire coming from - coil.
After suppressor out wire to speed sensor module/fuel pump relay there is only 0.29 ish volts coming from green/red
The coil green/red goes to suppresspr then from there to the speed sensor module then the fuel relay safety module then to the rpm rev counter, as my rev counter not working either....?
And the fuel pump relay aka safety module senses ignition pulses, and cuts the fuel supply if the ignition pulses stop
So where does it pick up ignition pulses.... anyone??
