Escort Range Ford Escort RS1600i / Mk. 5 & 6 / XR3 Discussion.
Need help identifying sensors EFI 1.8 XR3i
Old Nov 9, 2015 | 01:39 PM
morg65's Avatar
morg65
Default Need help identifying sensors EFI 1.8 XR3i
Hi all,
Seems my XR is over fueling and causing her to hesitate when accelerating.
Local mechanic reckons I need to change my engine management temperature sensor.Is this another name for the coolant temperature sensor.? And if so where would I find it.?
In fact does anyone know what sensors are doing what.? I would love to find a list of each sensor and a map as to where they are located.?
I have no clue about EFI.
Thanks a mill.
Morg
Old Nov 11, 2015 | 06:00 PM
werdas's Avatar
werdas
just simply disconecct lambda sensor and try drive without that...
or try same thing with coolant senor witch is under pipe that conecct thermostat housing and radiator
right one one picture
Old Nov 13, 2015 | 10:25 AM
morg65's Avatar
morg65
Thanks for the reply.
i understood the coolant sensor is the one that sits downwards into the thermostat housing close to the coil pack.? has a size 25 spanner fitting and is clearly visible once you pull the bonnet..
Is there two.? Is the one in your photo not the cooling fan switch.?
Old Nov 13, 2015 | 02:09 PM
werdas's Avatar
werdas
uh yes im sorry
You are right...on pipe is fan switch
under thermostat housing there is sensor (I think that one for dash) indicator)
but on top od thermostat housing is sensor (for ECU)
Im not shore witcih is witch now but if you dissconecct one and indicator on dashboard fell down other one is for ecu
ther is also IAT sensor for intake air temperature and that one is on rear of intake
http://www.rsrich.force9.co.uk/zetec...260007_JPG.jpg
where is big hole on picture
jay030787
Nov 21, 2015 02:00 PM
sidewaysdave
Fiesta ST
Nov 17, 2015 05:22 PM
bodace5
16
Nov 10, 2015 05:24 PM
henrydickens
Ford Fiesta
Nov 4, 2015 05:41 PM
