Escort Range Ford Escort RS1600i / Mk. 5 & 6 / XR3 Discussion.
Mk4 xr3i starter motor change
Old Jun 17, 2015 | 06:51 AM
Shaunc's Avatar
Shaunc
Default Mk4 xr3i starter motor change
Hi
Just recently solved a cold start problem I have been having on my recently bought xr3i and now I've been taking it for a run I have noticed it is a bit lumpy when starting it hot. I reckon this is the typical starter motor problem with the starter being so close to the exhaust, so I think its just best to change it for a shiny new one with a heat shield.
Now the question is would I be best to replace it with an xr3i one or a diesel one from a newer model?
I have been told a starter off a transit connect is a straight fit and it better at coping with heat and I've read that an escort mk5 mk5 diesel is also a straight swap and is faster at spinning or something along those lines..... However I have just read a thread where someone has used a focus zetec one and it fried itself after being stuck on for too long so as u can imagine I don't want to make that expensive mistake! Especially as I will be buying a brand new one!
Any help is much appreciated!
Old Jun 17, 2015 | 07:29 AM
haz87's Avatar
haz87
Starter motors don't cause "lumpiness"
Old Jun 17, 2015 | 08:38 AM
Shaunc's Avatar
Shaunc
Maybe lumpiness isn't the best way to describe it, its just reluctant to start when hot. Its almost the same problem I had when cold starting but that turned out to be a vacuum leak.
Old Jun 18, 2015 | 07:00 AM
Shaunc's Avatar
Shaunc
Also been reading a thread on here about this problem and it could be the fuel pump. What does anyone suggest I try first? Pump or starter?
marky_g
Sep 12, 2015 04:26 PM
morg65
Escort MK 5 / MK 6
17
Sep 11, 2015 08:40 PM
bassboy
Sep 10, 2015 08:54 PM
imnoteasy
Sep 7, 2015 09:26 PM
chris m1
Sep 7, 2015 08:02 PM
