Escort Range Ford Escort RS1600i / Mk. 5 & 6 / XR3 Discussion.
xr3i cab short clutch
Old Oct 13, 2014 | 07:32 PM
Robbo2g's Avatar
Robbo2g
Default xr3i cab short clutch
Hi
the pedal releases within the first inch or less (too short). The car had a new pawl fitted 30k ago and there is no cable slack, when the pedal is pressed the gearbox lever (spline type) moves right away and the lever/thrust bearing is in close contact with the pressure plate, I know this because when the cable is disconnected the lever sits in about the same position before the thrust bearing comes into contact with the pressure plate.
Car due for drive shaft oil seals soon so want to know what to do, if box is to come out then now's the time to know.
cheers
mike
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
stephenb4506
33
Oct 2, 2015 06:25 PM
