- 4x4 sump,how do you remove it
- Buying a T34 Turbo-Which exhaust housing is best?
- Specialist in the North West?
- Boot not locking properly
- RS500 value??
- Anyone Own G952 WBK or know of it?
- RS500 Cylinder head on 4x4 block
- elec windows not working
- INTERIOR LIGHT DALAY NOT WORKING
- anti roll bars
- Nightmare !!!!!
- live mapping
- What size speakers are in the front of a Saff??
- red cossie
- is 21psi safe thru a 2wd intercooler???
- What power/torque do you have for how many psi?
- T3 oil-return thread size
- saff cos an rs7s
- Engine Parts Finally Returned (Pics) UPDATED 09-10-05
- moonstone 3dr wheels???
- Gearbox 4x4 question
- Want to remove dump valve...what to use to blank pipe?
- what sort of 3DR for £5500
- solid disk brakes from escort to sieerra cossie
- 3dr springs
- help with loom
- improve traction
- white dials
- Boost problem
- ECU L8 question??
- cologne tuning
- 500 style front splitter
- Lowering Springs
- Rear lightbulb holders for sierra??
- Anyone thats replaced their exhaust?
- Tools needed to remove steering wheel hub on Sapphire
- Ford part numbers needed
- heat trancefer grease for ignition amps
- Quarter mile performance by Cossies
- stuck on 3000rpm??? would'nt go down!!! help!
- How do u make a cossie better on fuel
- dump valve removal question
- engine on sapphire 4x4 runing on after turning off
- Exhaust Valves
- abs light come on pls help
- Group a fuel pump part number??
- Heated front windscreen relay ?
- Anyone on here Hydraulic'd their Clutch?
- its time for a new headgasket! what parts do i need?
- actuators
- How much boost for stage 3?
- Wastegate Actuator
- sapp chip?
- 17" RS 7-spokes on a 3dr???
- How long do u get....
- this mornings problems:(
- Wots the difference between.......
- 4wd to 2wd....
- I need a new clutch, which one???
- cossie group a coil
- ssshh valve
- 4x4 box
- Sierra speakers.....
- 4x4 lowering?????????
- i got denso's!
- T34
- silly question what paint to use?
- saph cos owners help please
- 4x4 v 2WD exhaust manifold
- Cosworth T34 Turbo fitting
- 2ltr gls i saph info please
- correct badge style
- air filter
- 2wd Sapphire buying advise
- Is this a good spec and what power should it be good for?
- Stage 3'ing my baby
- Dads 3dr Cosworth
- 4x4 saff ECU
- black soot/smoke?
- Big Winged Sump, Baffles and gates
- Need A Bit Of Advice
- boost dropping..
- Fuel pressure on CVH sierra? ? ?
- the thing in the dizzy
- engine rebuild to run light blues
- 3dr cossie owners
- standard dump valve
- What Oil in a cosworth
- Whats needed to fit 18's on a saff
- Sierra Cossie Spotted -I was filming ya-anyone on here!?
- water leak help needed
- Rear ARB 2wd sapphire. Dog bone trouble Grrr!!!
- Cossie not as good ticking over since......
- saph cos loom / esc cos loom
- 4x4 not starting and cutting out
- cam timing
- Flow rate for standard Cossie pump?
- Camshaft bearing cap
- what size tyre and rad fan trouble!!
- how many pots?
- buying advice please
- PSI to Compression Ratio
- buying a cossy
- front driveshaft removal
- Which plug ! C57 - C59 - 071 ????????? or other .......
- sierra cosworth query
- ENGINE OUT- 4x4 cos ?!?
- 360 deg thrust
- cossie head
- Brake biasvalve (rear), same as "brake line lock"?
- 3Dr Cossie speedo?
- What is it worth
- some help from the cossie boys please,,,
- Rad pipe fitting, correct?
- 4x4 oil pump
- Idle Speed Screw - 1988 Sapphire
- anybody knows fuel pump code?
- Different diffs!
- Low Washer Fluid Level Light..
- THUNDERSALOON BODYKIT
- moonstone grey cossies
- EXHAUST CENTRE SECTION KEEPS CATCHING!!!
- dunlop d40
- QUICK QUESTION
- RS500/Rouse front splitter
- pls help
- Saph 2wd buying
- Strange elecy prob help me!!!!!!!!!!!
- slick 50?
- 3dr map sensor bracket
- what to do
- sierra 4x4 driveshaft question!
- Running on 3 cyldner's when ticking over Help?
- sagging front bumper
- How many Rouse sport cosworths left?
- Cossie 2wd/4wd Exhaust Differences?
- BEST SPARK PLUGS FOR STG 1 4X4 SAFF???????
- Wot stage is my cossie??
- need assitance
- had a prob today:(
- Sapphire 4x4 Buying..
- 2wdsapphire chassis mods, ARB`s bottom arms from ESCOS??
- Windscreen removal
- cooling fans??
- Max BHP???
- rear bumper removal from an XR4x4
- How much boost?
- 3 door wide arch kits
- RS500 drop braket
- everyday cossie
- 2.9 V6 info plz...
- I Want Chatter..
- why is it
- whats after stage 3
- coolent renewel
- Question chips stage 1.
- central locking
- 2wd saff cos springs
- Quickie.... 2wd saffcos
- Which tyres ????
- tyres,
- fuel gauge not working..
- help needed
- changing head gasket on my 4x4 saffy,how hard
- Sierra Sapphire RS Cosworth 4x4 Display at National Day
- Someone with compomotive cxn 17" in here?? pictures??
- How many 3dr Cossie's left??????
- valve guides
- 2wd Sapphire display at Donnington.....last chance
- lower ball joint boot
- 2WD COSWORH TOO HOT ! ?
- North West RS Day anyone ?
- Compression ratio for 500bhp
- hi
- smokey joe??
- ford Sierra ghia need info...
- 4x4 drivetrain vibration
- clifford smart windows 4
- engine gasket 4x4 head
- which lowering springs?
- oil consumption help ???????????
- 3dr Part No's
- binding brakes!!!!
- dimensions for wheel fitting
- Wanted, 2 door cosworth dash board
- fan problem on a 4x4 cozzie 330
- strange engine behaviour, any ideas?
- TAPPETS
- 17" x 7.5" rims on Saff - What tyre size?
- Refence map sensor 2wd ?
- wanted 3dr parts
- 4x4 cosy runing lean - any ideas?
- 4x4 oil pan leak? ?
- tyres rubbing
- Which brake conversion for a saph????
- 3dr price??
- Best S/S Exhaust for a 3dr Cossie?
- boot badges
- link to some pics of my car and new bits and pieces! UPDATED
- LSD or not?
- Breather claeaning help (2wd cos)
- Rear trailing arm rose joint fitting?
- What radio
- full beam stork
- Backfireing and cutting out
- what plugs?
- phase sensor,plug gapping and tale of woe.
- Texaco Decals
- 2wd black saph cossie
- can you still buy new cyclinder heads
- COSSIE WATER TEMPS ?
- "Search" feature???
- Black 1990 2wd Sapphire 80K Genuine miles (advise pls)
- Butyl cam shaft cover gasket
- defferences on YBG engines with and without A/C
- Sierra 2.9 efi 4x4, changing torque split
- My 1st Cossie!!! What do ya think???
- Help Relay prob on my 2wd saff
- rs 500
- bushes
- saph window tints
- 2WD Saph Cossy Fuse Box
- timing belt
- uprated fuel pump?
- Cosworth exzaust heat shields ?
- What plugs for a Stage 3 Saff?
- cam cover refurbishment ?? help
- Xr4i cosworth brakes
- 2WD COS PULLEY PROBLEM
- Best cossie specialist
- Sapphire Short Shift Gear Stick.
- heat shield ? where ?
- Part number or name for this????
- silversaph forum.....
- HELP!How much is a 3liter rs saph worth??
- 3 dr back bumper
- Compression ratios
- How many moondust saphs were made???
- Tappets on a 2WD Saph.
- 2wd cossie rear axle into estate
- which cossie oil
- Any way to find out if 2wd saff is low comp ?
- 4x4 cossie wont idle from cold?
- gearbox oil
- chips
- 200 vs. 205 block and long studding.
- AP racing 4pot rear kit
- Tracking the Sapphire cosworth
- Carbon Fiber Parts for Sapphire
- RS 500 splitter question
