what to do
what to do
i am hopefully rebuilding my engine soon to a spec not catered for by a pre programmed chip lol. after i have built the engine how do i go about driving it to a tuner to get it mapped? or is it a trailer job! also what do i do about running it in? i mean if it doesnt have a suitable chip in at the time then surely i shudnt drive it, but then u cud say it not worth getting it mapped until it has been properly run in
help
as i have no idea what to do
cheers
help
cheers
best is to get programmaple ECU, so you can tune your engine. Megasquirt is maybe the cheapest choise. you can get pretty good tune by yourself, when you use wideband lambda to check the mixtures, then just modify your Ecus programming accordingly.
if using just new chip, then i would take car to tuner with trailer. and again to check mixtures when drived 2-5k miles, if you dont have Air/Fuel Ratio gauge.
