PDA
View Full Version : Ford Sierra/Sapphire/RS500 Cosworth
Pages : 1 [2] 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71
  1. Door Rod Lever Clip / Retainer
  2. Starter does not turn
  3. Brake issues
  4. anyone tryied athena mls with cooper rings gasket? gaskets
  5. Upgrade time
  6. Roof headlining interchangeable??
  7. 3dr cosworth wiring loom
  8. 4X4 Uprights, CV axel ABS vs non-ABS
  9. Cosworth fuel lines
  10. Smaller jackshaft pulley
  11. reliability and long stud choice for engine rebuild
  12. chrome window trim, removable?
  13. T34 turbo
  14. ​​​​​​​Sapphire Cosworth 2WD 'real world' prices?
  15. ​​​​​​​Sapphire Cosworth 2WD 'real world' prices?
  16. ​​​​​​​Sapphire Cosworth 2WD 'real world' prices?
  17. 1.8cvh to 2.0efi dohc conversion
  18. 1.8cvh to 2.0efi dohc conversion
  19. Cosworth stainless steel engine parts
  20. side/door trim
  21. 4X4 Sapphire cos gearbox full rebuild cost
  22. Sierra cosworth fuel tank sender wiring
  23. Cosworth 2wd tps
  24. Sapphire 4x4 overfuel problems
  25. 4X4 into a 3 Door
  26. 3dr turbo heatshield
  27. RS500 Rocking Horse Shit
  28. Stainless steel brake pistons
  29. Sierra 3door Cosworth fenders
  30. 3dr cosworths wanted
  31. Sierra sapphire cosworth
  32. Sierra Ghia Estate Parts
  33. Looking for Sapphire Cosworth Front Bumper
  34. 3 dr seat refresh
  35. Standard yellow injectors
  36. How many Smokestone Blue Sapphire Cosworths are left?
  37. Starter Motor shaft length problems!
  38. Diff 7" 3.92 ratio
  39. Please help ignition Wiring problem L8 92 4x4 Cosworth
  40. 2.0 DOHC Motorcraft ignition
  41. Brake master cylinder
  42. Is a 500bhp Saph Coss drivable as a daily?
  43. MK2 DOHC 4x4 2.0i Estate differential identification
  44. Sapphire Cosworth 4x4 Front Brake Lines
  45. Anyone near Falkirk to help get my car running?
  46. Ford Sierra 2.0i Batch Fire or Sequential EFI
  47. T5 gearbox to block bolt help!
  48. Battery disconnect 4x4 Saph Cos
  49. Where can I get an iecs monitir from
  50. Idles and revs nicely but won't pull away.
  51. Rear coilover spring diameter
  52. Saph Cossie Front Bumpers New?
  53. 3door no fuel pump feed, spark, and eml light on
  54. Cosworth 4x4 fuel pump priming issue
  55. 4x4 cos suspension advice
  56. Sierra XR4x4 2.8 running issues
  57. Wanted Sierra saph cossie sender unit
  58. Wanted t3 0.48 turbo exhaust housing
  59. Sapph Front & Rear Screen Fitment Guide
  60. offset for 17s on a saph 2wd
  61. Plenum breather?
  62. Sapphire Cosworth Steering Column indicator switch
  63. 4x4 front subframe fit in 2wd???
  64. Sapphire Cosworth 4x4 and Escort Cosworth Brakes
  65. Ford Sierra 1.8 cvh, what is this pipe
  66. Where to buy Sapphire Cosworth Heater Fan Motor (Non A/C)
  67. ISCV alternative
  68. Rebuild help saf cossie
  69. Oil pressure drop when on boost Saph 2WD
  70. Sierra Sapphire boot lock mechanism
  71. Cosworth/ Granada 7.5” diff
  72. 4x4 front diff tag identification
  73. Cosworth 2WD front caliper brake pipe
  74. Sierra A/C Condensor needed (new) - any tips?
  75. Looking for some Cosworth lattice wheels
  76. 90A alternator. Best one these days?
  77. 2wd coolant issue
  78. Air leak at injector
  79. Looking for a pair of standard cams
  80. what injectors on your cossi? ID1050x recommendations?
  81. Motorcraft Fuel Filter EFG84 alternative
  82. Sierra mk1 passenger wing wanted
  83. EFR 7064.083 vs 7064.92
  84. Sapphire cosworth shell history
  85. Cosworth shell
  86. Saph 4x4 ISCV issues
  87. No earth pulse to injectors
  88. Cosworth very slow to come on boost
  89. Sapphire turbo lag
  90. MOT and emissions
  91. Sapphire sunroof removal
  92. 4x4 Turbo Heat Shield
  93. 6 degree beam setup
  94. Cosworth cylinder liners
  95. YB alternator alternative
  96. Is my old cosworth (G444 TNA) still about and does anyone know the owner
  97. Cosworth amplifier
  98. Searching wire diagram Sierra 1990-1993
  99. Sierra RS Cosworth 3 Door - Door card WTD
  100. Sapphire sills
  101. Sierra wing mirrors
  102. Cosworth Head Rebuild - Recommendations/Advice
  103. Mk1 Sierra Xr4x4 3dr
  104. 240nm diff, pratical way to measure?
  105. New owner help
  106. Plenum hoses
  107. Plenum hoses
  108. East Kent trim - outer window seals
  109. Sapphire repair panels
  110. Warning light on
  111. Sapphire headlining replacement
  112. Pf09 voltage at closed
  113. Rear Screen heating
  114. The true spec of the original RS500 "T4" turbos
  115. 4wd Sapphire outer window weatherstrip
  116. 2wd front strut braces
  117. Can someone identify the relays please
  118. £ door Cossie indicators
  119. Dip stick for twinky
  120. Ford Focus ST170 transplant into Sierra
  121. Cosworth fuel pump question
  122. Front diff strengthening plate
  123. 3dr panel doners
  124. Cosworth 4x4 coilovers
  125. An Italian member of passionford wanted, History search
  126. RS Cosworth shop in USA
  127. Cosworth turbo part numbers
  128. 3 door abs pump rebuilds
  129. anyone own K15 KOS
  130. 1991 Sierra Ghia Shuddering acceleration - gearbox / centre prop
  131. Crank weight
  132. Sapphire Cosworth Steering Rack
  133. 4X4 front drive shaft lenghts on lowering
  134. Sierra sapphire questions
  135. Cosworth 2WD ABS pump/ bleeding brakes
  136. Narrowband Air/Fuel Gauge Issue
  137. Sierra sapphire cosworth rear roll bar links
  138. Insurance time!
  139. Cosworth help please
  140. Ford Sierra MK2 headlight wiper loom
  141. what best way to reach 400 HP on sierra cosworth??
  142. Hose replacement - options/methods
  143. Looking for a Cosworth 2WD engine loom
  144. Need for info help! A red mk1 3doors
  145. Roof gutter trim removal
  146. Sierra Saphire door hinge bushing
  147. Cosworth 2WD prop fitting
  148. Parts needed sierra saph cos
  149. Fuelab pressure regulator
  150. ABS & Tyre diameter
  151. Diesel problems
  152. Ford Sierra 74kw Where the fuel pump relay stands
  153. Mk3 Capri
  154. MK1 Sierra vs Mk1 Sierra Cosworth running gear differences
  155. Front driveshafts
  156. ST170 into Ford Sierra
  157. MK1 Sierra vs Mk1 Sierra Cosworth - differences
  158. T5 gearbox advice
  159. 17" wheel tyre choices
  160. Cossie hydraulic clutch centre slave cylinder
  161. Power steering pump high pressure connection
  162. Anyone knows what this is?
  163. Cosworth modine bolt
  164. Power steering - bubbling fluid
  165. Airtec intercooler touching lights
  166. Mk2 Sierra parts wanted - drivers door glass etc
  167. Cosworth 4x4 calipers - sell or keep??
  168. Red Sierra Cosworth
  169. Map / amp group A coil mounting
  170. Side skirt fitting
  171. Cosworth 2WD high pressure power steering banjo
  172. Radiator & intercooler fitting
  173. Brands hatch aftermarket 3 bar map sensors
  174. Looking for a L8 ECU
  175. Set of Siemens 55lb injectors
  176. Ford Sierra 1.6
  177. Airbox clips
  178. Sierra vin plate explanation for vehicle type number? Position 12.
  179. Repo standard back box
  180. YB COSWORTH ENGINE ( low mileage )
  181. Low mileage 2WD Cosworth engine
  182. injector dead time Bosch 403 greys
  183. Can I fit 70A alternator to Sapphire Cosworth
  184. Looking for a Cosworth alternator
  185. Front suspension top bush
  186. Cosworth exhaust manifold gasket
  187. Cone air filter or standard airbox
  188. Turbo cooler location
  189. Low mileage engine in bit worth
  190. Looking for 2WD loom
  191. 36-1 trigger wheel on the original pulley crank
  192. Cosworth fuel pressure regulator
  193. Which Transit Connet starter motor do i need for 2wd T5 gearbox
  194. Looking for a Cosworth 2WD engine loom
  195. Updating Ford Sierra Ghia interior seat - what is possible?
  196. Ford Sierra Wiring Loom and Select exterior panels
  197. Standard power cables
  198. Turbo choice
  199. Ebay Arch Liners
  200. Polyurethane bushes
  201. Morette headlights wanted
  202. 16 inch wheels on a 3dr
  203. T5 spacer for centre push cylinder
  204. Cosworth 4x4 Head
  205. Selling BORG WARNER EFR 76/70 with nortech manifold
  206. Camshaft tight to turn
  207. 2wd or 4x4
  208. Whell Knuckle with bearing and Hub
  209. Fuel rail fittings
  210. Where to buy AP 6 Paddle clutch cossie
  211. Best brand for a new crankshaft / zrp
  212. Yb cosworth 2wd
  213. Centre console
  214. Interior light, stereo, cig lighter not working
  215. Fischer C box (cassette storge)
  216. 3 Door Running Issues. HELP
  217. Any MK 6 deg beam users ?
  218. T5 gearbox, clutch barely engaging
  219. 3 Bar map sensor
  220. Best place for a new T36.63
  221. Wasted Again
  222. Heated front screen relay
  223. To cannibalize or not?
  224. Help needed with cosworth mods
  225. Brake caliper repair
  226. Brake upgrade
  227. Let's talk about strokers...
  228. Quaife peg or vernier cam pulleys
  229. Rear caliper brake pipe
  230. Handbrake cable routing
  231. Cosworth 2WD caliper to hub thread size
  232. Blown Gearbox?
  233. Fuel pump (model/part number)
  234. Cosworth temp gauge
  235. Cosworth 4x4 Problem with cooling. Boiling header tank.
  236. Sapphire radiator upgrade question
  237. Handbrake cable
  238. radiator fan switch
  239. Escort / Sierra 4x4 rear discs
  240. 88 sapph horns?
  241. Diesel Cosworth
  242. New problem.
  243. AP BRAKES Banjo bolt size
  244. Cosworth 4x4 rear brake disc size
  245. hello members any one tryied Brands Hatch Performance chip ?
  246. looking for a photo of group a center diff of 4x4
  247. rear whale-tail
  248. Sierra estate dash clocks wiring
  249. cosworth running fault
  250. Idle
