Sapphire Cosworth Steering Rack
I had my 2wd Sapphire Cosworth steering rack leaking oil from both sides and from the middle, now I have changed the seals and after 3 days not leaking is leaking again from the middle. Would some Stop leak fluid work as it is leaking a bit as compared to before.
I had the same problem with my 2wd steering rack a few years ago, it was the original one fitted in 1990 and was leaking fluid from various seals etc. There is really only one solution get a re-conditioned one. There were other things worn as well on mine and when the new one was fitted it made a big difference to how my car steers. Not sure if you have somewhere in Malta where you can get a re-con one but there are a couple of places here in the UK.
Fhmreader-Darlo
28
12-10-2011 02:21 PM
