Anyone knows what this is?
So I'm putting a rollcage into my car and have been stripping it down. Had some problems removing the steering wheel, forgot to put the key into the ignition lock so the steering lock was engaged. Got everything of but about 30 minutes later i found this on the floorpan under the steering column.
The M8 bolt is just there for size comparison. It has a smal hole in it aswell. Anyone knows where it is supposed to go?
Regards Jimmy
Regards Jimmy
Is it the bit of the steering lock that pops out to lock the column? Does the wheel turn now, without it?
Could be but it does not look like it has broken of. Dont know if the steering wheel turns since its of + the whole thing where the ignitionlook and turn signal etc is mounted.
Did you remove the steering lock or only the steering wheel?
Not sure exactly where it goes, but if you keep looking around I bet you'll find a small spring that will fit in the hole in that.
Or the spring is still stuck in another hole waiting for that bit to fit on it.
No that part is still there, that piece goes inside the steering wheel and locks it if i get it right, And that "pin" or what u would call it is about three times bigger than the piece on the pictures ive posted.
// Regards Jimmy
Hmmmm after looking more closely at the picture ged296 posted I'm not sure anymore. That could be it. Have to check tomorrow when I'm at the garage. Here is how i removed it. Cant se if that piece is missing thou.
/ Regards Jimmy
/ Regards Jimmy
2wdsaph ben
03-03-2014 09:23 AM
