Any MK 6 deg beam users ?
Mines touched the floor while using the solid alloy mounts, so I machined some spacers (I think 6-8mm thick) to give me clearance and also spaced out the steel beam pad to get it parallel
Mark V8 (14-09-2019)
From looking at my pic mark I’d say 6mm and it leaves about 6mm of the reduced stem to enter the guide hole on the floor
Mark V8 (15-09-2019)
Not on the road yet mate, they’re not as thick as the polybushes from my old beam so I think that’s partly the reason why the beam touched the floor
I didn’t really notice much of a difference with solid beam mounts. If you are making a spacer then a hard poly 6mm spacer might give you a tiny improvement in nvh.
Mark V8
16
13-02-2012 09:11 PM
