- will it fit?
- play in propshaft centre bearing!!
- 2wd saff centre prop bearing
- cosworth cams
- Group A ignition coil??
- heatshield ?
- lowering my saph 4x4
- stage 1 or 2
- HELP!
- hub nut size
- Pics of my saph
- Cooling system headroom
- cost to get turbo reconed
- Wat to look for when buying a saff
- Ford radio 2007
- 2wd oil pump fittings
- How many sub 50k miles Cosworths out there
- front bumper removal
- 2 wd cossie using loads of oil
- Head Gasket
- t35 turbo on saph cossie
- Turbo Heatshield
- Sapphire running problems
- Garage needed!
- Oil cooler on a 3dr
- 2wd Saph alloy choice
- any ideas?!!
- smoking cossie when boosting and decelerating
- anyone else help
- tyre size?
- does anyone know this car
- raidiator fans
- can i have a pic or
- what wud cause??
- Got a Cossie head off the block?
- fitting kit?
- loosing boost!!
- fuel press reg wanted!
- Moose130's Rouse front splitter
- How do I sort head lining sag???
- Escort cossie wheels on a saph??
- Need advices
- hows this for nasty
- inflated prices for spares
- Who did I see today in a 4x4 near Hampton Court?
- Turbo shagg!!!
- Do you own the Saff in The Keep?
- wiring diagram needed plz
- Cosworth Engine Wanted
- cossie bursting oil filters!
- i need..........
- Cosworth T5 5th gear.
- diff oil
- 4x4 suspension
- over heating
- whats it worth?
- 2WD Front Anti Roll Bar
- rs 500 cooler help
- Samco hose sizes for top of swirlpot and breather system
- really bad situation please help
- timing
- my first cosworth ride height questions
- F600 KVX 2wd
- Gear Ratios
- my fuel cap :(
- o/s front driveshaft
- ENGINE OIL
- Apexi fuel controllers
- Anyone ever thought of a Diesel Cossie Replica?
- Megasquirt on cosworth??
- wheels?
- Respray estimate?
- AMAL VALVE
- Saph rear susp bump stops...........
- My baby
- Seized Discs
- adjusment on konis for 2wd saff
- Breather problem?
- Air con pipe ?
- Rear Diff...
- HELP: Connecting an original Cosworth car radio (ECU2)
- Cossie underbonnet pics!!
- a white saff in sunderland today
- magenta 4x4 sapphire H971 YFG?
- 4 pot caliper rebuild kits
- About ZOOMotorsports adjustable rear beam kits
- rs john
- sapphire cossy
- 909 Plug leads,,,,
- Anyone have any knowledge of this car?
- rear alignment/geometry
- headbolt help
- POWER STEERING
- Front TCA for 3dr cossie!
- -35 lowering springs search pics
- sierra cosworth rally prep manual
- VIN number
- L8 to P8
- Remvoing Cold Air box from Sapphire - Help
- Who runs coilovers on their Sierra Cosworth
- Hot start Problem
- side skirt clips?
- rear bumper clips for my saff??
- RS500 Thermostat
- how much???
- 2wd Saph Starter Motor
- Silly brake question
- Cambelt Covers - Is Yours Off Or On?
- Co% on 2wd saff
- good place for a turbo recon ?
- strutbraces for 4x4 saff
- 3 bar map sensor part number
- 2wd Sapphire Buying Guide
- engine rebuild
- cossie problem
- magenta
- where to go 4 mapping ?
- windsceens in a 4x4 saff
- Rare Sierra Cosworths.
- abs sensor
- whats required to fit esc cos wheels
- L8 ecu
- Sierra Cosworh 2wd Rear Lights Question
- PASSENGER SEATS WINDIND BACK ON ITS OWN
- spec r dump valves
- New Sapphire Wings
- Removing ABS
- saff tracking
- 18`s on 3door?
- Saff Air Conditioning
- Sticking trim to body?
- Battery's......recommendations
- diff problems
- ABS Modules is there different ones??
- 2.0 cosworth engine needed HELP
- Head Gasket
- Where are all the lattices?
- 2wd & 4x4 Intercoolers
- uprated engine mounts cossie4x4
- Modified Cossie as an Everyday Driver
- what brake fluid?
- Anyone noticed that there are no Sierras at the scrappies??
- halfway house rs owners tonight
- fuel regulator
- strips or no strips
- Removing Sapphire 2wd air cond?
- oil cooler convert to turbo rad ?
- Original Sierra RS technicians manual on ebay
- brakes
- 16'' wheels on a saph????????
- Do Laguna splitters attach straight onto 2wd front bumpers
- Will these fit my saff??
- Which Turbo Heatshield for 2WD Cossie?
- Fuseable links
- poly bushes. weather stopped play
- HELP!!! CLEAR REAR LIGHTS!!
- 3 Door Cosworth Alloy Wheel Pics Wanted.
- Speedo Accuracy ?
- Cosworth Insurance.
- just out of curiosity
- JAMEX SPRINGS
- STILL NOT RUNNING...AWWW
- Hello/escos rims/3 door
- plenem spacers
- Wheel alingment ?
- can some 1 help pls
- How to open my Sapphire bootlid???
- why
- What exhaust??
- Blitz single piston dv ??
- Will a rs500 fuel reg fit a 2wd
- sapphire problem valve guides? advice needed please
- Question on Saff trim?
- exhaust change
- 4x4 saph head for sale
- Best suspension
- after reading the sierra 2000e topic
- 89 wiring
- Splutters on a sapph
- ABS light stuck on
- 3 Door Dash
- Cosworth 2wd engine rebuild or buy
- Where's the cheapest Grp. A fuel pump?
- picture request??
- wing mirrors
- ashley systems
- Badly behaved light wiper
- Fuel Pipe
- COSWORTH MAP SENSOR PIPE WANTED.......
- sorry if i sound thick
- thought is was time
- saff windscreen?
- head lining
- Group A rear beam ?
- 18" wheels on a Saff?
- Anyone know how to take a wing mirror apart?
- cap keeps coming off
- Anyone changed their fuel tank ?
- This gearbox fits into a 3Dr?
- poly bushes
- Rough guess on power....and some help Req. Please
- Got my BIG brakes, see pics.
- Was it you (Glasgow)
- 2wd Quaife diff
- dead cossie
- THINKING OF BUYING A RS500
- Different housing > what does it give you ?
- Headlight scoop / port..... pics ?
- how much can you pick up an early saff coss for?
- How realiable is a stage 1, 2wd sapp.
- Cooling tips 2wd Cosworth
- SPEAKERS
- COLOUR????
- Exhaust too low
- dump valves
- Glaenzer Spicer ref. for 2wd rear CV
- steering adapter wheel for a sierra 4x4
- front 2wd calipers in a 4x4
- breaking my sapphire
- Cossie rear diff
- just bought a sierra saphire 2000e
- question on 3bar
- Who does not run water to there turbo ?
- Shine the light, anyone know.....
- That injectores scoff at 42 lb/h???
- drivers side leccy window will open but not close.help pleas
- Anyone using Valvoline Racing Oil?
- Fuel spillage when fillng my Saff
- Speed camera detectors?
- engine rebuild. parts advice needed.
- is rwd cossie clutch the same as 4x4?
- my washer jets dont work
- Wheels for 3dr cossie!
- tickford badges and rs500 identification plate
- Head light wiper? (edit - repositioning?)
- saph wanted
- How to fit a 4x4 quickshift
- How much torque & power for a stage 1?
- HEATER PROBLEMS, HELP!
- brakes for saph on a £500 budget?
- repairing leather recaro's and cleaning them
- fuel pump question!!??
- High mileage. Should I be worried?
- 4x4 oil pump in 2wd
- Compomotive MO's in grey 16"????
- Dont flame me... please...
- What can be done with a 24v conversion?
- boost problem
