Head Gasket
Head Gasket
Hi I have managed to blow my head gasket again on my 2wd Saph. I am only running 14 psi (MD67 turbo), RS500 intercooler, air filter and exhaust, yellows, ARP stud and nut kit, not a huge power car, but this is my 3rd group A head gasket in under a year. It always goes under the exhaust manifold. I have had the head skimmed any ideas?
Is the ARP studs and Nuts reusable? I have thrown the instructions away, does anyone know the torque settings. I remember there were two as one was or the arp grease and the other for motor oil (which is better)?
Many thanks!
Many thanks!
Football Cwazy
i would say it's failing due to the block not being flat or not being torqued correctly, should be no reason why a standard gasket let alone 'grpA' wouldn't be sufficient on that spec.
If you can check it yourself, then you MIGHT be able to do it with the
engine in place but head off.
(flat and feeler gauges)
But if the block is shown to be mis-shapen,
then yes, engine out, Stip the block of everything
and take it to the machine shop to be skimmed
07-10-2015 12:56 PM
Mc5506
05-10-2015 09:57 PM
