Megasquirt on cosworth??
Old 23-01-2006 | 09:55 PM
orsts2's Avatar
orsts2
Default Megasquirt on cosworth??
anyone?
i´m going to put one in mine and desperate for some info
Old 24-01-2006 | 08:46 AM
foreigneRS's Avatar
foreigneRS
Testing the future
no, but i'd be interested to hear how you get on. good luck
Old 24-01-2006 | 12:02 PM
sailorbob's Avatar
sailorbob
Best to go to the MS forums for info but IMO it's a backward step, the code is very basic.
Old 24-01-2006 | 09:17 PM
SillyFezzaMk1's Avatar
SillyFezzaMk1
Rubber Rhino Crew
i have used megasdquirt ecu's on rs turbo engines and the 24v v6 cossie engine and the all worked fine. You need a little knowledge to do the wiring and i suggest you creatre a new loom rather than modifying yours as if the MS ecu fries/dies then u will be stuffed...
Check the megasquirt website for all the info..... www.megasquirt.info
And as for the code being basic...wtf it works well on any engine and has more adjustable parameters than many of the leading aftermarket ecu's at a fraction of the cost!
go 4 it m8y!
Dan
Old 24-01-2006 | 10:55 PM
K.Goa's Avatar
K.Goa
WHY?????
Old 24-01-2006 | 10:56 PM
bud-weis's Avatar
bud-weis
Football Cwazy
how much is this megasquirt then?? and why choose it over L8 or P8
Old 25-01-2006 | 08:49 AM
foreigneRS's Avatar
foreigneRS
Testing the future
MS is just a hundred quid or so, depending on if you buy a kit or a ready made one. advantages over L8 or P8 include being able to map it yourself, wideband lambda support with self learning for the fuel map using target AFR values, coil pack support, etc, etc.
as it is fully upgradeable, you can add extra features as you like as they are developed by members of the MS community.
if you want to know about it properly, read the MS forums
Old 25-01-2006 | 04:46 PM
robrs2's Avatar
robrs2
You don't need to make a new loom. I have a MS on my Dohc 4i. All i did was use a plug from an old ecu and wire the MS to that. Advantage is the ford loom has all the fuses, relays and plugs fitted, and you can always change back to the cossie ecu
Ford Focus RS Parts for Sale.
09-03-2016 02:03 PM
Billy_RS
13-09-2015 05:17 PM
28
08-09-2015 08:10 PM
Adam Graham
06-09-2015 07:04 AM
wheelwizardrefurbs
05-09-2015 11:52 AM
