play in propshaft centre bearing!!
ive got a bit of play in my propshaft centre bearing on my 2wd saff.Ive just called fords who said they dont sell the bearing or rubber donut on there own anymore so id have to buy a whole shaft...yeah right.,but ive phoned up another car spares place and they said it could be the bearing that has seized causing the rubber donut to wear out or could just be the rubber donut itself.Does this sound about right to you and what have you guys experienced in the past.
hi mate i had a center prop bearing go on my 2wd saph i phoned up fords they said they could not get one then they phoned me back & it was a bloke that nows all about cossies & he said he could get one he ordered it from fords in germany & it was only £60 ok mate (ford newbury 01635555340 ask for matty if this no has changed get them to put you through to newbury).
let us no how you got on
yippee...phoned matt at fords in newbury and he gave me the finnis code for the centre bearing,i then called the same dealer local to me who told me i had to buy the whole shaft and guess what???...he can get one for the morning...
finnis code is 1613023
get it up on ramps and grap hold of the propshaft either side of the centre bearing and push it up and down...mine had a load of play in it and the rubber donut is being squashed out the side......when you pull away you will get a bit of a shudder and maybe a knock on gear changes.
sorted then mate i new you can get them still glad your happy now alan
07-10-2015 12:56 PM
