what wud cause??
what wud cause??
4x4 saph steamcleaned engine all plugs and looms full of water dumping fuel in like nothing i have ever seen ...runs alot better with map disconnected its on greens with 3 bar i presume
new map i'm thinking!!!!!!
co% is 8 - 11 heavy black smoke .. plugs were soaked in fuel
Wouldn’t it be wiser to first disconnect all the sensor plugs/looms and dry/blow out all the water and then see what happens? If the over fuelling was caused by a sensor, then id look at the coolant temp sensor first. It’s located on the intake side of the head right at the back near the dip stick
roybacer
15-08-2005 12:20 PM
