- can I use universal zirconium Bosch lamda sensor for my
- Gear oil advice please
- Changing engine mounts
- 8 injector swedish plenum
- oily inlet/plenem
- 4wd cossie head
- what do you rekon of these ???
- When fitting a Plenum Spacer
- MSD Coilpack conversion
- Does anyone know E200 VYD
- WHEEL REFURB
- Brand New Saph Shell
- Converting 4wd saff to 2wd
- DIN Slot for gauges
- coopers rings
- Newbie: Q RE; Thrust bearing
- Idle up and down (not air leak)
- Removing main crank bolt
- Heater not working
- 2wd or 4wd throttle position sensor
- what type of dump valve?best sound?
- Newbie: diffs
- PAS on a Cossie is it self bleeding & is it AT fluid
- Roll cages in saff's
- Coilovers on saffs
- sapph cos rear braided hoses problem
- a way to get more steering on a saff? - for drifting...
- handling mods
- which turbo timer
- Change ECU, L1 to L8
- D33 JHM 3door moonstone cos
- Mounting oil vapour gr.A
- Car status indicator
- track car sapp
- few questions for everyone ecu mainly
- Who to use for a cylinderhead
- Where to buy a good Cosworth 4x4.Please help
- Weeping head gasket ?
- best place for 2wd steering rack?
- Throttle position sensor
- 18`s on saffs
- best place for car batterys
- saph price?
- which disc n' pads??
- best color for sapp
- engine loom relays/sensor
- sapph dash
- Sappire dashboard colours
- ECU loom
- RS500 and 3dr Genk Trip
- noisey bottom pulley..
- sierra in need of help ?!
- help please
- Cam cover surface reface.
- 3 Door Center console with no arm rest
- Mudflaps
- rs 500 spilter
- Suspension Q....
- im losing water
- sapphire cosworth 4x4 firing order needed
- Strange fan problem??
- wheels
- Same oil pressure switch??
- 4x4 heatsheild on a 2wd?
- Oil filter from Ford dealer or eBay - cheapest?
- 3dr... how do i check for a drain on the battery?
- Need some advice...... (Sierra Cossie)
- What gearbox for 3 door 4x4 conversion?
- Plenum elbow gasket - where from?
- what chip best for stage 1
- what colour underneath?
- Sierra rear bumper removal
- escort seats into a sierra?
- cossie alternators
- Strut brace on a sapphire
- Electrical problem
- oil cooler
- nsr light unit earth
- F400 TBD
- Where can I get one of these?????I must have one
- Getting Hot!!
- base map
- Have the answer for sagging headlining
- Setting mixture (CO2) using AFR meter
- Can anyone help I'm after a rs500 throttle body?
- Converting my 3 door to 4x4
- Relocating a Saff front number plate - to Mitsi Evo style?
- diff hanger
- Non Start?
- Ignition lead designations
- new wheels
- 4wd to 2wd
- fuel pressure 450bhp
- -31 actuator question
- valve stem seal
- coilpack mod for rev counter
- cosworth chips (more questions)
- 2.9 exhausts....where best to go for one?
- In line turbo oil filters
- Door cards
- easy way taking rear springs out ???
- Saff indicators not working
- 3 bar map sensor...?
- Engine running temps
- Not boosting properly in 1st...
- head gasket - following my previous overheating thread
- Possible to run 2wd T3 without dump / recirc valve ?
- Cam Seals - Are 2WD and 4WD different sizes?
- RED RELAY IN FUSEBOX ???
- gear box mount
- T5 mount
- Rainproof car cover for Saph, what do you use?
- 3dr cossie front bumper
- Cossie Petrol Tanks
- What is you Saph suspension set up
- HOW CAN I REMOVE CENTRE CAPS WITHOUT DRILLING, KEY IS NO USE
- diff mount
- SILVER SAFF
- RS500 Cyl head on to 4x4 block?
- How much is my cosworth worth
- overheating problem on a late greentop 4x4 cosworth model
- Cossie springs/shocks on a 1.6 pinto?
- t4 turbo question (help)
- 3 door inner wing
- Lowering springs for 4x4?
- Part number needed
- Gearbox T-5 oil
- How much brake fluid??
- cossie rad
- XR4x4/2WD COS SENDER UNIT??
- side moulding strips for 3 door
- scrap yb head???
- diff rebuild
- uneven saph suspension??
- air conditioning question
- Modify or not?
- Exhaust manifolds - which one?
- Engine mounts 4x4 Cossie
- I am trying to buy a T34 compressor wheel, NO LUCK
- 2wd saphh driving me nuts
- RS500 Front Speakers - What size are they?
- will a xr 4x4 box fit straight into my cossy-any differences
- Original tyre size for Saff
- Missfire ???
- transmission problems!!!!
- Electric sunroof
- brake pressure control valve leaks
- Siezed engine! Possible causes?
- HOW TO REPAIR AN RS500 REAR LOWER SPOILER??
- Zoo Motorsport front arb ??
- Changing starter motor
- --------------COS PLATE WANTED---------------
- brake disc recommendations?
- suspension strut cups
- best head gasket for 450bhp
- Oil cooler
- Lamber boss
- cosworth yb standard head port sizes ?
- 4x4 gearbox- gear selection problem, help required!!!
- quick shift for T-5 2wd Cosworth gearbox on ebay!!!!!!!
- Is part YB0842 a 2wd/4wd/EEC-IV inlet?
- A DOUBT WITH THE EXHAUST
- Sludge,
- Smoking cozzy!!! HELP!!!
- What air filter have you got and why?
- 4x4 Bonnet vent screws
- Cam timing
- Rs500 style front splitter
- wheels and what offset???
- Doors for Cossie 4x4
- T34 compressor wheel
- Why am I loosing exhaust studs
- Induction Kit??
- Saph Cossie Buying Queries
- Genuine RS500 cyl. head?
- what is this for?
- want some new wheels for my sapphire
- Will these fit??
- Clutch thrust bearing question
- 3 door engine bulkhead heat/soundproof pad
- 4x4 SAPPHIRE COSSIE FUEL TANK AND SENDER
- 2wd Saff rubbing on standard alloys
- rs focus wheels on a 2wd saph
- Coil pack
- COSWORTH MAPPING ANYONE FIELD MOTORSPORT ENG ADV
- Standard yellow injector
- Removing front bumper on Sapphire??
- adjusting ap 6 paddle clutch
- Can you still buy clips for the centre vent
- Rear Beam Bended??
- cheapest place for???
- What would cause
- escos heat shield
- porsche trackday
- Bosch 403 Grey injectors
- Ecu pin outs
- Camber on 4x4 cosworth rear wheels....
- Refurbished T4 - what's it worth?
- Anyone running a GT35R turbo on a Cossie 4x4
- 2wd Front splitter
- Is this how people sell stolen Cossies?
- Do I need to re-face my flywheel to fit 6 paddle clutch?
- Brake pipes
- sierra temperature guage sending unit.
- Saff 4x4 cossie clutch cable
- How can I improve fuel economy
- next step?????????
- 2wd saff electric windows
- will a escort cosworth....
- HEAD GASKET
- What throttle body? Is there a big difference?
- OIL BREATHER/SEPERATOR FOR 4X4 SAPPHIRE COSSIE
- 8 injectors
- 4X4 electrical problem
- Ariel on wrong side, what do i do?? Going for paint! HELP
- BOSCH GREEN INJECTORS
- FORD MOTORSPORT BLUE PLUG LEADS
- BRIGHTER HEADLAMP BULBS
- RS500 INTERCOOLER,WHICH IS BEST
- SUMP GASKET engine in car
- Boost hose clamps
- removing rear halfshafts on 2wd??
- co reading at idle speed?
- Running rough in this weather.
- HOW DO I GET IN TOUCH WITH AHMED BAYOO ?
- [SEARCH] ECU cover black LHD
- SAPPHIRE FORD MUDFLAPS
- cossy calipers
- PLUG GAPPING FOR SAPPHIRE 4X4
- poly rear bushes
- won't start
- High emmissions
- Tickets for silverstone ford fair, how do i get them?
- Saff fuel guage lies
- How much boost T34 .63
- Just rebuilded my T3 4x4. Right chip needed
- sapphire 4x4 rear calipers...
- motor out/in
- t34 and exhaust manifold question
- 3 dr coilovers
- 200 block with a 205 motor questions
- Front wheel position in arches
- T38, L6, GREYS??
- Oil leaks from too high boost pressure?, Please help :)
- Sapphire head lining
- 4x4 or 2wd?
- Identifying cosworth 4x4 gearbox and diffs? Quick help pleas
- Cossie racing parts, what's it worth?
- wot oil to use on a fresh rebuilt engine(2wd)
- boost problem
