- anybody fitted scorpio seat's to a saph??
- boxing in a cone air filter
- side lights come on when braking?
- spring identification help - pics
- Suspension
- saff cossie 4x4 steering column bush
- Bonnet vents
- I need some....
- sierra coilovers
- small end bushes and guigin pin
- Cosworth warning lights
- sierrra cosworth with r32 gearbox can be fit ?
- Cosworth upgrade ecu
- Sequential gearbox for a 3 door
- Gauges
- cold start twice starting and uneven running ?
- Help anyone
- pics requested of sapphs
- 3DR Cossie - Aftermarket Alloys - Advice
- Ford Sierra lights
- l8 ecu, what do the pins you earth for al and lc for?
- gear lever - stirring a pudding..
- cosworth street master pads
- Been offered 2wd cosworth £3500
- Need a new driveshaft
- head gasket
- vernier pulley choices
- Pedal Boxes
- tyres
- anti lag, road legal?
- What's this for??
- Replacement panels
- Best road spec for power/ reliability?
- Ford Sierra front and rear springs
- 2wd Thermostat
- leda vs gaza
- Cylinder Liners
- Sierra and Escos Intercooler differences
- help
- Rev counter jumping and then misfire
- xr4i bits same as 3dr cosworth ?
- Water pump
- Need to low CR on Sierra 2.0 DOHC turbo
- Ashtray to gearstick distance please.....
- cossie anti roll bars
- Uprated polly diff.
- Idle control valve
- 2wd caliper/ hub
- tremec t55
- broke my diff!!!
- cosworth radiator
- fuel line joints/ adapters
- cosworth crankshaft flywheel bolt patern?
- AP's 4x4 to 2wd fitment what's required?
- Difference in 200 blocks Picture atatched
- Outer cv boot
- Failed MOT on emmisions
- billit fuel rails leaking (attention of the billit people)
- 3 door cossie doors
- Would this fit a Rs cosworth??
- Strut braces with external wastegate
- Who is running B16 inlet, 83s and msd closed loop?
- stronger driveshafts in uk
- Wierd Clutch Problem
- spec clutches
- Show us your 24v saphs
- YB Cooling
- cosworth (200)block boring?
- HELP!
- Fuel pump relay fuse keeps blowing
- front bumper bots have snapped and fixings on bumper u/s
- whats the easy way to change my rear shocks and springs
- 2wd/ 4x4 Springs Answer Needed ASAP
- Different between a Sierra Cosworth 4*4 exhaust and 3door cossi exhaust?
- 4x4 exhaust rubbers
- New Aussie Sierra forum
- swirl pot question
- victor reinz group a head gasket max boost/bhp
- Where to get relay?
- Idiot question...spring under drivers seat.
- Wireing help !
- Brakes
- Stage 1 Cosworth fuel pressure fse regulator??
- Sierra sapphire 24v wanted
- conrod bolts
- Where to get
- fuel economy?
- Is an external Oil cooler needed on a track car?
- Cosworth cam belt slipped
- Sierra roll over jig
- Abercrombie and fitch t shirts
- pics of rs500 splitters original
- Biggest brakes behind RS7 Spokes
- ECU Help! Identification Please.
- 2WD Front Wheel Bearings
- crank bearings
- cosworth engine price?
- boosting problem..stage 3 T34.48 greens
- RL7s... what colour???
- oil cooler
- Rev counter problem after coilpack conversation
- Small Saph Clearout Taking To FordFair
- 3dr rev counter problem
- 36-1 crank pulley, what ecu/loom?
- Sapphire 4x4 cv boots ?? are they the same as escos ones??
- who has run there cossie with braided fuel lines
- Sierra roll over jig/spit wanted asap
- Last sierra cosworth 4wd produced ?
- 2wd 82C stat
- 2wd head
- Saff wiring clips/straps??
- bhp saph 4x4
- longstudded block
- LC from msd, how dode it work?
- saph fuel lines renewal
- How to Breath...
- coilovers 2wd not clearing inner arch?
- Cosworth owners in bristol
- oil breather / bailey image tank return pipe fit
- Stainless Exhaust Box life
- Where can I find a T5 bellhousing and or a 2WD flywheel for sale?
- help wasted spark kit
- Renault Laguna front splitter
- Wanted Saph Cossie Level Warning Strip Display. Inc Photo
- recaro bucket leather seat refresh
- amal valve
- Urgent help needed please
- Clutch differances
- Vecta immobiliser
- Question on Oil
- Power Engineering
- T34 vs gt2871r
- Pic request please
- Sapph in OZ
- After market ecu
- tire size
- Unknown turbosystems chip, help needed!!
- Sun roof fitment? not the glass bit
- airtec 500 intercoolers
- oil on arse !!!!!
- Trying to identify injectors and chip!
- rear beam mounts
- 99 turkish 200 block
- Wiseco
- possibly upgrading to cossie
- what turbo is?
- Does the Amal valve need to be piped in!
- airtec 60mm rs500 type intercooler
- gaz vs avo
- 3dr fuel filter change
- service 2wd 3dr
- check control 3door
- whats involved in fitting a 2wd rear axle to a 4x4
- Amal Valve Leaking
- Motorcraft 071 Sparkplug Prices, Ford
- oil breather leaking..gutted
- 2wd rear bearings, best place
- Wilwood 6 pots Vs Ap's 6 pot
- T5 Borg warner mysteriously fixing itself??!
- Recommended Head Gasket
- what service parts to change???
- best sealent for half moons...
- sierra exhaust
- head bolts
- cylinder head troubles
- Track Preparation
- who for cossie head work and long studing my block
- is there any advantage to a 8 injector set up
- Stupid question.
- Dyno plot feedback
- Type 9 to replace t5?
- Does this look right?
- T5 Borg warner rebuild difficulty level!!?
- dizzy
- my rear strut brace
- 3 door rear lights and clocks
- 2.0 twincam efi very sore on petrol
- fan problem on saff 4x4
- this is cosworth block ? ? ?
- holes in the floor
- Exhaust Mounts
- fuel gauge not workin?
- cossy wolf racing 4x4 shock asorber?
- no power to abs pump 2wd cossie
- Cosworth 6pot aps help
- Chamber/toe change when lowered?????
- cosworth fuel problem
- anyone know where my old 3dr is???
- how do I dismantle side mirrors
- 2wd Powersteering Rack rebuild help!!!!!!!!!!!!
- cossie looms?
- What power should I expect?
- Cossie cough (Rain water)?
- can u run grays on standard fuel pump?
- cosworth running probs
- fitting cos saph skirts to a xr4x4
- Head Differences
- no brakes
- bosch 044
- Cosworth sump drain plug size ?
- 3dr rubbing strips lengths?
- where to get a new sapph petrol tank from
- Lowering a Sapph...
- Saff 4x4 fuel flow and return quick qeustion
- I'm new and in Australia ! Help please !
- trimming a samco hose?
- 3 Door Washer Jets
- How to increase your oil pressure with a pinto oil pump
- K670EBF saphire 4x4 anyone on here
- Why is my saph running worse when turning down boost?
- gt 30 and external wastegate
- Cosworth tuning T34, Greys
- Compbrake Tie-Rod Ends
- What Oil For My Sapphire 4x4??
- T34 rebuild required Where ??
- New 3 door dash top on Ebay
- what size vacuum hose
- 2wd sierra cosworth finishing of
- clutch for 4x4 500lb ft torque
- Sill trims and whats this? More about ECU now...
- Sequential RWD gearbox
- Help with saph K929MMW
- should a T5 box bolt up to a 4wd shell???
- Sapphire models......
- What oil would you use in this engine ?
- Anyone breaking cvh
- 2WD hydro clutch pic request
- Rear Arms
- Powerflow exhausts ????
- 2wd fuel pipe to fuel rail ??????
- brake compensator valve
- Original Ford Cosworth datasheets free pdf
- Is this correct fuel pressure ?
- Uneven 3Door ride height
- L6 ecu melted pins ???
- Dummies step by step guide to ABS...
- Only 1112 Miles in 6 and a half years!
- 3dr missfire
- Propshaft center bearing mount question
- I think I have the wrong seal, or have I
- Price Guidance?
- bore size
- Cosworth specialists in dorset
- 4x4 Intercooler.
- best headgasket?
- Front and rear diff. rebuild with pics.
- Phase sensor / Dissy
- My homemade custom breather system with pics.
- Sierra Cosworth Help please
- Who has MSD (CDF Racing) pulleys fitted
