Rev counter jumping and then misfire
Old Aug 19, 2011 | 07:34 PM
Mathias's Avatar
Mathias
Default Rev counter jumping and then misfire
Hi,
drove today a round with the Cossie (4x4, L8, closed loop). Everything was fine and then
during acceleration, the rev counter jumped from 3000 to 5000 and 6000 and in this moment the engine started to misfire. After that the car was running fine again and then
it did it again. Driving with normal speed and easy acceleration is normal as always.
Who knows what can cause this? Maybe the phase sensor? What can i check?
Thank you!
Old Aug 19, 2011 | 07:44 PM
riks2rst's Avatar
riks2rst
i had same problem with my old saff 4x4, found it to be the 3 plugs found on the bulk head. (engine loom behind engine) try opening them and give them a clean. i did with wd40 and it work a treat
Cheers,Rick
Old Aug 20, 2011 | 02:25 PM
Mathias's Avatar
Mathias
Hi,
cleaned the plugs and car performs now normal. hope this problem is solved now.
Thanks for your help!
Cheers,Rick
Old Aug 20, 2011 | 02:59 PM
carls9941's Avatar
carls9941
Smile
Mine done exactlry the same cut the blocks on the loom off as had nothing but problems with it ....it will probaly start cutting out completley soon if it does pull plugs apart and then push em back together bet it will start mine decided to cut out in the road works on the m1 where there was no hard shoulder so I got Harvey at scs to cut em out ...... Problem solved.
Old Aug 22, 2011 | 11:29 AM
wolf cosworth's Avatar
wolf cosworth
If in doubt ! Flat out !
Had simelar problem with rev counter coming back every X months so I have cut the 3 connectors out of the loom and no problem since.
Steven
wheelwizardrefurbs
Sep 22, 2015 05:45 PM
Brickhouse
Sep 21, 2015 11:00 AM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
fuzzy
Sep 4, 2015 10:11 PM
