best sealent for half moons...
Am about to change the cam cover gasket on my 4x4 cossie and have got a new gasket and new half moon seals, is there anything else i should replace whilst doing this? also what is the best sealant to get for around the half moons? thanks
Loctite 5910, or 5920, Halfords sell the 5910, £5.45 a tube, or Dow Corning 728, not sure if you can get this outside the forces though ?
You don't need any on the cap seal, just around the ends where the tang of the r/c gasket slots in(if cometic), and all around the half moon, just let the 5910 go off for 5 minutes first so it skins over, but make sure it doesn't go over 15 minutes as it start setting fully, though full cure is 24 hrs.
I advise you to take off the front caps/bearing caps and put sealant between the cap and head, as many leaks from here get blamed on the r/c gasket, it WILL leak from here if not sealed.
Tighten the r/cover ONLY to the specified torque, NO more as this can distort the cover and lead to leaks.
Thanks Tabetha thats perfect , new you would be along to help : clap:
Oh btw dont suppose you know the correct torque setting do you off the top of your head mate?
Pm me your address, and I'll send you a copy of the cosworth workshop manual on CD, FREE OF CHARGE, I'll even pay the postage for you!!
In the meantime tomorrow I'll try and remember to look on the torque tightening list in the garage, and post up for you, from memory it is only about 3.5lbft ?, the CD will come in very handy as a reference source for you.
Tabetha.....Sorry to be a cheeky fucker but is there anychance i could have a copy aswell... I dont mind paying mate.
cossie fan (unluckerly)
K***LMT
sealer i used was from a vauxhall parts dealer, the sealer was grey but very good stuff.. not sure if its simular as the other mensioned but only used it one the moons and never failed was told to use as it was tried and tested.. just good stuff.
http://www.cannell.co.uk/Manuals.htm
Just scroll down the page till you hit fords
I had a leaking gasket and I tried to fix it couple of times with Loctite 5922. That stuff sucks as it leaked even though I used it on the ends of the rocker cover gasket where it meets half moons. Then I bought Loctite 5910 (though, I used it more than 5922 previous times) and no leaks whatsoever. I can recommend 5910, don't bother to buy anything else.
