- spacer block for 2wd manifold
- Block bore
- 4x4 front driveshaft clunk
- help on measurements for power window installation please
- What the f**k my fans r cuttin in at 82c
- GT30 peeps
- Saff cossie 4x4 gear knob
- anyone know who's this RS500 was - cheap!
- Rear Lights
- looking at 3 door
- turbo cooler
- RS500 rear spoiler
- emissions
- Cambelt cover mounting posts
- Rear beam bushings problem
- wheel offset of a sapphire cosworth
- 4x4 Sierra Track Day Car ?
- fin code for 17inch diamond cut polished rs7 alloys
- Saf Cos not running after jet washing engine bay.
- Cossie ownership again
- Sapph front bumper
- Best way to route gauge wires/pipes?
- My cars going 4 a set up
- 3dr sierra cosworth pics & rare funk songs!!!!!!!!!!
- Uprated Actuator?
- Sapphire Petrol Tank & Straps & fuel cradle
- abs problem
- Replacement panels for rot repair on Saff
- wheel PCD
- sierra 4x4 silicone hoses
- anti-freeze for sapphire cos 4*4
- New Cossie Owner
- Cover for Saph
- Cossie heated front windscreen
- idle problem
- sierra fuel tank
- saph cossie bumper splitter??
- bleeding brakes on sapp cosworth
- Diamond Cuts or 17" Rondells on my Saff Cos
- 8 injectors and loom
- Window rubbers
- battery drain!
- cone filter 2wd cossie
- Fuel pressure gauge
- dash lights out
- Underbonnet stickers
- Torque settings for yb rs cosworth Please ???
- abs sensors
- t4 turbo help...
- fooking cossie wont start. help me PLEASE
- et 42 or et 38 help please?
- wrc or Grp A spec piston ?
- L1 or L6?
- crystal collection
- Advice please..................
- 2wd baffled sump ?
- Saff 4x4 gearbox whine
- Cossy fuel pump rewire.
- cams
- AFR
- recommendations 4 engine and gearbox paint? cossie lump+box
- Group A Hydraulic Handbrak lever
- BEST PLACE FOR COSWORTH ADJUSTABLE REAR AXLE
- 2wd cosworth diff ????
- how do you clean an idle control valve?
- standard saf cos 2wd wheel offest ?
- Throttle cable
- heater matrix/rad .........???
- Brake upgrade Sapphire 4x4
- Heated screens
- Why do some cossies pop and bang on the overrun ?
- anyone know the measurement of ......
- Does anyone know about this car?
- Anyone know this RS500?
- Anyone know this RS500 ?
- cossie head gaskets
- HELP Cosworth starts then cuts out
- idle speed control valves??
- 1st to 2nd Gear Problem
- Co adjustment help needed
- Phase sensor adjustment
- cosworth injector question
- running very erractic!
- electrical fault
- Maximum BHP on Greens?
- vibra-technics 2wd gearbox mount
- temp guage won't move from the top??
- Correct co at idle.
- Dump valve, is it right
- what dump valve for a cosworth?
- Can you still buy brand new yb engines ?
- Modifying my sapphire 4x4
- Autronic SM4 on YBG
- turbo oil return pipe
- Front brake discs still warping!
- saff 4x4 dying when warm now fixed.
- Two tone paint
- sapphire cosworth steering wheel boss
- 2wd/4wd sapphire steering columns?
- RS 500 RUNNING PROBLEM HAVE TRYED EVERYTHING
- Oil pump
- Adjustable spherical jointed TCA's - Noisey?
- Coilovers vs Koni's/Bilstein's etc
- Tip of the year 2007
- front driver side wing..for saph cos
- whats the best coolant radiator ...............
- Parts on a Sunday
- Whats this plug for?
- Best place to get 400 bhp build on cossie engine ?
- 400+ bhp cossie owners post your spec please .
- Best Quickshift for T5 ??
- cossie door card removal
- xr4 cossie
- braided hose
- time attack
- Cambelts ...
- TORCO MOTOR OILS
- lamdba sensor
- 2wd axle beam
- Flippin heater matrix
- mis inlet plenum
- Fuel rail disconnect
- MSD Cloosed Loop Chip - Help!
- Saff cossie 4x4 gearbox oil
- carbon fiber bonnet for sapph
- what ecu P8 L8
- Best engine oil for running in ?
- water pump
- Cosworth engine oil - where do i get it from??!!
- Saff cossie 4x4 front wheel bearings
- diff gearbox oil
- 10 sec 1/4 mile
- Red Line gear oil
- ap superlights
- Water pump 2wd
- Cosworth Engine Number
- big brake kit
- BOOST GAUGE PROBLEM
- GPA RS500 papers
- Head bolts issue ?
- Date stamps 2WD
- The difference between a 205 block and a 500 block
- Did you know.............................
- sierra cossie air- water temperature sensors
- Magnex tail pipe
- Boost gauge 2wd
- What Size Tyres??
- Damaged bore,best fix?
- sapphire door bump strips
- Radiator Rebuild
- Original badges
- Big crash
- Amal Valve
- Rear brakes
- Tourque settings for yb clutch and fly wheel Urgernt
- Good Spec...?
- abs sensors
- GAUGES
- pistons
- Best Tyres for 2wd Cossie?
- Sierra Estate rear bumper
- cossy now wont start
- oil pump priming
- rear suspension shims
- ANY COSSIE'S WITH NO ENGINE REBUILD'S
- cometic head gasket
- Where to get pistons
- 3door moonstone blue paint code needed
- is it dangerous to use std headgasket at st3(22psi)?
- Final ratio on a 4wd saph
- Group A fuel pump Advice
- Cosworth BDA / Kent - Cosworth YB dry sump /dissy difference
- What Thermostat Degree?
- what intercooler
- Over fuelin
- Boot lid question
- Missfire?
- BONCASTER INSURANCE ????
- is it enough 4x4 intercooler for st3(standart T3 turbo)?
- where's Tabetha gone??
- water pipe Q
- big brakes under 17's
- Standard Cam help please ? Snapped again!
- door help
- ECU, which one??
- fuel pump rewire saff 4x4 ??
- Genuine Ford Group A gasket Vs Cometic
- polybushes for saff
- Boost Control
- 2wd saff & 4wd saff rads???
- changing clutch ratchet!!
- cossie free manual
- hesitating
- mongoose exhaust
- For 20k what sort of 500 could I expect to buy
- battery drain!
- i need new wheels any suggestions???
- 4x4 rear brakes
- does this cooler fit on standard hoses ? ebay link
- Loss of boost pressure
- CV JOINT GONE
- Best place to buy a turbo new, non exchange
- Overfuelling
- Clunking Brakes
- Why do we drink oil.
- who knows what about bolts lads and lass's .
- stg 3 2wd saff what headgasket and headbolts?
- L6 chip fit L8
- Lining up doors...
- over fueling
- Ive just been fookin stupid!
- rs500 style splitter
- quality wiring materials
- Rear Bumper Clips
- Dizzy cap
- a couple of cossie pictures
- 2wd Vs 4wd
- Bd14 - standard pulley..?
- wilwood breaks
- Changing water pump - how difficult?
- what rim size??
- fuel filter
- Respraying a saph
- Problem starting! Calling all 24hr PF tech heads!!
- Please help sapphire cosworth enthuiasts.....
- headgasket or cracked block?
- fuel pump bracket
- Thermostat Housing 2WD cossie problem
- BD10`s
- Cosworth handbook
- Grp a coils are they same as nova sport
- SAF COS 4X4 CAMBELT TENSIONER
- sapphire cosworth suspect head gasket problem
- Is this part standard?
- filling quantities
- MT75 quickshift
- show me ur track saffs
- Fittin a wasted spark driver
- Best Company for YB head porting?
- Sapphire adjustable rear beams
- rear brakes!
- sapph. sunroof seal
- Front suspension top-mount bearings
- Vibration when pulling
- Swirl pots?
- Need urgent help... coolant in oil!
- Boost Control
- help help help not starting
- GGR suspension system, anyone?
