RS 500 RUNNING PROBLEM HAVE TRYED EVERYTHING
I HAVE JUST GOT MY RS 500 RUNNING AGAIN AFTER A REBUILD CAR TICKS OVER PERFECT BUT WHEN YOU REV IT UP IT CUTS OUT LIKE THE IGNITON HAS BEEN CUT OFF I HAVE TRYED EVERYTHING I CAN THINK OFF I HAVE REPLACE THE FOLLOWING COIL,PHASE SENSOR,CRANK SENSOR,IGNITON MODUAL WATER TEMP SENSOR AIR TEMP SENSOR, AND MAP SENSOR HAVE ALSO TRYED ANOTHER ECU ANY IDEAS WOULD BE GREATLEY RECIVED
Have you checked to see if the ecu is losing its ign live ?
Is the alternator charging ?
I've seen it before on other cars, not Fords though that if the ecu doesn't see 12volts then it will simply switch off.
Check what Marco mentioned, I have heard that mentioned before
alot of the 3dr and rs500's suffer from this thats mainly the problem
it's ok ticking over but once you try to rev it , it cuts out and starts back fireing and sometimes it would just cut out for no reason thats the problem i had anyway
martin found the problem for me
persoanlly for what it's worth i would just change the whole engine loom to a pectel engine loom or a dingy or ryan loom
at the end of the day the 3drs and rs500 are 20+ yrs old electrics start fooking up after 8yrs anyway
marco
I was going to mention just changing the loom
Sounds like its already had enough and one thing you dont want is a part of it failing when on full chat !
Hope its fixed for now though
RB26DETT
17
27-05-2016 11:26 AM
Stu @ M Developments
41
21-08-2015 06:47 AM
ekjim
17-08-2015 08:57 PM
Zoggon
10-08-2015 10:39 AM
