- Focus mk1 and mk2 1.8 TDCi,s estates
- Trip computer wiring
- P0102 P0458 Issues, pulling my hair out
- Centre consul removal
- Hard to start and rough idle
- MK1 Focus wheel arch rust - preemptive strike?
- Heater matrix replacement
- Ford Focus Doors
- Hello from mertonwatkins
- Stock zetec focus aesthetic mods
- No start focus
- Help please
- Mk2 heater matrix removal
- Part Check
- Mk3 1.0 Eco-boost Clutch & Gearbox Failure
- Low mixture/no power when cold
- Focus 1.6 Zetec - 2nd noisy fuel pump issue
- Ford Focus 1.0 ecoboost pipes shaking
- Focus high reving
- New (to me) Daily
- Focus/fondeo sunroof compatibility
- window removal
- central locking
- St150 swapped mk1 focus?
- Xenon st170 in focus mk1.5 help please!!🙏
- Rear centre seat belt removal
- lights on warning buzzer
- brake ights
- focus mk1 interior upgrades
- De-cat exhaust system mk1
- MK1 Focus not starting
- MK1 Focus RS vs ST170 vs 2.0 Blacktop block
- Thick question
- mk2 towbar
- might some more valves be damaged..?
- ideas how to increase friction
- timing belt pulley not fixated...?
- Main bearings torque Zetec-SE / Duratec
- LED bulbs, yes or no?
- Focus mk1 more power!! Help!! Thank you
- focus mark 1 1 and 4 no spark
- Power steering fault reduced acceleration
- short ratio ford focus 1.6
- 1 owner Mk1 Ghia
- Focus MK1 VSS question
- 2006 (MK2) Rust...
- MK2 vs MK3 Dampers
- Ford focus mods
- Focus 1.8 misfire
- Oil in clutch housing
- Focus 1,6 Zetec-SE engine swap Ford Puma 1,7?
- Do you own a Focus sleeper?
- Fitting reversing camera Problems
- Ford focus 1.6 engine mods
- Ford focus 1.6 2009 engine swap or upgrads
- Ford Focus Cmax 58 plate 1.6 tdci
- transmission throw out bearing
- Ford Focus 1999 mk1 Transponder
- coolant bubbling
- Ford focus engine management light
- New Product: Classic and Kagu Floor Liners by 3D MAXpider for Ford Focus
- Suspension kits
- squeal/screech when pulling away
- Zetec 2.0 mods
- 1.6 Mk1, no spark at all.
- Ignition Problem !
- Focus Mk2.5 - Wet boot & passenger footwell
- focus mk 1.5
- Advice on fault with my Focus
- focus mk1 gear selector
- ib5 gearbox cable adjustment question
- Rocket cover focus mk1
- Parking lights Focus 2003
- 10 plate mk2.5 focus
- electric windows
- Anyone got IDS and good knowledge?
- Simple engine mods - Mk2 1.6 petrol
- remote central locking
- tailgate lock
- Starts then dies
- Fuel starvation
- mk1 focus 1.4 to 1.6 swap
- Car temp
- What does this mean?
- newbie
- Engine swap Immobilizer battle!
- mk1 focus
- Jacking point
- Mk1 focus coil issue
- Mk1 Focus instrument cluster swap
- How To Fix Or Replace ???
- 1.8 mk1.5 2003 Focus LX misfiring under load
- Focus MK1 Retrofitting Remote lock module
- 2013 automatic gearbox refitting problem
- mk1 focus ib5 gearoil suggestions?
- Heated leather seats lukewarm
- Can't Start The Car Now Help Needed Fast
- Mk1 2.0 Ghia Throttle Cable
- Ford Focus traction control light
- fitting st170 exahust on a 1.6
- MK1 Focus rear 'carpet' arch liner question
- Whats the difference between the Focus and Puma 1.4 zetec?
- Ford focus interior
- Focus low speed fan not working
- MK1 Focus - Gearbox Crunchy when Cold - Recent Clutch Change
- 1.6 Ecoboost 148 0r 182 BHP
- Focus Estate Bumper Swap
- Switching off hill start
- mk1 rear drums...how to remove abs ring?
- Bottom end hose
- Water getting into Focus boot
- ordering ebay key for mk focus
- Activating cruise control on FF mk1,5 1,8 TDCI
- mk1.5 1600 what boosts idle speed when a/c on?
- 2002 Focus 1.6 se zetec coolant fans
- ford focus mk1 sound system
- focus mk1 1600 low idle speed
- Ford Focus 1.6 54 reg
- Uprated Blacktop 2.0l valves
- End for my focus?
- pre tensioner wiring.
- Focus 1999 2.0 Ghia Stopped working.. Help
- new owner
- Focus 1.8 blacktop engine removal
- after some help again
- Focus 2.0 16v help
- heated screen info mk1.5 focus
- 1.4 focus hunting problem
- Engine swap from focus 1.6 tdci into peugeot 3008 1.6 hdi dv6ted engine
- focus headlight removal
- Focus MK1 - Engine swap problems
- Focus zetec s 2009 engine problems
- mk1 cup holders
- Mk1 focus rs t190 n I'm no idea what to do with it? Wts it worth? Advice plz thanks
- mk1 1600 gearoil change?
- 52 plate focus problem
- Sound system issue
- Focus Mk1 Speedometer
- 1.5 turbo tuning
- Swap head unit from ford to Sony advice
- EGR valve
- Speedo sensor retaining pin
- Focus 1.6 2006 - MPG Advice
- Mk1 focus mot query?
- St 170 head onto silver top
- Flat spot at 3000RPM
- Focus 1.8 LX Annoying Unsettled Idle
- Mud flaps for st2
- 17s or 18s on mk2 focus tdci?
- Electric windows not working mk1 focus 1.6 5door
- passanger side drum scraping noise.
- Clutch Return Spring Fitting - Sheffield - Non Dealer Specialist Garage?
- St specialists
- can i fit parts of a mk1 focus 1.4 to a mk1 focus 1.6?
- Focus ST2 Tints
- knocking n/s/r
- MK1 Focus Hand Brake Dash Light
- Car stalling when stopping.
- Lumpy, bad running, misfire, help needed badly.
- focus sub
- mk1.5 focus rear wheel bearing.
- Help needed on how to get into the drivers leather seat
- Cruise control on 2002 Ford Focus Ghia 16V, 1796CC Petrol
- Focus 59 Titanium Headlight Issues
- MK1 Focus 1.6 engine stalling?
- engine swap
- Blown seals on 2 slave cylinders in 1 week?
- Ids
- Focus MK1 1.8 Non Start?
- revs drop when slowing
- revers light switch
- 2001 1.6 zetec at a loss with idle / slow rev drop
- 1.6 Zetec-SE soft tuning
- Ford Focus 02 Clutch
- Changing timing belt Ford Focus 1.6 02 plate
- need help
- Mk1 focus headlight swap to facelift
- Aluminium or Steel drop links
- blown engine help!
- Ford Focus Mk1 Time Clock wiring
- Programming new key for Focus Ghia 2000
- rough idling after valve change
- rebuild front end mk1 focus
- keys in mk1 focus ghia
- idle valve
- Instrument Cluster
- Focus MP3 question
- different gearbox
- Help needed with a rough running Focus
- Koni suspension kit
- mk1 focus gearbox change?
- Engine cut outs
- Engine conversion
- Ford Focus 2.0 Zetec - what would you do?
- First car!
- 2007 focus se 3 door cv axle problem
- Ford Focus 1.6 mk1 1.7 Puma conversion?
- Alarm strangeness, maybe stereo related?
- 04 Mk1 Focus 1.6 Zetec - Stuttering/Hesitation at 65-75mph
- Auto Box Help!
- Central locking pulse wires
- focus 1.6 need more power
- strange intake noise on 1.6 sigma mk1
- Did any of the focus models have manual windows?
- st170 xenon beam is it right
- dash board light help
- water dripping
- Focus st mod x to turbo x
- Focus 2.0 ESP estate
- mk1 focus interior fit in mk1 focus for collection?
- Overheating
- Post pics of rustiest Focus you've seen
- Locking Kit 61262
- headlight bulb replacement
- Focus timing belt question
- Focus Very jerky at low revs
- Focus 1.6 Ghia auto 2003 no temp gauge
- Finally! Refurbished my alloys :)
- Focus MK1 5 door electric rear window motors/mechanisms
- 2006 auto Focus anything to be aware of?
- st170 solid flywheel conversion
- Focus 2003 Towbar
- Help with changing gearbox...
- fitted new turbo and now new issues
- Fitting tow bar urgent help needed
- Urgent help does my 2009 ford focus zetec a have canbus?
- Focus 1.6 OBD Code P0352 running on 2 cylinders
- Ford Focus MK2 Bonnet Lock Damaged
- Focus rs shafts on a normal 2.0 focus
- Juddering on the motorway
- Is this the ICV?
- Finally.
- Focus Error Code
- mk1 LX seat upgrade
- My car...
- Little bit of painting. PICs
- Has anyone used
- Fuel gauge problem mk1 focus 1.8 zetec
- Radio looms..
- Ford focus 1.8 Zetec roll bar
- Proper bugging me now :/
- Mk2.5 intermittent engine non start
- Best way.. Updated. (PICS)
- throtle bodies, st170
- MK1 Focus Ball Joint?!
- Odd Question
- focus 1.8 zetec 30mm lowering
- Lowering...
- HIGH CO2 mot failure
- Focus 1.8 zetec TPS
