Ford Focus (All Models) This forum is for discussion of all things pertaining to the Ford Focus Range that doesnt belong in the seperate ST & RS sections..
rough idling after valve change
Old Jan 7, 2015 | 07:54 AM
sgilwhite's Avatar
sgilwhite
Exclamation rough idling after valve change
Had a problem with a rough idle mostly when driving and the car slows and the revs drop too much and there's is a rumble but it never stalls. The revs flick back up which I've heard is normal. I cleaned my idle valve with carb cleaner but still looked dirty inside at the back so in case it just wasnt working correctly, on Sunday I changed my idle valve to a brand new one. I let the car run for 5 mins then took it out for a drive for 15-20 min's. Still not right. When I turn the engine on the autochoke doesn't keep the revs high initially before they go to normal after 1 minute and when the revs drop when slowing the rumble is still there. I've checked all hoses but could it be due to corrosion in part of the exhaust?
15
Oct 7, 2015 03:43 PM
xrmalin
Sep 13, 2015 06:52 PM
RSmark84
Sep 13, 2015 01:29 PM
natehall
Sep 8, 2015 05:13 AM
routemaster
Sep 7, 2015 05:27 PM
