Ford Focus (All Models) This forum is for discussion of all things pertaining to the Ford Focus Range that doesnt belong in the seperate ST & RS sections..
Focus high reving
Old Mar 13, 2021 | 02:37 PM
wirralalan's Avatar
wirralalan
Default Focus high reving
Hi
I have a mk1 2001 focus that is reving high when i plug in the idle control valve in and drops to just below tick over speed when i unplug it. Have changed inlet breather pipe ,new idle control valve and changed coil pack ,cleaned throttle body also taken out pcv and cleaned it (no gunk in it only discoloured ) Have a fault code on dash but thats only for the idle control valve to stop the engine over reving other than that it drives like it should
any help would be appreciated
Old Jun 14, 2021 | 08:02 AM
rayben's Avatar
rayben
Sounds like a case of a vacuum leak.
Camel Fiddler
Nov 23, 2019 12:28 PM
gramsey
May 9, 2009 02:24 PM
BECKY
Apr 15, 2008 04:17 AM
330bhpcoz
Apr 24, 2005 08:18 PM
