Ford Focus (All Models) This forum is for discussion of all things pertaining to the Ford Focus Range that doesnt belong in the seperate ST & RS sections..
brake ights
Old Nov 6, 2020 | 06:32 PM
johnno23's Avatar
johnno23
10 Year Member
Default brake ights
Hi all, my MK2.5 focus has developed an electric problem. When I switch on the ignition and turn on the lights the brake lights and dash lights come on.Could this be an earthing problem. I have no idea where to start looking.
Regards,
johnno
Old Nov 6, 2020 | 07:35 PM
GVK.'s Avatar
GVK.
Sounds like its back feeding , check the bulbs, and check where the rear lights earth in the boot of car, might have to remove some trim.
Old Nov 6, 2020 | 09:02 PM
johnno23's Avatar
johnno23
10 Year Member
Hi GVK, thanks for prompt reply, Had a bulb replaced when in for MOT, Will check tomoz for defect bulb.
regards
Johnno
Old Nov 7, 2020 | 12:33 AM
GVK.'s Avatar
GVK.
Aha! Bet they have put a single filament bulb in a twin filament socket....
Old Nov 7, 2020 | 06:10 PM
johnno23's Avatar
johnno23
10 Year Member
Well GVK, you were spot on, took it back today and they confirmed what you had suspected. they had indeed put a single filament bulb in a twin filament brake light socket. Many thanks again for your invaluable knowledge.
Old Nov 7, 2020 | 06:57 PM
GVK.'s Avatar
GVK.
Won't be the first or last time someone has done it! Glad it was a simple fix.
fezzajsy
15
Aug 21, 2010 10:12 PM
highlander1972
Ford Focus RS
Jun 7, 2009 07:09 PM
danm
Nov 28, 2007 06:59 PM
POPEYE
Sep 28, 2005 07:38 PM
BigbaRd
Apr 1, 2005 08:26 AM
