- fuel gauge with adapter complete
- Cosworth stereo amp with lead
- 2l twincam sierra ECU performance chip
- Sierra Sapphire RS Spoiler
- Cosworth brake pads, lights, hose etc
- pair of sparco pro circuit seats for sale
- Sapphire Cosworth Bits
- Cosworth hoses
- Gauge holder
- cosworth air box,complete!
- 4x4 Saph Cosworth Original Airbox
- Escort cosworth parts price reduced
- Sierra mk1 cosworth dash
- Bara big tooth box, 6 Deg beam & Gripper diff
- wanted
- Cosworth Level 6 ecu with Ahmed Bayjoo 330 chip & PF01 Throttle position sensor
- Few bits Alloy cam cover,fuel reg, breather etc
- Actuator bracket
- Cosworth cam cover
- Garage clearout , turbo , ht leads etc.
- 4wd Cosworth YB cylinder head + cams
- Group a airbox lid
- Airtec 70mm rs500 style intercooler
- BD14 & BD16 camshafts
- Garrett GT30r turbo
- Compomotive MO6 18x9 and 18x10
- Saph spoiler with caps
- Cosworth parts for sale.
- What's it worth 3dr Cosworth shell & rs500 bits
- Cosworth parts and more...
- Cosworth spares parts for sale
- 200 block and other parts for sale
- Genuine Sapphire Cosworth rear bumpers - what are they worth?
- YB Cosworth Engine 465BHP/440LB Geabox,clutch and flywheel open to Offers
- £400 job lot! Cosworth parts for sale.
- Cosworth Brake servo unit/crank pulley/4x4 thermostat
- Wanted: Cosworth boot badge.
- *WANTED* Turbo damper (3 legged)
- Pace Products PS steering Tank - SOLD
- L6 Cosworth ECU with Harvey Gibbs chip
- Wanted greens
- *For Sale* 4x4 Exhaust manifold
- Wanted: Tremec TKO T600
- Sierra Cosworth saphire white bumper wanted
- 2wd cosworth billet pulleys set,PRICE REDUCED!
- exhaust housing .48
- Escort cosworth carbon heat shield
- Escort OE Rims 16" with Goodyear tyres
- Cosworth Parts, Engine, Fuel System, Loom + More
- WTD: 4 door Sapp Gear knob.
- L8 ecy with wasted spark, new rs500 hose,3 bar map sensor.
- Cosworth 4x4 bits
- Hoses and Bling
- Sierra Cosworth Koni adjustable rear shocks
- MINT Sapphire Cosworth 4x4 under bonnet lining
- 325mm 2wd front brake set up willwood
- 3.9 drop gears and chain
- sold
- Sold!!!
- 7.5inch ATB diff
- Collins Siamese 8 injector inlet manifold
- Sierra cosworth Rs500 inlet manifold
- Nomad boost/oil pressure gauges
- Saff/3 door Airtec 70mm intercooler
- Escort Cosworth parts, AP brake kit
- RS ECU cover
- Aftermarket oil / water temp gauges
- Sapphire cosworth fibreglass rs500 style front bumper splitter
- New 4 spoke rs steering wheel + new escort abs sensor
- LUK 3 piece clutch kit
- P8 ECU
- Some cossie bits and pieces
- Cosworth parts left from breaking!!!
- Freshly Rebuilded Cosworth Engine. 200block, 5000£
- Straight cut Bara 4x4 gearbox.
- Grey injectors
- cosworth alloy breather
- Cosworth air injectors
- 2wd gripper diff
- Escort / Sierra cosworth front brembo brake kit 360mm
- Now sold.
- L8 ecu, MSD closed loop 330bhp full setup - also set of grey injectors
- p8 ecu
- Sierra Sapphire Cosworth Shell
- Sold
- Sapphire weatherstrip seals
- Twin air injector loom
- sold
- Siemense 55lbs(3102)P8 ecu
- Cosworth L8 ECU + Stage 1 chip
- Innovate lm2 wideband kit
- Genuine RS500 rear spoilers
- Small turbo escort engine Sale!
- Cosworth L6 ECU & PF01 TPS
- Saph Ambers
- 1988 sapphire cosworth breaking!
- cosworth YB conrods
- Cosworth yb inlet
- Gt3071 turbo with atp exhaust housing
- 4x4 Auxilary Belt Tensioner
- Sierra dashboard cosworth xr4i 3dr
- 4x4 inlet manifold and throttle body complete with sensors £125
- Escort Cosworth, selling up, shell & parts
- Rare Biante Dick Johnson 1:18 RS500
- 3dr Cosworth original side moulding - full car set
- YB 200 Block
- Genuine RS500 Front bumper
- YB engine stage 3 kit for sale.
- 55lbs injectors and a 380bhp chip
- Autronic SM4 ECU/LOOM,COILS & LEADS FOR COSWORTH
- cosworth inlet manifold, polished trumpets 2wd cover
- Cosworth oil filler cap billet polished alloy
- cosworth engine parts head bottom end cam cover etc
- Few bits and bobs
- Cosworth private plate
- Bosch 044 grp A pump
- turbo technics t38
- Helix uprated clutch cover - like new £150
- Turbo A/R 60
- cosworth injectors / turbo / ecu's
- Adjustable tca,s ABS block, front diff, swirl pot.
- Some Cosworth parts
- Sierra 3dr AP Racing 4 pot Calipers
- Sierra Cosworth 8 injector COP Engine
- Sierra 3 Dr Works Adjustable Rear Beam
- sierra saph parts
- Cam belt tensioner
- turbos,cats,fuel rail,3 bar map sensors etc can take to national day
- 2wd alternator brackets
- Sierra Cosworth standard fuel pump & Blue M/sport H/T leads,fit all red top engines
- 2wd sierra cosworth shell breaking
- Parts
- Sapphire 2wd parts for sale
- Mk bottom tooth pulley
- Genuine 2wd motorcraft clutch (Now Sold)
- 4x4 Plenum (Now SOLD)
- Set of 803's SOLD.......
- Saph 4x4 AB rear springs
- Cam, fans, ARB, glass, motors etc. job lot
- Rs 4apoke wheel to fit Sierra + escort hub
- Life racing F88rx Ecu £1250
- Smith and Jones 1000 bhp engine and few other parts
- 83lbs low impendence injectors, 2wd exhaust manifold,genuine 3 bar map sensors
- escort cosworth std cats
- Sold .......
- Billet fuel rail and brake bells
- Siemens 72lb 750cc injectors £250 plus L8 ecu with Pectel board £280
- Autronic SM4 ecu
- Siemens 83lb and 55lbs injectors low resistance
- 7.25" twin plate clutch drive plates
- L8 ecu with pectal board Prometheus Wiring loom and fan loom
- Cosworth engine parts, GT30 turbo and tubular manifold, cams, fuel rail
- What's it worth? P8 ALS + 83lb's
- Stack ST 8130 dash, boxed as new £750
- L8 ECU with wasted spark and Pectel board for sale
- Rs500 airbox for sale
- Pectel t2 management setup
- Ahmed bayjoo 6 degree 2wd rear beam. Sold.
- Cosworth AB07 Cam
- L8 ecu with baby board and chip £250
- Uprated AP pressure plate
- Escort Cosworth Parts
- 2wd 7.5" gripper diff. Sold.
- 4x4 bara stright cut gearbox. SOLD.
- sierra cosworth complete airbox mint condition no broken clips etc.
- Siemens 83lb blacks
- Modified Fuel Rail, 14mm Inlet Spacer and 4x4 Manifold
- Twin turbo cosworth 24v v6 engine gearbox ect
- sierra Rs500 3 door cosworth lower dash mint also amp with le
- 200 block on standard bore
- cosworth parts , more added and prices reduced
- bosch grey injectors 028150403
- Grey injectors 403's
- turbo technics T34.55 housing
- bogwarner 7670 turbo
- 4wd 7" inch Quaife ATB reardiff
- Quaife front diff thickwall casing + ATB Quaife frontdiff
- Various 2wd cosworth parts,heatshield,d40,k&n,Samos,bolts,bumper spoiler plus more
- NEW Genuine Ford 70a Alternator (2wd)
- cosworth YB timing belt cover for sale
- NEW! GHA coilovers for 4x4 sapphire and Escort
- Cosworth 2wd front brakes (std size)
- t34 .63
- Siemens 3105 inj for sale
- Brand new vipec v88 for sale
- L8 ECU for sale
- Brand new cosworth engine loom
- cosworth fuel pressure regulator 2wd mint condition
- T34 turbo with .48 housing just been rebuilt.
- 2wd hoses
- Powerflex Rear ARB bushes
- Creative carbon airbox lid
- Cosworth Yb 9 bolt billet steel TTV flywheel
- Straight Cut Gearboxes x 2
- Sierra and Escort RS workshop manual
- New Laguna splitter
- Bosch 044 Pump + Sytec Fuel Regulator
- complete sierra cosworth 2wd ported head 137.5
- 4x4 central locking motor
- Genuine Cosworth 2wd Weber fuel pressure regulator
- mk1 sierra dashboard cosworth rs500 ect
- Autronic SM4, EFR6758 new price!!! T5 BW gearbox
- cosworth parts
- sierra cosworth clocks
- Escort/Sierra Cosworth Parts for Sale
- T5 speedo drive
- bilstein 40mm strut cases (brand new)
- few cossie parts for sale!
- 2wd used pistons
- 2wd cambelt cover.
- Garage clear out
- Various bits and bobs JOB LOT £25 DELIVERED IN THE UK
- Hel breaklines 4x4
- New Bailey damper, new 2wd rear calipers, new rear flexis
- Long Studded RS500 Block
- 55lb Siemens black injectors
- Saph rear ambers forsale (pics now added)
- refurbed t34.48
- Mk1 sierra dashboard
- Cosworth Parts...
- Sapphire cossie leather recaros
- Ap racing 2wd brake kit
- 3dr cosworth rear lights new
- Asev a 17x8.5 et25 pristine new toyo proxes tyres new koni shocks 4x4
- escort cosworth parts
- Escort Rs Cosworth parts for sale updated 10-06-16
- Cosworth Parts For Sale
- Escort Cosworth 18" New Replica Wheels Tyres
- cosworth parts
- Ford Sierra sapphire Cosworth parts new items
- Supra diff cover
- Escort cosworth fuse box
- Sytec ITP048 Fuel Pump (in-tank)
- Ferrodo ds3000 pads to suit AP 6 pots CP5555
- 2WD Exhaust manifold
- Sold
- deleted
- Sierra 3dr/escort genuine indicators
- SIERRA COSWORTH 2WD 350mm COMPBRAKE KIT
- Ford Racing Gauges White Face Brand New in Box (Sealed)
- Mass clearout of sierra parts, new and used
- sierra/escort Cosworth..(RADTEC) intercooler new pictures on page 3
- deleted
- Fuel pump cradle
- Borg Warner 7670
- Cosworth cam cover machined
