- BNIB Sierra Cosworth Centre Cap
- Breaking Sierra saff good spec
- escort cosworth calipers x4
- T34
- Big spec v8 escos ex time attack breaking UPDATED!
- Saph Cossie Leather interior in Ireland
- Gaz Gold 2wd Dampers SOLD
- ***SOLD***
- Nice camcover and new grpa cambelt + more
- 2wd sapphire door cards
- Sapphire cosworth Front & rear bumpers , need paint etc..
- various cosworth parts Escort+sierra (open to offers on all parts) need space
- RS Cosworth Gearbox Quiafe Internals
- 4x4 Cos std front brake callipers and discs+pads, and more
- Greys and chip
- bd14 inlet cam
- Escort breaking group a/wrc parts updated 12/7/09
- radtec 60mm intercooler and complete water injection reduced
- TurboSmart Eboost 2 Electronic Boost controller
- Escort Cosworth parts for sale.
- WRC 18Y perfect for escos/ rally car.
- RS500 front splitter
- sold
- Mountune air-restrictor (T34)
- 2wd cosworth engine/ turbo/injectors/anitlag
- brand new gaz golds 2wd
- cosworth 2wd willwood brakes
- 2wd engine loom and standard pistons
- Pace turbo cooler with mounting kit.
- 2 wheel drive rear brakes ***NOW SOLD***
- 4x4 leather interior
- Escort/Sierra Cosworth Custom Tubular Manifold
- std cosworth pistons cheap
- 4x4 cosworth stainless gear lever bushes £25 delivered
- loads of parts now on ebay
- Morette's for saff
- bits on ebay
- Gaz Gold adj dampers 2wd
- Brand new Genuine Cosworth 4x4 Uprated Oil Pump
- GT3071r
- AP Racing 330mm brake kit for sale
- Saftey Devices saff/sierra 6 point cage
- Turbosmart Megasonic Dumpvalve
- New Ap racing 4 pot pads , Hawk Ht-9 .D-50 pad depth
- esc cos parts
- sold please delete
- 36/1 crank pully small turbo escort cosworth
- b&m 2wd quickshift
- New Carbon Metallic PFC 93 Brake pads , Suit AP 6 pots
- gear lever cradle bushes
- Sierra Morrettes, with a piccie.
- complete 2wd black samco hosekit
- cosworth wheels what they worth
- cosworth 2wd std pistons
- delete plz
- SOLD
- .55 Exhaust Housing. Pics added
- 2WD Sierra brakes
- Focus RS Brembos to fit 2wd cosworth***********SOLD**************
- Sold please delete.
- Escort Cosworth Alloys, Sierra Cosworth Interior + More
- cosworth parts,poly bushes,clips,arb bushes odds and ends
- SFS HOSES, ESCOS tyres,
- Cosworth engine bits
- SOLD
- coswoarth bits
- flywheel and clutch
- new cossie clutch
- Re-con sierra cosworth 2wd calipers SOLD please delete
- 2wd saph blue hoses, loads of chrome job lot on ebay
- Cosworth parts + TT38
- radtec 60mm intercooler with complete water injection kit twin pumps
- 4x4 rear diff /driveshafts SOLD
- Breaking 4x4 Sapphire Cosworth - Shell, Engine, T34, Magnex, Koni, AP, Brakes
- chrome bonnet hinges
- MK5 Escort Cosworth/RS/XR3i Morettes
- 4x4 cos parts for sale
- cosworth engine 472 bhp sod sold sold sold
- Nomad boost gauge (new price)
- Cobra Evolution Carbon seat and 3" Harness
- sapphire Cosworth roof lining
- 4wd Cosworth stainless system SOLD
- Escort Cosworth exhaust stystem
- saff cos bumper
- complete 2wd saph rear beam with diff
- MSD Chip
- GGR dump valve
- msd magnetic sump plug
- escort cosworth parts
- How much is a standard small turbo exhaust worth?
- .5 mahle pistons
- L6 ecu, 2wd loom, ignition amp on bling back plate + standard pistons
- saph shell with mot SOLD SOLD SOLD SOLD
- MT75 gearboxes
- sierra 3dr roll cage (price drop)
- Group A 909 fuel pump
- 3DR Cosworth Engine wiring loom
- 4x4 cosworth front driveshafts
- brakes
- Rs 4 spoke accessory s/wheel
- Cosworth brakes (with pics)
- Cosworth rear beams and arms
- 2wd Cosworth Cams
- cosworth parts for sale
- ap discs for sale
- escort rs cosworth small turbo injectors
- sold
- all sold at ford fair
- sierra cosworth ecu cover
- Going Castlecombe - can take the following parts if interested
- few bits i put on the bay
- 2wd cosworth shell (EVERYTHING NOW SOLD!!)
- alloy steering rack bushes
- RS Cosworth Engine & Management parts
- 3" 4x4 scorpian system
- large k&n filter *sold*
- 803 - Green Injectors
- 4x4 saph carbon fibre bonnet
- 3 door cosworth t3
- white 2wd saph breaking
- sapphire cosworth 4x4 parts for sale
- -31 actuator
- Cosworth Parts Injectors, Stg 3 Chip, Swirl Pot.
- T4
- SOLD
- beam bushes coss
- L1 stage 3 chip
- S8 ecu for sale
- 2wd saphire cosworth cloth interior
- Fuel Pump 0580254044 "044"
- Cosworth sierra parts
- Silkolene Pro S Bargain £37.49 This weekend!
- T34.48 360 bearing, £375
- Cosworth Parts Clearout all lowered to clear!!!!!
- Standard Unground Crank, AP Calipers 5200
- Rocker cover gasket
- cosworth 3 door parts for sale
- big spec 2wd cos breaking diff, radiator fans, stainless 3" exhaust, anti roll bar ..
- 4x4 saff wheels
- 4x4 front anti roll bar
- 3 door bonnet vents
- iscv,throttle and 4x4 tps,cossie
- 3DR Cosworth Door bump strips and GRP A Coil
- 3dr cosworth parts (now with pics)
- Various cosworth parts
- saphire parts
- Mongoose 2wd cosworth exhaust
- Sapph outer rubber window surrounds
- cosworth parts
- Bosch 803 dark green injectors as new
- Sapphire headlamp wiper arm& blade
- Ford dump valve for 3dr/2wd sapp
- few cossy bits
- Breaking 4wd saff cosworth good spec
- cosworth crank from 52k escos st also turbo unit
- P8 MSD chip/ siemens 55lb injectors/ turbo
- XR4x4 FRNT SHAFTS, ST - COSSIE HEAD + parts
- Garage clear out cosworth parts
- dash vent gauge holder thing
- 3dr BONNET PULL/CABLE BRAND NEW
- Bailey breather
- Cosworth parts Clear Out...
- hybrid T3 4x4 saff
- 2wd cosworth TCA's
- SOLD
- 044 fitting kit
- spax coilover/suspension adjuster key (hard/soft)
- Few Escos bits
- Now sold
- couple items on ebay
- cosworth private plate
- Standard grind crank
- Bara box
- cosworth odds @ sods
- cosworth inner and outer rear beam bushes
- 2wd cos rear beam
- sold
- Cosworth rocker cover and discs.. *pics inside*
- 3 Door Wing, how much is it worth?
- 3 door smoked clusters - SOLD :-)
- t5 gear stick,smoked rears, ign amp
- RS200 SPEC BROCHURES(4 page fold out)
- A pillar twin guage pod-3dr brand new
- 3dr/rs500 car cover
- 4x4 manilfold. 10inch spal fan slimline
- Super 8 ECU + 803's
- 909 diffmount
- Cosworth 044 Pump and Fitting
- Breaking 4x4 saff fairly good spec H16KOS now with pics
- R&D plated big front diff
- cosworth parts *FREE DELIVERY*
- wanted
- bailey turbo damper brand new
- 3 Dr Cossie 1/4s
- 4 pots / fancy discs £100
- amhed bayjoo springs 2wd saff
- 2wd saph breaking, carbon goodie's and other bit's!! breaking next weekend!!
- Cosworth brakes
- Gt3582r turbo
- PARTS
- Near new 4x4 header tank
- sold
- 4x4 tps and idle valves
- Magenta 2wd Cosworth shell
- Breaking July 1993 4x4 Saph
- Brand new original outer bush for Rear arm.
- scorpion 4wd exhaust
- Aux Pulley and Dizzy Cap
- Bilstein 909 Rear Top Mounts
- Looking for some cheap sale items for your Car?
- 3 door parts prices added updated
- MSD ALS/LC Chip - (with spec)
- few saph bits
- cosworth engine
- one for the "concourse" Cosworth owners
- sold
- Escort Cosworth monte engine and P8 ECU
- mods can delete :) - new thread
- 4x4 saff shell in ebony..MAKE ME AN OFFER !!!!!!!!
- 2wd cosworth shell and more
- Sold
- Carbon gauge holder/air vent replacement
- Group A Coil
- Saff chrome header tank and swirl pot- Can bring to Classic Ford
- Saff Front and rear strut braces - Can bring to Classic Ford
- Paddle clutch
- 3dr cosworth parcel shelf
- Sapphire boot Carpet & Foam underlay.
- GT35R Field Motorsport Special
- pro alloy water injection tank and pump
- Strut Brace REDUCED AGAIN !!!! SOLD
- 4x4 gearboxs
- RS500
- cosworth door strips SOLD
- BITS.
- rear quarter windows of an EcCos
- 4x4 gearboxs
- Pectel
- Brand New Garrett Dash -31 Actuator..
- Silicone Hoses (Some samco) & Alloys pipes
- 2 x Fan Switches (cossie??)
- baileys trumpet dump valve
- B&M Quickshift for 4x4 Sapphire Cosworth
- 4x4 Saph Cosworth Airbox with K&N panel filter
- Garage clearout 2wd avo coilovers new in box plus more
- ACT Gauge
- 2wd Stainless Bottom Radiator Pipe
- Breaking Escort cosworth 1995
- 4x4 throttle,tps and iscv+caliper rebuild kit
