- NEW Front windscreen trim (outer)
- For Sale - 803 Dark Green Injectors
- 2wd cosworth thermostat housing Genuine,NEW
- Isky double valve springs+ retainers
- 3 door abs distribution block and original metal brake lines
- Cossie Oil filler cap (Stainless/Polished) *SOLD*
- 3 spoke RS wheel (with boss and center horn) *SOLD*
- 2WD stainless exhaust - Scorpian
- Auto Specialist Cambelt cover - Sapphire Cosworth
- g tech pro rr performance metre
- 2wd bd14 inlet cam
- Greens Injectors SOLD**
- cosworth parts for sale (more bits added)
- Tb34.63 sold
- 200 Block machined for long studs, oil squirt jets (Cosworth Pistons Available) SOLD
- Pair of BD14 Cams - SOLD
- T38 Turbo+Comp Alloys 18"
- Ford Escort Cosworth badge
- saff cosworth morrettes £185 including postage
- sierra sapphire breaking not cossie
- SOLD
- 2WD Cosworth Sump
- Escos Mongoose Exhaust system
- stack gauges for sale, oil temp/oil press/boost
- Cosworth bits ( up dated )
- Hyd hand brake
- Various Sapphire Cosworth parts
- sapphire mouldings
- Wanted 2wd stub axles and hubs
- RS Cosworth Pars Forsale
- Cosworth Philloy single bar strut brace ### SOLD ###
- modded small turbo inlet with tb and iscv
- Brand new avo coilovers 2wd on eBay with pics
- Rear 2wd gaz coilovers
- AVO GTX Coilover Kit
- a few Escort Cosworth spares
- cosworth eibach springs
- Sapphire Cosworth leather interior - provisionally sold
- Recaro spares, inlet/exhaust valves, various parts
- Snap off Steering Wheel
- Auto specialists inlet
- SpecR 3dr Header Tank (sold)
- Saph front an rear raven leather seats
- Standard pistons rods cams and valve springs
- Various parts forsale (some pics added)
- cossie bits, siemens 55s, ht leads, 2wd std inlet cam , cam pulleys, l8 MSD chip
- some nice parts for sale
- sierra parts clearout
- cos 4x4 gearbox mt75
- Escort Cos rear bumper
- Wanted sierra heater box
- Stack oil temp gauge
- WANTED siemens 83s
- Carbon fibre bonnet pin recess
- Sapph parts clear out-new parts added 02/04/2013
- Sold
- Pair of quality Escort Cosworth Strut Braces
- Escort Cosworth 4x4 hubs
- Leather seats for sale
- T.C.S. Baffled sump -what's it worth?
- set of saphire cosworth wheels
- Escos exhaust
- cossi 2wd discs
- A few bits for sale
- Airtec RS500, 70mm cored intercooler
- Brand New Escort Cosworth rose jointed rear strut brace
- Cosworth recaro foam bolster
- Ahmed bajoo track springs new
- Escorth Cosworth Breaking 520BHP Oppliger Semi Cut Gearbox
- 205 block an head complete with crank and cams
- Sold
- Sierra Cosworth Gaz Gold coilovers, nearly new
- Escort cosworth abs sensors
- sold
- Gaz Golds & other parts(Pictures added)
- Big clear out time - Updated
- T34 turbocharger & -31 actuator
- moonstone 3dr front bumper... sold
- Fully Trimmed Group a Escort Cosworth Shell
- Supra diff and full mk Motorsport fitting kit
- Gas flowed 2wd cylinder head, gripper diff, turbo and big brake kit NEW PRICES
- RS Gel Style Wheel Centres 60mm Rondell etc
- Mint raven cloth front and rear seats £180 ono
- Alloy brackets for ap brakes
- Alloy brackets for ap 6 pots
- Shiney under bonnet stuff , pas tank
- 18 x 8 OLD STYLE Compomotive Mo's in Black, New Pirrelli P-Zeros
- cosworth Yb roller barrel billet MIS inlet manifold
- Rs 3 spoke
- Escos steering boss, Solid beam mounts, strut brace, 17" wheels (price drop)
- Pair of standard small turbo Escort RS Cosworth boost hoses
- Grey injectors sold sold sold
- T61 turbo, tube maifold, ext wastegate
- T5 Hydraulic clutch conversion nose and cylinder
- 200 block std bore + std-std crank + rods
- es cos/saph 4x4 5 stud hubs
- Cyber Weekend sale Now On... Shop till your mouse breaks!
- Breaking stage 3 white 2wd sapphire cosworth
- sold
- cossie bits bumper 4x4 bonnet bumpers lots of lil bits shell
- Breaking Escort Coswrth WRC LHD
- Puma Cosworth WRC Fully Trimmed Shell
- 200 Block - STD
- ****ALL SOLD****
- Escos rear lights, window regs and sunroof skin
- Airtec 70mm RS500 style intercooler.
- -31 Actuator £20
- Main & Big end breaings, Turbo smart E boost 2
- Shot Peened YB Robs and ARP Bolts
- 1 front gaz gold coilover and compression struts
- focus rs brakes
- 4wd bells
- RS500 Fog Grilles £75 + FREE POST - price reduced
- Cosworth x 4 grey bosch injectors
- 480+hp Mark Shead MAD Built YB Engine
- 2wd 1988 breaking cosworth
- Various parts
- Escort Cosworth roll cage
- FOR SALE..Escort cosworth alloys with tyres
- 20% Off ABSOLUTELY EVERYTHING - This Weekend Only.
- 4x4 saph good spec breaking
- a few saph cos parts for sale...
- N.O.S genuine 3 door tailgate
- Breaking stage 4 magenta 4x4 sapphire cosworth
- 3dr/RS500 Sierra Bootlid £90
- cosworth chrome crank pulley
- Mongoose back box
- sierra cosworth group a parts for sale (insert ratings added)
- 5 Bar Map Sensor, 13 Row Oil Cooler & CNC Top Mounts
- Escort RS Cosworth big turbo badges, brand new, genuine Ford...
- Bd10 ex cam & eibach rear springs-2wd
- Loads of Cosworth parts - few new parts added
- cossie shell£150 lots off bits need gone asap
- parts
- Cosworth shiney bits
- 2WD 330mm Cossie Brembos
- Leathers/RS500 lip/ front bumper
- Cosworth 7.5" LSD diff's & new 3.9 CWP!
- T38 TURBO new build, siemens deka 55lb injectors
- 1989 sapphire cosworth breaking
- clearout
- Breaking sierra cosworth 2wd.
- SCS 6 degree beam and a gripper diff BOTH SOLD
- SOLD please delete***
- 3dr cosworth tca arms sandblasted for sale
- 2wd Saph parts clear out
- Sold
- cosworth breaking offers on all bits need it gone
- sold
- 4x4 plenum New price
- cosworth rs ecu cover
- T34.55 turbo for externally gated
- 7.5 gripper diff from bara motorsport
- l8 ecu , ign leads, abs ecu, mint gear gaitor
- Samco powerflex goodridge
- 6 pots
- Bits and bobs lying around....
- clear out offers on anything
- Group a sierra square rear beam (big price drop)
- 3 door quarter light glass
- Siemens low impedance 83lb injectors £240 or best offer
- Cosworth Gearbox T5 2wd
- Few 4x4 escort/Sierra cosworth bits
- cosworth breaking 2wd white
- Cosworth parts.. Big disc kit added 22/10
- chrome tat
- bushes
- 2wd blue samcos
- Air injectors & bracket
- Ford Sierra parts for sale
- cosworth parts
- ***24V COSWORTH JENVY TB'S 48's***
- sapphire gen ford inner wings
- 2wd sierra cosworth disks and calipers front and back
- bushes
- Another little clear out
- AP 362mm brake kit 4X4
- Turbosmart E boost 2
- YB Parts, Pistons, Gaskets, Tps, Spec r.
- stripping a moonstone blue 4x4 saph, lots of parts avalable
- Supra turbo LSD
- Cosworth yb newly built engine, escos breaking
- htt t25 escort inlet manifold
- BD14 and BD10
- t34 ar .55 247 maram shaft
- brakes
- sierra cosworth inner wings new
- n.o.s sapphire slam panel
- Please Delete
- 2wd konis + other suspension parts
- Twin scroll Borgwarner EFR 7670 1500 miles from new!!
- Sapphire Cosworth Front Bumper
- Sapphire Morette Headlamps
- sold
- ford racing gauges
- Tailgates and passanger doors-
- number plate
- Escort Cosworth in Two Halves...
- Cosworth Turbo Cooler, 13 Row Oil Cooler & CNC Top Mounts
- Brand new cosworth yb 4x4 crank shaft £1000
- Various Cosworth parts for sale
- Cosworth parts for sale offers accepted
- pinto turbo set up for sale!! including full exhaust system modified to fit
- 3dr Cosworth parts for sale...
- Big spec Cosworth YB engine
- group a dumpvalve..
- Aquamist 2s Water / Methanol Injection System w/MF2
- FOR SALE...Escort cosworth alloys with tyres
- Various cosworth parts
- cam pulleys, 4x4 alloy header tank
- complete sapphire cosworth recaro interior
- Sapphire rear strut brace
- Cosworth braided engine loom! - SOLD!
- 2wd oil feed pipe
- ford sierra foam backed headlining material
- sold
- 2wd mongoose 4inch back box
- 7.5 2wd welded diff
- Oppliger exhaust manifold
- Escort Cosworth Air Bag...
- Cosworth parts
- Garrett -34 actuator
- GT series to Cossie down pipe adaptor
- Sierra cosworth 3dr heatshield...
- es cos bits
- GT35/82 turbo by CR turbos
- Escort Cosworth parts
- Escort Cosworth panels(new)
- Cosworth turbo pipes
- Recon 2wd 7.5" diff 0 miles **pics added**
- RS500 Cosworth T4 Turbo Fully Rebuilt By CR Turbos
- Sapphire doors....
- New Siemens 3102 55lbs injectors
- T3 turbo and 803 injectors ( now on eBay )
- Brand new RC engineering 1000cc injectors
- Roll cage
- Clearout !
- 2x braided fan looms on ebay
- Apexi AVCR boost controller and Apexi SAFC
- GT3071 Turbo
- volk rays engineering 19" 10.5j +24 alloys 295/30/19 r888 tyres
- saph recaro seats
- Spec-R parts
- Single DIN triple gauge holder + oil pressure gauge
- Spec R oil cap to suit 4x4 cam cover.
- Siemens Deka black 650cc injectors
- 3.9 dropgear, wrc breather, als throtlebody
- Breaking Moonstone 3 Door Cosworth 500BHP AP 4 Pots brakes
- Fully Trimmed Escort Cosworth Shell
