PDA
View Full Version : Ford RS Cosworth Parts for Sale
Pages : 1 2 3 [4] 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54
  1. Ford Escort RS Cosworth useful bits
  2. Wanted
  3. 2wd sierra cosworth avo coil overs,compbrake compression struts and tca's
  4. T5 clutch central release bearing and spacer
  5. Cosworth goodies
  6. 3 door front indicator (escort COsworth) slight damage
  7. Cosworth 2/4x4 strut top bushes and inner TCA bushes
  8. Compomotive mo6 18x10 18x9
  9. DBW throttle body and new connector
  10. Genuine RS500 Front Splitter
  11. Wanted
  12. Wanted
  13. Wanted
  14. 3 door sierra
  15. Turbosmart supersonic adjustable dump valve
  16. Hi spec front and rear escos/saff 4x4 brake kits
  17. Carbon strut tops and proper aero wipers for sierra
  18. Cosworth - Skyline converted gearbox
  19. 4x4 sapphire front antiroll bar
  20. sold
  21. Cosworth external wastegate set up
  22. Brand new AP RACING front and rear brake kits!! Price drop!!!!
  23. t34 turbo price drop
  24. brembo calipers and brackets
  25. Sold
  26. Sold!!! Please delete
  27. Sold
  28. K&N with elbow , Headlights gizzmo boost controller
  29. Stuff for sale
  30. clutch
  31. Rebuilt T5 Standard Ratio
  32. Quaife 71/2 rear diff
  33. Mk1 Sierra parts coming to ford fair
  34. 2wd Cambelt Cover
  35. fan loom
  36. Pectel T6 new
  37. Pectel Monitor
  38. Pectel Raychem loom new
  39. £250 for the lot! ;-) Cosworth parts.
  40. wilwood brake set up - 2wd saff
  41. Yellow injectors wanted
  42. Ecos wrc grill
  43. Ecos wrc rear spoiler
  44. Ecos wrc bumper
  45. Ecos morettes £200
  46. 3dr cosworth front bumper now with pics
  47. Mk motorsport adjustable axle 7" (LOWER PRICE)
  48. Big Spec Engine - What's it Worth Thread
  49. Sold please delete
  50. full carbon fiber escos bonnet
  51. konis, springs, 4x4 steering wheel, door mouldings
  52. 2wd cosworth parts offers on remaining bits
  53. siemens 83lb's greys l6 ecu
  54. COSWORTH PARTS pf09 and other parts
  55. Who does real carbon bits for sapphire's???
  56. ecos parts
  57. 4x4 Cosworth Flocked Dash & Trim bits
  58. sierra cosworth parts for sale, some new
  59. 8 injector ecu, level 6
  60. SOLD!!!
  61. Escort Cosworth race car breaking
  62. Rs500 style intercooler for sale
  63. 2wd original exhaust system by SOHAM
  64. 2wd Cosworth Koni Shocks
  65. Whats it worth 4x4 steering wheel and door mouldings
  66. RS500 fuel rail - what's it worth?
  67. Rs500 parts for sale
  68. ap racing 4 pot 330mm rear brake kit 4x4 cosworth
  69. Sapphire front splitter
  70. Spec-r dump valve [near new]
  71. What are they worth - SOLD SOLD
  72. now sold please dlete
  73. Escort Cosworth armid beam
  74. Ambers, Bosch 044 fuelpump brandnew
  75. saff cosworth 4x4 propshaft donut needed!
  76. mt75 4X4 gearbox, needs rebuild and a 2nd 4X4 box with no bellhousing
  77. 3DR downpipe
  78. Genuine weber PF09 throttle position sensor
  79. Rs500 genuine rear beam freshly powder coated
  80. Spec-r dump valve
  81. FOR SALE Escos 4x4 Oppliger big tooth G/box
  82. RS Cosworth Seats
  83. Saff rear panel
  84. Massive spec engine for sale.... 500+hp
  85. T-5 Bell housing
  86. T34-63/ front diff / inlet other bits
  87. Escort Cosworth Automotive Unlimited Extended Front Shafts
  88. Hydraulic handbrake
  89. Cosworth Group A T34 Maram Shaft Turbo
  90. ford sierra cosworth 70 amp alternator new for sale
  91. Breaking 2wd Magenta cosworth
  92. Cosworth alternator heat shield
  93. sierra Cosworth various, 0044 pumps,Gpa coil, chrome, polys,throttle body,cables,abs
  94. cosworth parts, wasted spark leads, twin amps, bell housing
  95. Flocked Dash, door cards, console and sill trims (Black flocked)
  96. Sierra electric sunroof motor
  97. new stainless ignition amp bracket
  98. Cosworth parts inlet, loom, elbow
  99. YB Engine breaking
  100. Brand New Horn Push Centre to suit RS3/4 Spoke Steering wheel
  101. 2wd Sierra Cosworth 7.5" LSD rear diff in good condition.
  102. Escort Cosworth Rear Callipers Complete
  103. 2WD Adjustable Compression Struts
  104. More bits..
  105. M I S 8injector inlet
  106. Weber injection components..
  107. Few Sierra and Escort Cosworth Parts For Sale
  108. Brand new garrett gtx3071r
  109. Brand new BD8 4wd Newman Cam £80 + post
  110. 3dr cosworth front and rear seats
  111. *****PRICE DROP***** Silicone hoses.
  112. Breaking 4x4 sierra cosworth h reg
  113. Wanted......turbo
  114. cosworth 3 bar map sensor Magnet marelli weber
  115. 803 dark greens and chip
  116. Cosworth cam cover powdercoat end red
  117. *****NEGOTIABLE PRICES*****Tonnes of 2WD & 4X4 Cosworth parts.
  118. Siemens 83lbph Fuel injectors. Low Impedance.
  119. Few cosworth bits, clear out
  120. Wanted Good set of bosch 803's and genuine MAGNETI MARELLI 3 bar
  121. Sapphire pedal box
  122. 2wd cosworth rear calipers for sale.
  123. Pace intercooler 4x 803s stage 3 chip
  124. Freshly Rebuilt Quaife Cosworth 4x4 Big Tooth Gearbox
  125. Mint t34.63 & oil catch tank
  126. 4x4 vented bonnet
  127. Cosworth parts - updated list.
  128. sierra 3dr rear roll cage (sold)
  129. hubs
  130. Focus RS Cosworth Converted Rolling Shell
  131. escort cosworth carbon grill £30
  132. Efr 7670 turbo
  133. Sold please remove*
  134. Sierra 3dr Cosworth replica. Turbo Technics 2.8i.
  135. konis
  136. Carbon cambelt cover SOLD
  137. Ecos fronthubs 4x4 tca 4x4 konis and springs
  138. Sierra cosworth front wing mouldings
  139. MK Supra Diff billet alloy cover
  140. Autronic sm4 ecu and carlooms uk custom loom.
  141. Twin scroll exhaust manifold, 45mm wastegate, screamer pipe.
  142. GTX3071R turbo LOWER PRICE
  143. Custom hydroylic handbrake and bias valve
  144. MT-Motorsport Cosworth Rear Diff Mounts
  145. MT-Motorsport Supra Diff Covers
  146. Set of 12 Torx head bolts/screws
  147. Escos Transmission - Gearbox, Strenthened Front Diff & Props - From 39K miles Car
  148. Rs500 alloy airbox
  149. 2wd cosworth 4 pot ap brake kit 330mm
  150. cosworth parts for sale
  151. Carcoon (3dr Cossy)
  152. Escort RS Cosworth Standard Wheels 16x8"
  153. SOLD
  154. SOLD
  155. Aeromotive A1000 Fuel System - Reg, Filter, Fittings - All New SOLD
  156. CR Turbos T38 - SOLD
  157. Sapphire dark trim parcel shelf
  158. sapphire cosworth window seal (ones that bubble)
  159. Cosworth exhaust manifold extension piece with external waste gate take off
  160. Cosworth stainless exhaust manifold with external waste gate take off
  161. Std/std 4x4 crank
  162. 200 block
  163. Garage clear out
  164. 3" escos exhaust
  165. 6 degree beam pictures added
  166. Borg warner turbo ***SOLD***
  167. 3dr Sierra Cosworth Bootlid moonstone £50
  168. 4 x Genuine Brand New Sierra Sapphire Door Skins - Will sell seperately
  169. Cossie parts. silicone SFS Hoses, sensors, mounts ,etc. More added 19.5.15
  170. extensive list of WRC and RS2000 Maxi/Kit car part, new and used.
  171. Pro alloy intercooler
  172. Escort Cosworth Group A/WRC Carbon Fibre Door Mirror
  173. Quaife T5 5th gears (pair of)
  174. MINT 3 spoke steering wheel
  175. Focus Cosworth 4x4 Full Project - Complete or Breaking
  176. Bosch Dark Green 803 Injectors £SOLD
  177. SOLD
  178. Brand New AIM MXL Strada Dash - Boxed £SOLD
  179. Pectel T6 and Brand New Braided Motorsport Loom SOLD
  180. Brand New Garrett GTX3576 - Top Spec £1350
  181. Garage clearout - Updated - last few bits
  182. Bit naff Cosworth aftermarket front kick panel speaker pod thingies.
  183. ATL 60l fuel cell, Brown & Miller lines 044 pump
  184. 2wd Cosworth left hand drive body shell - no rust
  185. Freshly refurbed 2wd prop.
  186. Cosworth parts
  187. New Cosworth YB Steel Cam Pulley Bolts x2 With Built In Flange
  188. Escort Cosworth rear arb and billet links.
  189. "Whats it Worth?" Some Cosworth parts what I have left
  190. FULL MINT SET OF RS500 WHEEL LOCKS and KEY[[ now sold]]]
  191. 3dr alloy cam cover & bonnet raisers
  192. new sapphire grey dash for sale;rare'
  193. Denso Iridium IK27's BNIB ***SOLD**
  194. Cosworth t5 bellhousing
  195. Few saph parts for sale
  196. 2wd Rear Diff £225
  197. Cosworth parts BD10 and BD14 cams ecu wheels and cam covers
  198. Mk2 escort rs2000 rally shell
  199. .
  200. Escos small turbo plenum
  201. Siemens 83lb blacks
  202. cosworth parts
  203. sold thanks
  204. Mk2 escort shell whats it worth???
  205. Toucan Touchscreen, Stack Dash, Pro alloy tanks, Seats, Prices dropped.
  206. Private plate E 16V RS
  207. Roll up roll up cosworth odds n sods cheap.
  208. 83lb seimens injectors for the Cosworth[fl11405] injectors
  209. 15% Off All Anembo Engineering Webshop Products
  210. Cosworth Group A Throttle Brackets WRC
  211. 2wd cossie parts fuel pump, cradle, tca's calipers and carriers
  212. Motorsport Developments Spring Sale - 15% Off Everything.
  213. Cosworth fuel pump cradle bushes/mounts
  214. T5 gearbox for sale
  215. 4x4 front hub brand new
  216. Cosworth TWIN Ignition Module Bracket kit with RS logo!
  217. Ecsos Braided fuel lines c/w An-6 Goodridge fittings
  218. 3dr cosworth fuel pump cradle for sale
  219. sold..
  220. ecos parts for sale
  221. Turbosmart eBoost Controller ***£150***
  222. ASNU 1100cc High Impedance Injectors ***SOLD***
  223. Hart Inlet with Anti Lag Air By Pass ***SOLD***
  224. BRAND NEW EsCos alloys X 2
  225. Immaculate RWD Sapphire cloth interior
  226. Number plate. F4T YB
  227. Omp Sierra strut Braces
  228. Cosworth 2wd clearout
  229. Turbonetics GTK550 turbo WITH PICS NOW Lower price!!!
  230. 4WD big valve head WITH PICS NOW
  231. Nikasil block, Arrows crank, rods, pistons WITH PICS NOW
  232. 3dr cosworth parts for sale
  233. Cosworth T5 gearbox for sale - No speedo
  234. Ford Racing Gauges white face X 3
  235. Sapphire Cosworth Rear Ambers
  236. Cosworth Parts For Sale / Escort and some 4X4 Saph - Updated more bits 04.04.15
  237. Gauges - Boost / Fuel / RPM
  238. Cosworth T5 dog box for sale.
  239. For sale wilwood 4pots front setup 2wd
  240. Very good Engine parts!
  241. Cloth for 3dr recaro front seats
  242. sold
  243. Corbeau revenge carbon fibre seats
  244. 4x4 saph shell - what's it worth?
  245. immaculate retrimmed 4 spoke steering wheel.
  246. SOLD thanks
  247. Private plate C20 SWH
  248. Sierra cosworth RS500 inlet manifold
  249. Cosworth parts
  250. Escort Cosworth Boot Lock and Rubber
