- Washer bottle
- Koni Front Coilovers
- Stg1 l6 ecu and injectors
- Spec R cambelt cover + K&N Filter + .48 Housing
- escort cosworth rear cosworth badge
- 205 block
- Free 2wd rack, needs recon
- 4x4 parts for sale (fuel rail/intercooler/front prop)
- SOLD
- jenvey 70mm throttle body
- brand new exhaust housing
- p8 pectel board
- full msd ecu ,loom coil pack etc
- Rs500 splitter strengthening hockey sticks
- SOLD
- Quaiffe 7.5 2wd diff with 3.92 crownwheel and pinion
- Mainly 3dr Parts For Sale
- 3DR Sierra Cosworth parcel shelf
- 3 door/ Escos front foglights, SOLD!!!
- Koni Front Strutts With Springs 2wd
- focus rs coworth shell £3500
- Twin air injectors motorsport
- Spec r cam belt cover/76mm cold side pipe
- Cosworth L6 ECU
- Cosworth parts
- ford racing oil pressure gauge and fittings £40 posted SOLD
- 4x4 Front Diff...
- ryans loom for cossie
- Rocker cover/3 Spoke steering wheel
- Few Cosworth bits
- 3 door parts
- 4x4 sapphire cosworth rolling shell white
- brand new quaife thick wall atb, 2wd head 139.10 mm
- sold please delete
- t5 2wd b and m quickshift
- Sapphire Cosworth 2wd Parts Sale
- cosworth 4x4 standard mahle pistons
- sold - please delete
- 2wd engine
- RS500 bits
- Adjustable TCA's
- Small turbo Escos engine
- ***SOLD*** Escos 909 shell
- Garrett -31 actuator ***NOW SOLD***
- stack boost gauge
- L6 ECU
- Various cosworth parts, suspension, morettes.
- Load of parts Escort/Saph 4x4 More Added 24/6
- T34.63
- wasted spark kit
- 4x4 cosworth sump
- Secs monitor
- Concours Saff Cloth Recaros
- Cosworth Engine and box in Ireland
- L8 ecu with pectel board
- New t3 turbo repriced
- cosworth parts for sale
- 2wd Prop on eBay
- t34 .63 , green injectors , group a head gasket
- 2wd big wing sump
- Few cossie odds and ends.Now with pics.
- sierra rs cosworth dashboard £25.
- bushes
- 4X4 Cosworth parts
- gt 30 turbo external waste gate and trouser section
- escos bits on the bay
- Spec R 4WD Header tank and Group A beather
- t28 small cossy turbo
- random cosworth engine parts
- Sierra cosworth foglight surround
- MAF - Airflow meter for 24v 2.9 cosworth + intake bellows
- Sierra polybush top mounts - front
- 2.9 24v Cosworth Manual Gearbox mt75 + clutch
- kn large cone filter
- 2wd water pump
- ford racing 60mm oil pressure gauge.*sold*
- Wing moulding
- IAW Monitor cable
- 3 X cosworth cambelt covers (2wd)
- Escort Cosworth Morettes + Motorsport Leads
- Forge header tank 3 door / 2wd ***SOLD***
- Cosworth inlet
- P8 ecu prices?
- new 4x4 cosworth in tank fuel pump
- L6 ecu (pics added)
- Aquamist 1S
- Lots of Excellent Cosworth Parts For Sale
- Saph cossie heater matrix
- SOLD COSWORTH 4X4 ENGINE, T38 TURBO, MSP COIL PACK, AIR INJ, MSD MAPPED 450+bhp SOLD
- msd chip for t34 and 803 green injectors *SOLD*
- Creative Carbon Cambelt Cover - SOLD
- standard ground crank
- Very trick yb engine parts
- G-reg 2wd saph-breaking!
- **Door panels, Boost pipes, Header tank, Shift light**REDUCED
- Read Here If You Would Like To Win A Chip...
- Saff Alloy Wheel / Carpet / Injectors
- head gasket,valves and cams for sale
- couple of bits
- Free Cossie Odds and Sods
- konis
- 3Bar Sensors,turbotimer,air charge monitor,rear bearing
- Cosworth 909 parts
- external wastegate and manifold
- Lambda genuine narrowband
- cossie cam cover + front grill
- 4x4 cosworth satin black forge header tank
- chrome fuel rail cover...kent vernier pulleys...green inj...arp head kit...for sale.
- cosworth wilwood superlite 4pots calipers
- 3M Di-Noc Carbon Fibre Wrap
- Sierra and Pug 405 Haynes Manuals
- 17 inch Raceline RL7's, 4x4 Sump and 4x4 Diff...
- 2WD breaking, Konis, ABS, race seat, loom, etc. south London
- 2WD 3 door engine (SOLD)
- brand new sapphire cossy bonnet vents, what they worth?
- What's it worth L8 wasted als launch MSD....
- saff leather
- Saph cos front grill
- cosworth interior sound deadening !!!!!
- few bits
- Bailey dump valve with aeroquip hose & fittings
- Bailey turbo damper /3dr stainless grill bars/ 2wd heatshield
- brand new escort rs cosworth gearknob!
- 3dr hubs and adjustable tca's
- racetech gauges
- sierra g/f mudflap
- Genuine rs500 inlet complete,super 8 l8 ecu and sub loom
- Bosch 044 Fuel pump adaptor/fitting
- Adrenaline Motorsport Stage 3 Beam complete
- cosworth exhaust manifold
- 4wd rear calipers
- Quaife thickwall atb
- 3 door body kit for sale sold sold
- Aeromotive big hp fuel pump and rs500 fuel rail for sale
- few cossie bits, clutch, WI, cam,
- escort cosworth bits REDUCED!!!!
- Gauges
- R&D MT75 6 speed dog box - RWD
- reconned rear 4wd shafts and escos dash clocks
- 3dr cossie parts
- cosworth boot, water Pump, inlet,
- Small turbo Escos parts
- ALL SOLD!
- Sapph Morettes
- complete mk1/2 escort cossie engine etc ready to run.
- AP Racing CP6600 caliper brake pads
- 3 door fuel tank
- bilstein 909 tarmac spec front struts
- 2wd bits, escort s/s exhaust
- Light Blue Injectors, 3 Bar, 4x4 Wiring Loom And 4x4 Drilled & Grooved Discs.
- escos msd 380+ conversion complete £OFFERS
- Secs monitor
- Stainless 2wd Turbo oil feed pipe+Bailey turbo filter + union SOLD!
- Rebuilt mt75 gearbox for escort or saff 4x4 cosworth SOLD
- Red Samco hoses for 2wd Sierra cosworth
- Mallard escos breaking
- passenger side front jacking point cover
- Escort cosworth big winged sump
- Cosworth rocker cover £45 Inc Screw cap and breather tube
- 3dr / 2wd / 4wd Parts
- Brand New Single rear caliper 4x4 passenger side
- Mint Magenta rear passenger door for saff
- Cosworth hoses, lights, swirl pot, d/v, filter, and 3dr locks caps & key
- small turbo escos chip
- xr4i boa breaking (lots of rs goodies)
- COSWORTH PARTS (2wd/3DR) MORE PARTS ADDED
- Various Cosworth bits 200 block etc
- ap 5200 type calipers....brand new..£250
- Cosworth 4x4 Mahle pistons .
- Morette Twin Headlights AVAILABLE AGAIN
- Fast ford Performance ford mags free for collection
- Escos copy whale tail spoiler
- Few bits inc chip for greens
- Set of Greens: £100 posted
- Leda Remote Can Suspension 4x4
- last bits left all on e bay
- Dark greens,dual stage boost,ecu+330hp chip +
- Silver Saph cosworth, h plate shell/interior etc---- BREAKING
- fuel system set up - 044 pump, goodridge lines, aeroquip
- airtec intercooler
- 2wd scorpion exhaust
- As turbo heatsheild
- ABS sensors
- anyone got a Throttle cable & Bracket cheap
- Sapphire 4x4 being broken
- msd l8 380 with als and lc ,injectors £500
- Sold, please delete
- konis and other bits
- YB Rocker cover
- Cosworth YB Head
- loads of 3 door parts £150
- Rear coilovers, GGR front shafts, hydraulic clutch - pics added
- cosworth tubular manifold
- Escos Tool Kit & Alloy rear hubs
- SOLD
- Escort Cosworth intercooler modified to fit Sierra
- Sapphire Cosworth Owners Hanbook 1992
- Pro Alloy Radiator
- Cosworth plenum for sale
- Bargain job lot of 3 dr bits!!!
- T3 Turbo- Just Recon'd By CR Turbo's
- Please remove this thread. Nothing is for sale now due to idiots!!!!!!!!!!
- Saff Raven Leather...£200 !!!!! SOLD SOLD SOLD SOLD SOLD
- Swirl pot
- bosh greys x4
- Sold
- cosworth fuel rail with jic fittings and reg
- 3dr rolling shell..
- Green 803 injectors
- tt t35 stage 3 turbo
- Sold please delete
- Mountune cam pulleys
- How much should i ask for????
- cossie bits
- Set of 4 Bosch 403 Grey Injectors SOLD!!
- 2x's level 6 chips
- Bailey Header Tank, Mirror Image Tank, PAS Tank, GT30 K&N Trumpet
- Brembo 325mm Front brakes
- AN6 -6 Goodridge Teflon Lined Stainless Hose 6m
- A few items - Ign Amps, bracket and guage holder.
- Alloy crank pully Hydraulic Cam Followers
- Our New Turbosmart Product Range!
- Free 2wd bonnet to whoever collects
- Sabelt Racer2 Bucket Seats
- Motodrive Bucket seats and harnesses NEW
- Race Tech Dash 2 with Omex link looms & trigger sensors
- A few bits
- Cosworth diff £80
- cosworth 2wd ext wastegate setup
- Stack Boost gauge
- Cosworth parts, Siemens 55lb injectors, RS500 cooler etc *PRICES REDUCED*
- Saff carbon bonnet and boot *Prov Sold*
- Cosworth 2wd exhaust
- esc cos parts
- saftey devices full cage
- Brand new 2wd rear calipers
- turbonetics spr60 good for 600bhp
- Escort Cosworth Eibach Rear Springs...
- L8 ecu with coil pack driver,cloosed loop,anti lag,launch control
- few 2wd bits and 4x4 bonnet
- what's it worth post....gaz coilovers
- Brand new MK1 Cosworth parts
- WRC Breather - Sold.
- Morettes and bucket seats
- -6 Aeroquip Teflon Hosing
- Escos eeciv small turbo inlet
- 7.5" Rear diff with shafts.
- poly sport bump stops sierra cosworth rear.
