PDA
View Full Version : Ford RS Cosworth Parts for Sale
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 [28] 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54
  1. sierra cosworth 2wd loom and ecu
  2. 2wd manifold
  3. Saff cossie Flocked dash *reduced*
  4. gpa conefilter heat shield cossie
  5. 4 brand new wheel arch liners saff cosworth
  6. Complete Cosworth 200 Block - Cracked
  7. 2wd Cosworth parts for sale some new prices
  8. P8 ecu + MSD chip
  9. Set of Dark Blue Injectors for Sale
  10. 4x4 Cosworth Alternator, Power Steering Pump and Front Diff...
  11. 3dr cosworth standard headertank
  12. 2 WD Sapphire Cosie just in for breaking
  13. 200 engine block
  14. Track tyres 5x 205/50/15Yokohama Advan AO84 (Toyo R888)
  15. Rouse rear spoiler
  16. bosch motorsport 044 fuel pump brand new
  17. R+d six speed dog box
  18. 4WD Barra / Mullit Box
  19. Cosworth cam shafts...standard
  20. Touring car slicks
  21. Drilled and grooved discs
  22. Bara Box for sale
  23. WANTED: 2WD Gearbox Dust Guard
  24. harvey gibbs gpa rally engine
  25. new cosworth bosch 023 in tank fuel pump * SOLD *
  26. Level 8 ecu
  27. AP organice clutch + plate
  28. Cosworth AS Heatshield.
  29. saph complete hose set wanted
  30. Unused Pro Alloy RS500 Intercooler +T34.63
  31. 414bhp Harvey Gibbs Cosworth Engine (Spec Added), L8 ECU, GP A Coil and more...
  32. SOLD
  33. Sierra coss 4x4 turbo to header tank water pipe
  34. rocker cover caps
  35. mongoose full Exhaust system 3". Offers.....
  36. RS500 T4 turbo
  37. Ball Bearing T38 - Almost new
  38. bits for sale - mint bonnet -arch liners-lights -smoked tail lights
  39. 3dr cosworth bits ( couple more bits )
  40. cams
  41. small turbo escort cosworth grp a cone fiter
  42. 4WD & 2WD Saph Cosworth parts (Updated 19.5.2010)
  43. Sold
  44. Escos trims, map sensor brackets, FRS randoms
  45. sold - please delete
  46. siemens 850cc injectors
  47. **Lots of 3DR cosworth parts for sale** !!05/10/09 20:41UPDATE!!
  48. WANTED..saff outer door trims!!!!!
  49. Cosworth Head 138.8mm, 24mm Inlets, BD10's & Piper Pulleys **SOLD**
  50. [New Product] Escort Cosworth Fuel Filter Brackets
  51. saph odd's and sod's, interior plastics etc
  52. Wanted Rs Cosworth 4x4 head
  53. door cards,late spec 4x4 cosworth
  54. Scorpion 3 inch exhaust system (4wd)
  55. t3 turbo
  56. cosworth green top rocker cover
  57. 200 block 4x4 head T34.63
  58. Tarox 6-pot 335m big brakes for 2wd cosworth SOLD!!
  59. tremec tko 600 pics added sold :-)
  60. B&M short shift 4x4 Cosworth
  61. ***FREE*** Complete 4x4 saff car loom + Engine Loom ***FREE***
  62. specialised car covers saff indoor cover
  63. Cosworth Parts Turbo Technics T38 and loads more
  64. Flint grey sierra cosworth bits
  65. Classic Addition Outdoor Car Cover for sale
  66. Cosworth Plug leads for sale
  67. 5" Exhaust for a 3dr Cossie
  68. Ported head, 83lbs blacks,and 2wd prop
  69. Rear Koni Shock Absorbers
  70. pj motorsport blue boost hoses
  71. cosworth 4x4 exhaust..
  72. 2wd calipers
  73. 2wd alloy sump - £50
  74. Ecu,throttle body,calipers,ispv,crossmember,etc
  75. L6 ecu + 2wd loom £150 !!
  76. 3 door cosworth front bumper genuine
  77. sierra cosworth 2wd shell
  78. Genuine 4x4 O/E TCA's
  79. New Ford Cosworth GpA Front Anti Roll bar Mounting bracketrs
  80. 4x4 Bonnet and Vents
  81. genuine rs 500 front bumper and whale tail
  82. 55lb siemans brand new £200 posted
  83. dome built200 block long studded engine
  84. DOME Big tooth 4x4 Gearbox
  85. siemens 750cc/72lbs.....
  86. 3" / 76mm mandrel bends + silicone hose, boost hose exhaust ect
  87. sierra digi dash
  88. 500bhp MA.D engine and autronic sm4 for sale
  89. greys, chip, fuel rail plus reg £140 deliverd
  90. cosworth 2wd power steering rack,almost new
  91. cosworth abs sensors and abs ecu
  92. cosworth 2wd loom and ecu
  93. t34 maram shaft +escos bits
  94. konis Gas dampers REDUCED, OPEN TO OFFERS.
  95. Bailey Breather Tank and Esc Cos Intercooler...
  96. Super P8 ecu
  97. GT30 hybrid, int. gated (SOLD)
  98. Lots of small parts for Cossies
  99. few blue boost hoses , cloth door cards and 4x4 saph bonnet
  100. cosworth saff parts!
  101. 200 block
  102. Sapph Cosw Magnex Bk Box
  103. Sapphire cosworth front side skirt clips
  104. big spec saff breaking!!! ##CAR SOLD##
  105. 200 Stainless Steel Lambda Sensor Bosses M18 x 1.5 **SOLD**
  106. sapph pace intercooler
  107. gr a coilpack and leads
  108. Brand new genuine Ford RS500 lower rear spoiler
  109. some parts on ebay
  110. 2WD Four pots and other bits
  111. Cosworth leather inetrior
  112. Ex WRC Prodrive Alcon 4 pot 2wd cosworth Brake Kit
  113. How Much For A Level 8 ECU
  114. Garrett GT3076 turbo
  115. Autronic SM4 ecu and LS1 individual coils
  116. pair of rebuilt escort cosworth rear driveshafts £100
  117. Sold sold sold sold
  118. Sapphire carbon fibre boot spoiler
  119. Genuine Garrett Rs500 T4
  120. Sapphire cozzie drivers seat runners
  121. Ford oval stickers
  122. Carbon cambelt cover 2wd
  123. shiney bits
  124. RS 500 turbo Damper, Stack Boost Gauge , Actuator Brackets...
  125. ap 4 pots
  126. New ap racing floor mounted pedal box
  127. 2wd avo coilovers brand new
  128. sold !
  129. 2wd avo coilovers SOLD
  130. SFS hoses and MSD antilag/launch control - couple more bits
  131. 3dr cosworth A pillar twin guage pod
  132. Ford racing fuel and volt guages
  133. Koni Sport shox & springs for 2wd Cosworth
  134. Dark Green 803s - Sold!!
  135. 3 Door Parcel Shelf
  136. saph grey cloth interior 4sale!!
  137. normad lites
  138. airtec 500 intercooler and radiator
  139. 4x4 "hi-spec" front big brake conversion
  140. greys, and fuel rail
  141. complete 200 block wanted
  142. DARK GREEN 803 INJECTORS x 4. Plus Chip
  143. Cosworth Parts clearout 330 Big Brakes,Collins Actuater,ss filter shield,Distributer
  144. lowering springs
  145. escort cos standerd lites
  146. escort cos spoiler
  147. escort cosworth rear window's
  148. 2WD calipers,grooved discs, clear indys and 4x4 discs!
  149. Escort Cosworth rear 1/4 window seals
  150. Apexi AVCR
  151. Garrett GT4088
  152. Carbon fibre cambelt cover "SOLD"
  153. sold
  154. Freshly Painted Rs Cosworth Cam Cover Open To Sensible Offers?
  155. Leather Interier Mint !!!
  156. 3 DR shiny bit's, washer bottle, acc cable bracket
  157. Cosworth Turbo Heat Shield
  158. EX touring car part - DJR big wing sump.
  159. Base model headlight O/S **Brand new**
  160. cossie bits
  161. Escort cosworth breaking !!!
  162. 3DR Parts
  163. sapphire cosworth cloth rear seats
  164. cosworth crank /+ spares
  165. cosworth 4x4 Oppliger Motorsport big tooth gear kit
  166. Ferriday stainless sapph dials
  167. 4x4 cooler
  168. Rare saff cosworth trim with new pic
  169. Brand New Sapphie Cosworth Mouldings
  170. quick release .63 housing with pics
  171. All sold
  172. The Last of the Rs Cosworth parts "Cheap to Sell" ANY OFFERS??
  173. 4x4 cozzy exhaust ss
  174. End of Show Season SALE
  175. Gt4094r turbo for sale. Brand new
  176. BRAND NEW RADTEC 60mm CORE RS500 INTERCOOLER £275.00!!!! (now sold)
  177. K&N grp A induction filter
  178. small turbo escos timming belt cover
  179. front strut brace
  180. couple of bit's...
  181. 3 door breaking
  182. group buy k-sport big brake kit
  183. 18" Dunlop & Michelin slicks , for 9 &10" wide rims !
  184. 2wd AVO coilovers SOLD
  185. t34 stainless water pipes
  186. Few 2wd cossie parts
  187. 2 wheel drive Sapph breaking, stage 3 kit etc
  188. Sapph morrettes (pics added) Sold
  189. escos blue boost hoses,altinator,,conrods,dump valve,small turbo chip,engine mounts
  190. Colins ECU
  191. Cosworth rear brakes
  192. Stainless Battery Cover (Cosworth Logo)
  193. Bailey DV34 Venturi DUMP VALVE (cosworth fitment)
  194. engine rebuild parts/3 dr car cover/ turbo/ diff
  195. need a bit of advice
  196. cosworth 2wd engine wiring harness
  197. cosworth 2wd l6 ecu
  198. cosworth garett t34 turbo with .48 housing.
  199. escort cosworth gtill
  200. 3'' 2wd down pipe(cossie)& B&M 4x4 shifter & more
  201. bailey turbo damper**NEW PRICE**
  202. Bailey dv24 cosworth dump valve £40 posted SOLD
  203. 2wd T5 gearbox
  204. few cosworth bits
  205. cosworth uprated suspension parts (NOW WITH PIC'S)
  206. 4x4 Cosworth parts
  207. Maybe selling my T34 ALS and?
  208. 2wd exhaust manifold
  209. Smokestone Sapphire Cosworth 4x4
  210. escort cossie for 6 grand?
  211. Escort Cosworth air box
  212. BD12 Inlet Cam 2wd
  213. brand new omex 600 loom and ecu £650
  214. NMS Chip + Standard Fuel pump
  215. Escos & 2wd bits....
  216. exhaust 2wd stainless
  217. cosworth cam pullys new
  218. Breaking 2WD crystal blue sapph
  219. 4x4 Cosworth Engine T34 Turbo
  220. Carbon timing belt cover
  221. Genuine ford exhaust studs and washers
  222. escort cosworth part's
  223. Brand New 3 Door ECU Cover.
  224. SOLD
  225. New Cosworth Samco 2wd Boost Hoses - £80 delivered
  226. k400 wrc
  227. Ally fuel tank, hose, sender etc.
  228. rear compbrake kit sold
  229. 3dr mint parcel shelf!!
  230. Plug leads for sale
  231. moonstone blue 4x4 cosworth breaking
  232. cossie stuff pics included RS500 airbox
  233. chrome parts for sale
  234. cosworth engine
  235. 2wd ap 6 paddle clutch £90 delivered no offers
  236. chips
  237. 2wd sapphire
  238. 2wd rs cosworth sapphire
  239. Gt3582r turbo
  240. 3dr cosworth bits and bobs
  241. 2wd calipers
  242. 2wd T5 gearbox
  243. 3 door parts
  244. A few bits......
  245. 2wd prop
  246. samco 2wd PICS
  247. 2wd Plenum Cover and Modded Elbow *SOLD*
  248. 2wd Engine Loom (Offers?)
  249. 3 door custom speaker builds, with speakers tweeters and crossovers
  250. Quaife atb 4x4 cos front
