PDA
View Full Version : Ford RS Cosworth Parts for Sale
Pages : 1 2 3 4 5 [6] 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54
  1. Some cossie bits for sale
  2. AP racing calipers and discs for sale
  3. Quaife T5 bernie box for sale
  4. Parts for sale
  5. 3 Bar For sale
  6. P8 ecu and pf09
  7. air boxes for sale
  8. rs
  9. Cosworth 4x4 Bigtooth Fixit Gearbox
  10. RS500 Exhaust
  11. 4x4 Cosworth Engine
  12. EFR7670 T4 twinscrolled
  13. 2wd Quaife Diff (2k miles)
  14. Various Cosworth Parts
  15. Collins Pro monitor 4x4 loom
  16. Cosworth cone filter heat sheild
  17. Stainless steel exhaust
  18. AP BIG BRAKES 2wd Front brakes 4 pot discs and bells SOLD !
  19. Sapphire cosworth leather interior
  20. saff roof
  21. Rs500 rear upper spoiler --- sold ---
  22. Few Bits - Update 15/09/2014
  23. Cosworth YB 'O' ring inlet manifold
  24. Cosworth 4x4 Bara straight cut gearbox NEW
  25. 2WD Diff
  26. Sapphire rear door plastic triangles / 4x4 Mahle pistons
  27. RS2k Seats on Escos/Sierra runners
  28. Escort Cosworth 370BHP, Big Tooth Box, Quaife Front And Rear Diff, Breaking
  29. BD14 inlet cam
  30. Cosworth 650BHP turbo/manifold/waste gate. Dyno proven
  31. Cosworth 4x4 dry sump set up, sump.
  32. Sierra RS500 cosworth airbox SOLD
  33. 4 very clean complete Saff Cos doors with rubbers & bump strips
  34. DTA S40 Pro ECU and Loom
  35. SOLD
  36. Sapphire cosworth cloth seats
  37. escort en sierra rs cosworth parts (new parts added !)
  38. Wanted** 2wd gearbox
  39. 2wd sapph cosworth parts for sale
  40. 3" Stainless Steel V-Banded 2WD Cossie Exhaust ***SOLD***
  41. Cosworth 205 block/pistons/rods with ARP bolts
  42. Latest 2wd cosworth breaker
  43. Escort Cosworth Rear Beam
  44. Escort cosworth carello headlights
  45. Sierra 4x4 Floorpan
  46. SPA Digital oil pressure and water temp gauge
  47. 4x4 shocks and springs nearly new
  48. Blitz Dual Solenoid SBC R Boost Controller ***SOLD***
  49. Classic Additions Outdoor Cover for Sapphire
  50. Escort Cosworth WRC RHD Breaking
  51. Tyre, light seals and 2wd king lead
  52. Parts
  53. T4 turbo
  54. cosworth cylinder head
  55. L8 ecu with wasted spark set up
  56. AB07 cam
  57. pinto cosworth efi manifold
  58. cosworth power steering cooling pipe
  59. 2wd tps
  60. 2wd braided turbo oil feed pipe
  61. Brand new ford battery cover & road angel
  62. AIM MXL Dash Carbon Fiber Surround
  63. Sierra Cosworth Leather Seat + polybushes
  64. Ford racing gauges
  65. Latest 4x4 cosworth breaker AND 2WD!!!!!!!!
  66. Escos Electric sunroof kit
  67. Cosworth adjustable control arms
  68. Genuine RS 4 spoke steering wheel red/brown
  69. Cosworth long studs
  70. Selection of cossie bits
  71. 2wd T5 gearbox parts
  72. cosworth gt turbo exhaust flange adapter
  73. cone filter
  74. gt35 turbo to filter hose
  75. roose hoses
  76. Wanted cosworth t5 gearbox
  77. More parts
  78. TT T38, P8 ALS board + bits
  79. Couple of Sapphire Cosworth bits
  80. boost hoses
  81. Escort Cosworth parts.
  82. 2wd dizzy with cap
  83. jacking covers new old stock. sold
  84. cossie cloth interior lattice wheel
  85. Bosch 023 fuel pump
  86. L8 with Wasted Spark, Greens, 3bar
  87. Just gauging interest "C16VRS" Private plate
  88. Sierra sapphire parts new & old please look
  89. Gaz coilovers
  90. Compomotive 18" TH Wheels
  91. GTX3076, Tubular Manifold, Turbosmart Wastegate Package ***SOLD***
  92. 17'' raceline rl7's
  93. Piper vernier pulleys, ggr catch tank
  94. 3dr Sierra replica breaking
  95. Quaife big tooth 4x4 gearbox
  96. 4x4 378mm ap brakes
  97. cosworth shocks and springs
  98. Twin 044 fuel pump set up SOLD
  99. Stunning rolling Sapphire 2wd shell and more
  100. cosworth cranks , rods, and pistons
  101. 803 green injectors
  102. Lots of little Saph Cossie bits taking to Ford Fair
  103. Parts clearout
  104. Bara straight cut big tooth gearbox.
  105. Carbon fibre cambelt cover and steering wheel boss
  106. Yb crank
  107. Cosworth Parts
  108. Sold
  109. om
  110. full lock set for sierra saph cosworth inc cap/boot £80
  111. few cossie bits!!! prices up!! Can bring to fordfair!!!
  112. Cosworth parts. Some goodies :)
  113. engine mounts and engine parts
  114. genuine ford whether strips brand new
  115. Escort cosworth alloy!
  116. Cosworth tps new and throttle cable !
  117. concours 2wd steering wheel SOLD!!!!!!!
  118. Paying for and Receiving goods( please read
  119. dash board clocks and genuine ford jacking covers
  120. 2wd tps pf01
  121. pectel coms/data cable
  122. Cosworth Amal valve
  123. BOSCH 803 Dark green injectors
  124. cassette holder
  125. sold..
  126. 2wd sapphire re-shelled in for breaking
  127. L6
  128. ECU,s
  129. sapphire 2wd header tank
  130. Immaculate RS 4 Spoke Steering Wheel
  131. Some tasty Cosworth bits
  132. B&M Quickshift For Sierra/Escort 4x4 Cosworth
  133. Alternator heatshield
  134. a pair of willans harnesses with pads brand new. SOLD
  135. sapphire trim rubbers ect
  136. Dateless private plate --500 HXD--
  137. 108 mm cossy drive shafts
  138. cossy genuine boost hoses
  139. Escort Cosworth Engine Loom SOLD
  140. L8 ECU with MSD wasted spark - SOLD
  141. Brand New MSD Wiring Loom With Wasted Spark
  142. Cool fan switch
  143. Up-Rated Diffs And Gearboxes
  144. A Couple Of Bolt Sets I've Made Up
  145. Group A k&n filter and 76mm inlet pipework.
  146. Ford Sharktooths
  147. Wanted 4x4 big turbo engine
  148. Solid beam mounts cosworth
  149. damaged and cracked head good for mock up
  150. heater matrix
  151. plastic gear stick surround
  152. cosworth 3dr parts for sale.
  153. R&D 7.5" plated rear differential
  154. SCS all ALLOY 2.2 800bhp YB plug and play unit
  155. So here goes
  156. cosworth front and rear axle bits!
  157. Set of Siemens 83lb injectors
  158. Breaking 4x4 sapphire cosworth
  159. kent cams pulleys
  160. Spec-R, Garrett Bar and plate, top feed intercooler
  161. compomotive group A wheels just refurbed
  162. Cosworth IECS Monitor
  163. Spec-R cosworth turbo heat shield
  164. Airtech gob stopper top feed intercooler
  165. Sold
  166. 2wd vibratechnic engine mounts
  167. Wasted spark plug leads
  168. Bailey turbo damper
  169. RS500 Diecast model, posters and mags.
  170. Rs cosworth diecast models,posters and mags.
  171. Rear brake pipes Ecort cosworth
  172. 4 x Bosch 803 green injectors £100
  173. 2wd Konis and Ahmed Springs
  174. Mahle pistons and polished rods x3
  175. WANTED: 7.5" rear diff & .63 exhaust housing
  176. few cosworth bits more added some chrome bits?
  177. saph cos 2wd parts
  178. New oil breather hose blue roose m/sport
  179. clifford parts for sale
  180. MAD 2.2 Cosworth Engine - 670 Bhp - Prov Sold
  181. number plate value
  182. Sold
  183. Cosworth parts for sierra 2wd and 4wd cars
  184. Brand new cosworth parts mainly 2wd some 4wd to
  185. Set of genuine rear ambers *new*
  186. SOLD
  187. Bailey 3dr header tank and cap
  188. Genuine MAP sensor EsCos HTT *new*
  189. Cosworth cam pully
  190. Cosworth 4x4 intercooler
  191. Cosworth 4x4 inlet manifold
  192. rear callipers
  193. Cosworth whie clock
  194. Sold.
  195. Gt30 100mm k&n filter.ggr oil catch tank
  196. Escort Cosworth WRC LHD Trimmed Shell
  197. a few switches and ignition parts
  198. Motorsport ht leads
  199. Breaking My Escort Cosworth
  200. rebuilt 2wd gearbox
  201. Alloy Fuel Cell (tank) Foam Filled
  202. SOLD
  203. Throttle cable bracket and batteryclamp kit for saph cossie
  204. L6 ecu
  205. 2wd/3door avo coilovers for sale £300
  206. various cosworth parts just in!!
  207. Cosworth blingy bits
  208. Few cosworth bits from my garage
  209. 2wd yb crank
  210. AB07 Inlet Cam with tappets, less than 100 miles done
  211. Few Cosworth bits for sale
  212. Cosworth standard bore 90 200 block
  213. wizard of nos hydro injection kit
  214. NOS fuel pump cradel clamp
  215. job lot bits reduced
  216. 4wd bigwing sump sold
  217. Bosch 044
  218. 7.5" Gripper diff - SOLD
  219. SOLD
  220. lu
  221. Some cosworth bits collection & DELIVERY
  222. cosworth turbo hanger/4x4 alloy and tyre
  223. race tech water temp and oil press gauges
  224. Sapphire Cosworth parts
  225. Rs500 style I/C, 2wd exhaust 2wd & 4x4 front sub frames
  226. cosworth alloy engine mounts
  227. Bosch dark green injectors
  228. Genuine NEW 2wd water pump
  229. Cosworth RS500 Rear Spoilers
  230. ..
  231. Sold
  232. Cosworth engine turn key package
  233. Twin plate ALCON clutch kit & stainless steel lightweight flywheel,**SOLD**
  234. Cosworth T4 Turbos (Fully Rebuilt)
  235. Sold
  236. Bucket seats and 6 point harness's
  237. Forge actuator Escort Cosworth
  238. FOR SALE...Cosworth fuel pump cradle
  239. Team heko wind deflectors
  240. K and N
  241. Cosworth 2WD engine mounts
  242. 2wd saph engine
  243. Rare Weber remote idle valve bracket and Turbo water pipes
  244. 300mm rear disc conversion, couple of billet bits
  245. Escort Cosworth Original Tank Straps and Fuel Filter Bracket NOW WITH PICS
  246. AP racing twin plate clutcth & flywheel
  247. AP 4 pots + Compbrake 6 Pots
  248. escort cosworth front anti roll bar
  249. flo flex bushes
  250. 2wd engine complete whats it worth ?
